Zigbee2mqtt niet werkend te krijgen: 502 bad gateway
  • nachtwaker
  • Laatst online: 13-11 09:47
Mijn vraag
Zigbee stick: cc2652RB
log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[00:38:32] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[00:38:32] INFO: MQTT available, fetching server detail ...
[00:38:32] INFO: Previous config file found, checking backup
[00:38:32] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[00:38:33] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[00:38:34] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.21.2-dev start
> node index.js
Zigbee2MQTT:info 2021-10-08 00:38:41: Logging to console and directory: '/config/zigbee2mqtt/log/2021-10-08.00-38-38' filename: log.txt
Zigbee2MQTT:info 2021-10-08 00:38:41: Starting Zigbee2MQTT version 1.21.2-dev (commit #89d2b00)
Zigbee2MQTT:info 2021-10-08 00:38:41: Starting zigbee-herdsman (0.13.154)
Zigbee2MQTT:error 2021-10-08 00:38:50: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-10-08 00:38:50: Failed to start zigbee
Zigbee2MQTT:error 2021-10-08 00:38:50: Check https://www.zigbee2mqtt.i...igbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-10-08 00:38:50: Exiting...
Zigbee2MQTT:error 2021-10-08 00:38:50: TypeError: Cannot read property 'length' of null
at AdapterNvMemory.init (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:28:42)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:60:9)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:97:27)
at start (/app/index.js:95:5)
[00:38:50] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Iemand een idee, ben een beetje te einde raad.....
  • HKLM_
  • Laatst online: 21:35
Dit heb je al verder uitgeplozen?
Cloud ☁️
  • Deshmir
  • Laatst online: 07:57
Staat inderdaad ongeveer 1 vergelijkend issue op het web zonder verder vervolg.
Heb je de modemmanager deinstalled? En hiuarct disabled?
Last resort is de firmware opnieuw te flashen, als dat niet werkt de verzender even een berichtje sturen
  • nachtwaker
Deshmir schreef op vrijdag 8 oktober 2021 @ 06:28:
Wat bedoel je met modem manager en hiuarct?
Heb de laatste versie Zigbee2mqtt Edge geinstalleerd. Mag aannemen dat de laatste versie er op moet staan, zijn samen besteld met een zelfde usb stick bij een collega van me. Daar werkt het na veel pielen wel, daar staat versie 20120708 op
  • nachtwaker
HKLM_ schreef op vrijdag 8 oktober 2021 @ 05:50:
Ja stond zelfs iets over dat een IKEA Trafdri in de buurt problemen kon geven. Deze stond er naast, dus die ligt ook al los.
Heb die site verder uitgeplozen
  • Deshmir
@nachtwaker Dat staat oa in de stappen die je moet/kan doorlopen als het niet werkt.
  • nachtwaker
Maar het is mij niet helemaal duidelijk hoe je de firmware kan flashen iemand een idee?
  • nachtwaker
Op die site heb ik hem ook aangeschaft.
En ben behoorlijk dummy, ben eigenlijk op zoek naar een handige stappen plan. Wil de firmware flashen vanaf een Windows pc.
En ik denk dan de laatste firmware. iets van 3.0 (https://github.com/Koenkk...dinator/Z-Stack_3.x.0/bin)
[ Voor 17% gewijzigd door nachtwaker op 08-10-2021 12:49 ]
  • francisp
  • Laatst online: 12-05 09:17
Deze heb je nodig :
CC2652RB_coordinator_20210708.zip
  • nachtwaker
francisp schreef op vrijdag 8 oktober 2021 @ 13:14:
Deze heb je nodig :
Ja die heb ik. Fijn dat je me hier ook helpt :)
https://community.home-as...502-bad-gateway/344803/12
Maar moet je die usb stick in je computer doen en dan BL knop inhouden en dan RST knop 1x indrukken?
Moet het programma SmartRF Flash Programmer 2 al actief openstaan?
  • francisp
Bij de CC2652R moest ik de BL knop ingedrukt houden bij het plaatsen in de USB poort, en nog enkele seconden nadien. Bij de slaesh pin moet je blijkbaar nog eens op RST klikken nadien ook
  • nachtwaker
francisp schreef op vrijdag 8 oktober 2021 @ 13:20:
Ok, en het programma mag wel gewoon actief zijn? Anders kom ik een paar handen te kort ;)
  • francisp
Ik denk niet dat het uitmaakt. Ik dacht dat ik eerst de stick in de USB gestoken heb en pas daarna Smart Programmer v2 opgestart.
