[Synology] USB ethernet link status
  • menn0
  • Laatst online: 16:03
Heb een 215j en zelf de drivers compiled voor armada375 arm.
root@Synology:~# lsusb
|__usb1          1d6b:0002:0302 09  2.00  480MBit/s   0mA 1IF  (Linux 3.2.40 ehci_hcd Marvell Orion EHCI ehci_marvell.0) hub
|__usb2          1d6b:0002:0302 09  2.00  480MBit/s   0mA 1IF  (Linux 3.2.40 ehci_hcd Marvell Orion EHCI ehci_marvell.1) hub
|__usb3          1d6b:0002:0302 09  2.00  480MBit/s   0mA 1IF  (Linux 3.2.40 xhci-hcd xHCI Host Controller xhci-hcd) hub
|__usb4          1d6b:0003:0302 09  3.00 5000MBit/s   0mA 1IF  (Linux 3.2.40 xhci-hcd xHCI Host Controller xhci-hcd) hub
  |__4-1         0b95:1790:0100 ff  3.00 5000MBit/s 124mA 1IF  (ASIX Elec. Corp. AX88179 000000000000B6)
En:
eth1      Link encap:Ethernet  HWaddr 00:0E:C6:8E:1E:36
          inet addr:192.168.1.222  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:200 (200.0 B)  TX bytes:0 (0.0 B)
Zelf ip adres opgegeven, via dhcp werkt het niet, pointers naar het probleem zijn dat ie via dhcp een 169 krijgt maar ook;
Link detected: no
29
root@Synology:~# ethtool eth1
Settings for eth1:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: Symmetric Receive-only
        Link partner advertised auto-negotiation: Yes
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 3
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: pg
        Wake-on: g
        Current message level: 0x00000007 (7)
                               drv probe link
        Link detected: no
Ik heb meerdere kabels geprobeerd dat is het echt niet, in de GUI van synology zie je wel de 2e nic maar bij Netwerkstatus is er niets ingevuld.
het resetten van alle interfaces;
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
root@Synology:~# /etc/rc.network restart
rm: cannot remove ‘/etc/dhcpd/dhcpd.conf.leases’: No such file or directory
rm: cannot remove ‘/etc/dhcpd/dhcpd-leases.log’: No such file or directory
network-interface stop/waiting
stop: Unknown instance: eth0
stop: Unknown instance: eth0/client
stop: Unknown instance: eth0/info
stop: Unknown instance: eth0/pd
stop: Unknown instance: eth1
stop: Unknown instance: eth1/client
stop: Unknown instance: eth1/info
stop: Unknown instance: eth1/pd
stop: Unknown instance: lo
stop: Unknown instance: lo/client
stop: Unknown instance: lo/info
stop: Unknown instance: lo/pd
stop: Unknown instance: tun
stop: Unknown instance: tun/client
stop: Unknown instance: tun/info
stop: Unknown instance: tun/pd
SIOCSIFADDR: No such device
tun: ERROR while getting interface flags: No such device
cat: /proc/sys/kernel/syno_skip_vender_mac_interfaces: No such file or directory
eth0      Link encap:Ethernet  HWaddr 00:11:32:46:F0:09
          inet addr:192.168.1.30  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: 2a02:a463:f807:1:211:32ff:fe46:f009/64 Scope:Global
          inet6 addr: fe80::211:32ff:fe46:f009/64 Scope:Link
          RX packets:42357578 errors:0 dropped:0 overruns:0 frame:0
          TX packets:21717817 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1024
          RX bytes:971161604 (926.1 MiB)  TX bytes:1600324732 (1.4 GiB)
          Interrupt:73
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:82916 errors:0 dropped:0 overruns:0 frame:0
          TX packets:82916 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:5669553 (5.4 MiB)  TX bytes:5669553 (5.4 MiB)
Ik verwacht een 2e ip adres te krijgen in de range 192.168.1.X
Enig idee wat hier mis gaat?
  • Ben(V)
Het probleem is dat DSM het niet ondersteund en enkel een driver compileren niet voldoende is om dit werkbaar te krijgen.
  • m.eddy
  • Laatst online: 18:39
Wellicht even aan Donny007 vragen.
Hij kreeg het voor elkaar op een + model.
productreview: Club 3D USB 3.2 Gen1 Type A to RJ45 2.5Gbps Ethernet Adapter r...
En ook:
https://www.reddit.com/r/...bps_usb_ethernet_adapter/
[ Voor 12% gewijzigd door m.eddy op 16-09-2021 20:02 ]
  • menn0
Já die adapter is easy peasy maar ik had deze nog liggen.
Wellicht dat het eerder in m'n Makefile verkeerd is gegaan maar ik had dan eerder errrors verwacht.
@Ben(V) de bovengenoemde adapter is zelfs via de GUI te installeren... Klopt is geen standaard DSM feature maar daar ben je Tweaker voor toch?
  • Ben(V)
Jawel maar het is niet voldoende om een driver voor een armada cpu te bouwen, je moet hem minimaal meelinken met de Synology toolchain.
  • menn0
Dat heb ik uiteraard gedaan! :)
  • menn0
Ok ik had nog een USB dongle aan mn USB poort hangen voor tado, die eruit gehaald en deze dongle op mn USB 2.0 poort gehangen en;
dmesg
[18377.952264] ADDRCONF(NETDEV_UP): eth1: link is not ready
[18378.021864] ax88179_178a 1-1:1.0: eth1: ax88179_178a - Link status is: 1
[18381.078374] ax88179_178a 1-1:1.0: eth1: Write medium type: 0x0033
[18381.153374] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[18381.166122] ax88179_178a 1-1:1.0: eth1: link up, 1000Mbps, full-duplex, lpa 0xCDE1
en een pingetje vanuit windows naar 192.168.1.123 (.30 is de interne nic)
Afbeeldingslocatie: https://tweakers.net/i/eJeEpE03Pp0M-D7u7SamLQiPwzg=/800x/filters:strip_icc():strip_exif()/f/image/GQn051D4XSpMD4qgmh0z47SB.jpg?f=fotoalbum_large
