Survey on plug-in hybrids
  • 322 views
Hello electric car fans,
I would like to present you a small survey and would be very pleased if you take 10 minutes and answer it.
It's about plug-in hybrids, these vehicles have besides the electric motor also a gasoline engine to cover longer distances. They are preferred for tax purposes, especially if they are used as a company car. Unfortunately, they are often criticized because they are often not used as intended. The charging rate that is too low and a consumption higher than expected, are noted. Fraunhofer ISI, together with ICCT, is currently investigating the real-world use of these vehicles. (something similar from last year: *knip*).
For this purpose, a survey has been launched to investigate the real-world use of plug-in hybrid. If there are any questions about the survey, you can find contact information and the survey at the following link:
*knip*
Best regards,
Marc
[ Voor 8% gewijzigd door deepbass909 op 27-09-2021 20:03 ]
  • deepbass909
  • Laatst online: 22:03
deepbass909
Modbreak:Voor iedere enquête moet vooraf expliciet toestemming zijn verleend. (Het algemeen beleid #verbodenspam) Voor deze enquête is dit niet het geval en gaat deze op slot.
