Xfree 4.1 onder Slackware 8.0
  • 61 views sinds 30-01-2008
  • scim
  • Laatst online: 08-07 09:53
Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "Module"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "pex5"
Load "type1"
Load "freetype"
Load "record"
Load "xie"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "PS/2"
Option "Device" "/dev/mouse"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "PciRetry" # [<bool>]
#Option "rgbbits" # <i>
#Option "NoAccel" # [<bool>]
#Option "TurboQueue" # [<bool>]
#Option "SetMClk" # <freq>
#Option "FastVram" # [<bool>]
#Option "ForceCRT2Type" # [<str>]
#Option "ShadowFB" # [<bool>]
#Option "Rotate" # [<str>]
#Option "NoXvideo" # [<bool>]
Identifier "Card0"
Driver "sis"
VendorName "SiS"
BoardName "5597"
BusID "PCI:0:20:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 8
SubSection "Display"
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Dit is dus mijn XF86Config file, maar ik als ik X opstart werkt het gewoon, er is alleen een probleem met het beeldformaat, dat is heel erg opgerekt. Het is een oude monitor en ik kan het beeld dus niet in elkaar duwen zoals bij nieuwere monitor. En ik kan niet echt vinden waar ik mijn schermgrootte kan instellen.
Deze config file is btw gemaakt met behulp van xfree86setup...
Iemand die mij kan helpen?
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Op zondag 19 augustus 2001 16:09 schreef Sorcerer@ het volgende:
Het magische woord, is in dit geval : xvidtune
Klein programmaatje, waarmee ik altijd m'n beeldscherm goed zet. Wel ff als root draaien geloof ik..
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • scim
Hmm in console geeft dat als error.
Can't open display
maar ga eens kijken of ik wat in X kan
in X richt het ook niks uit :(
  • deadinspace
  • Laatst online: 16-08 16:08
deadinspace
The what goes where now?
xvidtune in de console gaat niet werken nee - het wil een X display creëeren. Maar in X zou het gewoon moeten werken, en het hoeft niet als root.
Lijkt mij dat je gewoon je modes moet instellen.
Normaal staan die bij de Section Screen dacht ik..
Je zou dat eigenlijk ook bij xf86setup moeten opgeven.
Het makkelijkst is om de modes die je niet gebruikt weg te halen en alleen die achter te laten die je wel gebruikt (in de volgorde waarmee je er met TAB doorheen wilt wandelen).
  • Jordi
Jordi
#1#1
Mwa, denk niet dat de starter er nu nog op zit te wachten (hint: datum ;) )
Het zal wel niet, maar het zou maar wel.
