Crash en auto restart tijdens games
  • KopjeKoffie_21
  • Registratie: April 2020
  • Laatst online: 28-07 22:33
Beste tweaker,
Tijdens het spelen van games als Warzone, Destiny 2 en F1 2021 heb ik regelmatig crashes. Mijn scherm wordt dan zwart, het geluid gaat in een loop en de PC start automatisch opnieuw op. WhoCrashed geeft mij de volgende info op het moment van crashen:
On Thu 19-8-2021 23:36:49 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\LiveKernelReports\WATCHDOG\WATCHDOG-20210819-2336.dmp
This was probably caused by the following module: amdkmdag.sys (0xFFFFF8032EC94B90)
Bugcheck code: 0x142 (0xFFFF880461C6E110, 0xFFFFF8032EC94B90, 0x0, 0xB44)
Error: VIDEO_TDR_APPLICATION_BLOCKED
file path: C:\WINDOWS\System32\DriverStore\FileRepository\u0369070.inf_amd64_f201604fbb8aca98\B369060\amdkmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that an application has been blocked from accessing graphics hardware.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: amdkmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: amdkmdag.sys Advanced Micro Devices, Inc. VIDEO_TDR_APPLICATION_BLOCKED
Of ik krijg deze melding, van dezelfde AMDKMDAG.sys
crash dump file: C:\WINDOWS\LiveKernelReports\WATCHDOG\WATCHDOG-20210731-1440.dmp
This was probably caused by the following module: amdkmdag.sys (0xFFFFF8018DC34B90)
Bugcheck code: 0x141 (0xFFFFBA0E297C8460, 0xFFFFF8018DC34B90, 0x0, 0x548)
Error: VIDEO_ENGINE_TIMEOUT_DETECTED
Bug check description: This indicates that one of the display engines failed to respond in timely fashion.
Google query: amdkmdag.sys Advanced Micro Devices, Inc. VIDEO_ENGINE_TIMEOUT_DETECTED
Tot nu toe heb ik het volgende gedaan:
- DDU
- Reinstall game
- Update BIOS, Drivers, Chipset
- PCI naar gen3 in BIOS
- Testen van het RAM in alle sloten en ook individueel
- Game settings veranderen (lager zetten voornamelijk)
- Kabels controleren op fouten etc.
Mijn systeem:
1ProcessorsAMD Ryzen 5 3600 Boxed€ 225,-€ 225,-
1MoederbordenASRock B450M Pro4€ 69,-€ 69,-
1VideokaartenPowercolor Red Dragon Radeon RX 5700€ 0,-€ 0,-
1Behuizingenbe quiet! Pure Base 500DX Wit€ 89,21€ 89,21
1MonitorenMSI Optix MAG24C (S15-0003079-HH5) Rood, Zwart€ 0,-€ 0,-
1ProcessorkoelingArctic Freezer 34 eSports DUO (Zwart / Wit)€ 39,15€ 39,15
1Geheugen internCrucial Ballistix BL2K8G32C16U4W€ 84,05€ 84,05
1VoedingenCooler Master MWE Bronze 550W V2€ 56,-€ 56,-
1Solid state drivesCrucial P1 1TB€ 102,11€ 102,11
Wat mij is opgevallen is dat het vaak voorkomt in laad schermen. Dus bijvoorbeeld tussen het spelen van potjes door. Dit is echter niet altijd het geval, want soms gebeurd het ook midden in de game (maar naar mijn idee wel een stuk minder).
[ Voor 10% gewijzigd door KopjeKoffie_21 op 20-08-2021 10:41 ]