  • nachtwaker
Afbeeldingslocatie: https://tweakers.net/i/EqzSo1pc8lJgJH6zEo768YDIUJM=/800x/filters:strip_exif()/f/image/ORlw08Pi5UvUUv6AO54aTkK3.png?f=fotoalbum_large
Ik krijg dit? Maar disable bootloader is grijs. Volgens mij is dit niet goed? Heb de handelingen gedaan die je doorgaf...blijkbaar doe ik iets fout.
  • francisp
Zolang er maar geen vinkje staat bij 'disable bootloader'
Nu bij actions nog een vinkje zetten bij Erase, Program en Verify, en dan op de blauwe knop |> drukken.
  • nachtwaker
francisp schreef op vrijdag 8 oktober 2021 @ 13:58:
Aangevinkt, en op blauwe knop gedrukt gaat heel even lopen en breekt dan de applicatie af.
Afbeeldingslocatie: https://tweakers.net/i/gMX68_UqjnmifLMhonDyBYTCIsY=/800x/filters:strip_exif()/f/image/c1qGrxnII7hLYAh4NQqPwOpv.png?f=fotoalbum_large
In de rode cirkel zou toch wat moeten staan aan info?
  • francisp
Dat komt er maar na het drukken op de blauwe |> bol.
  • nachtwaker
OK maar de applicatie breekt compleet af.
  • francisp
Dan zou ik tock maar eens contact opnemen met slaesh.
  • francisp
je zou zoiets moeten zien :
Afbeeldingslocatie: https://electrolama.com/_assets/flash-prog-ok.png
  • nachtwaker
Krijg deze melding:
Afbeeldingslocatie: https://tweakers.net/i/MeCOCjrDitCcD2sVXbNTWs9ZND4=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/iQkKgvdcrMzU5OdcC2awlCKe.png?f=user_large
en die slaesh schijnt heel slecht bereikbaar te zijn
  • francisp
Dan is uw stick niet in bootloader mode.
Nog eens proberen, lijkt mij ook anders dan de stick die ik heb :
Press and hold the bootloader-enable button (nearest to the chip, marked with small "BL")
Just press/click the reset-button (nearest to the usb-connector, marked with small "RST")
The bootloader-pin can be released.
  • nachtwaker
Afbeeldingslocatie: https://tweakers.net/i/WZLVHFjqkrOqDVFTcn6975WchHg=/800x/filters:strip_exif()/f/image/qkxzqhAavZrXwJKh4hmAMhmB.png?f=fotoalbum_large
Zo dus!!!
Moet ik daarna nog iets doen of is het nu een kwestie van de stick weer in mn nas doen?
[ Voor 36% gewijzigd door nachtwaker op 08-10-2021 14:45 ]
  • francisp
Gewoon terug in de NAS en kijken of je de fout opnieuw krijgt.(hopelijk is het met de flash opgelost)
  • nachtwaker
Hij werkt nu volgens mij
Kan alleen geen devices vinden:
fo Zigbee: disabling joining new devices.
Info MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":false},"status":"ok","transaction":"fahs7-1"}'
Info Zigbee: allowing new devices to join.
Info MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"fahs7-2"}'
Heb hier een ikea lamp liggen die heb ik gereset (6x aan en uit)
  • Septillion
  • Laatst online: 07:19
Septillion
Hoe probeer je dat, gewoon via de webinterface van Zigbee2MQTT? En de meeste lampen gaan knipperen / op-neer faden als de in pairmode staan.
  • nachtwaker
Is allemaal gelukt, merk alleen op dat het bereik niet super is. Zit soms een lichte vertraging op.
Ben blij dat het nu werkt, is een kwestie van de firmware updaten. Wat nog wel heel belangrijk is als aanvulling. Zorg dat je op de computer de drivers van de zigbee hebt geinstalleerd anders gaat het flashen niet lukken
Andere antenne is misschien een idee voor het bereik? iemand ervaring mee?
  • etienne001
  • Laatst online: 23:43
nachtwaker schreef op vrijdag 8 oktober 2021 @ 17:08:
Ik zou eerst een USB verlengkabel testen. Dat werkt in 99% van de gevallen met de Zigbee sticks.
