  • Nicolett
  • Registratie: Februari 2021
  • Laatst online: 05-01-2022
HI,
I print clay cutters. But since a few days I have a problem with the prints. I replaced the nozzle and checked the capricorn tube. Nothing gets stuck there.
Afbeeldingslocatie: https://tweakers.net/i/EcYi0tBu9UXhtPfSFHna01oc-Mk=/x800/filters:strip_icc():strip_exif()/f/image/zPJl1iH8R04HSiY6HtHfspL0.jpg?f=fotoalbum_large
I have checked all settings and they are exactly as I have been printing for a long time without any problems.
The print seems to have melted slightly (or pressed in to the layer below), but is above all a lot less high than it should be. The print appears to have been pressed. The photo shows a clear example. On the left is the incorrect print, on the right the size as the cutter should be.
Afbeeldingslocatie: https://tweakers.net/i/g681rQKwIXn1j_9NBS8FSpJGHrs=/x800/filters:strip_icc():strip_exif()/f/image/tiZDOMVGsOV28jquD2NyCfgo.jpg?f=fotoalbum_large
Could this be a problem with over-extrusion? I've also had 3 reports about homing failed, printer stopped. But this resolved itself by turning the printer off/on.
I am not very familiar with all the technical aspects of 3D printing. So I'm looking for help with this problem!
Thank you in advance.
  • _ferry_
_ferry_
Moderator Tweaking
Nipple Tweaker
Graag verder in het Nederlandse topic
