Synology ds218+ nextcloud/notes permission denied
  • Cyberdemon
  • Registratie: Oktober 2016
  • Laatst online: 08-09 07:15
Hey.
Sinds een week kan ik niets meer uploaden via de Android nextcloud + notes app.
Ik krijg dit als foutmelding :
App Version: 3.4.11
App Version Code: 3004011
App Flavor: fdroid
Files App Version Code: 30160190
OS Version: 4.9.133+(55e5c029ac)
OS API Level: 27
Device: star2lte
Manufacturer: samsung
Model (and Product): SM-G965F (lineage_star2lte)
java.lang.Exception: com.nextcloud.android.sso.exceptions.UnknownErrorException: failed to connect to /192.168.0.249 (port 80) from /:: (port 36449) after 60000ms: connect failed: EACCES (Permission denied)
at it.niedermann.owncloud.notes.persistence.NotesServerSyncTask.pushLocalChanges(NotesServerSyncTask.java:158)
at it.niedermann.owncloud.notes.persistence.NotesServerSyncTask.run(NotesServerSyncTask.java:94)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:457)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
at java.lang.Thread.run(Thread.java:764)
java.lang.RuntimeException: com.nextcloud.android.sso.exceptions.UnknownErrorException: failed to connect to /192.168.0.249 (port 80) from /:: (port 36817) after 60000ms: connect failed: EACCES (Permission denied)
at io.reactivex.internal.util.ExceptionHelper.wrapOrThrow(ExceptionHelper.java:46)
at io.reactivex.internal.observers.BlockingMultiObserver.blockingGet(BlockingMultiObserver.java:93)
at io.reactivex.Maybe.blockingGet(Maybe.java:2321)
at io.reactivex.Observable.blockingSingle(Observable.java:5381)
at it.niedermann.owncloud.notes.persistence.NotesServerSyncTask.pullRemoteChanges(NotesServerSyncTask.java:219)
at it.niedermann.owncloud.notes.persistence.NotesServerSyncTask.run(NotesServerSyncTask.java:96)
Caused by: com.nextcloud.android.sso.exceptions.UnknownErrorException: failed to connect to /192.168.0.249 (port 80) from /:: (port 36817) after 60000ms: connect failed: EACCES (Permission denied)
at com.nextcloud.android.sso.api.AidlNetworkRequest.performNetworkRequestV2(AidlNetworkRequest.java:172)
at com.nextcloud.android.sso.api.NextcloudAPI.performNetworkRequestV2(NextcloudAPI.java:171)
at com.nextcloud.android.sso.api.NextcloudAPI.lambda$performRequestObservableV2$1$NextcloudAPI(NextcloudAPI.java:110)
at com.nextcloud.android.sso.api.-$$Lambda$NextcloudAPI$8WS9mapJbOYsPgbhBi25vBNYZqI.subscribe(Unknown Source:6)
at io.reactivex.internal.operators.observable.ObservableFromPublisher.subscribeActual(ObservableFromPublisher.java:31)
at io.reactivex.Observable.subscribe(Observable.java:12284)
at io.reactivex.internal.operators.observable.ObservableSingleMaybe.subscribeActual(ObservableSingleMaybe.java:31)
at io.reactivex.Maybe.subscribe(Maybe.java:4290)
at io.reactivex.Maybe.blockingGet(Maybe.java:2320)
... 8 more
Kan iemand mij helpen aub?
  • Cyberdemon
Weet niemand hoe je dit kan oplossen?
  • sOid
We vragen hier wel wat meer inzet dan alleen je foutmelding dumpen.
  • Wat heb je zelf al geprobeerd of uitgezocht?
  • Heb je er alleen last van als je op 4G of buiten je eigen netwerk zit, of ook binnen je netwerk? Draait de service wel op de Synology?
  • Heb je updates of wijzigingen uitgevoerd op je Synology en/of je smartphone? Of je router? Of je firewall?
  • Heeft alleen jouw Android telefoon hier last van of ook andere apparaten?
  • Hoe heb je nextcloud geïnstalleerd op je Synology?
Etc.
Zo op het eerste oog vermoed ik de Nextcloud server op je Syno gewoon niet bereikbaar is. Draait die nog wel op IP 192.168.0.249 poort 80?
  • Cyberdemon
Bedankt voor je reply
Ik zou niet weten hoe ik dit oplos dus ik heb nog niets geprobeert. Heb wel al wat gezocht maar niet veel wijzer geworden. Had een topic ergens gevonden met iemand dat een gelijkaardig probleem had maar een oplossing werd niet gegeven. Er werd wel gezegd om nextcloud op de computer eens te testen.
De nas is niet op het internet aangesloten.
Is dus enkel binnen het eigen netwerk bereikbaar.
Dus via 4g werkt het zoiezo niet.
Ik heb niets verandert. Als ik naar mijn nextcloud pagina surf kom ik er zonder foutmelding wel gewoon in. Wat ik wel kan proberen is nextcloud te installeren op mijn computer en dan iets proberen te uploaden.
Cyberdemon schreef op zaterdag 14 augustus 2021 @ 13:03:
Begin dan maar is met het opzoeken wat die foutcodes betekenen, GoT is geen Servicedesk ;) Vaak kom je een heel eind.
  • Cyberdemon
Ik heb nextcloud geïnstalleerd op mijn computer, wanneer ik de synology zijn server adres ingeef krijg ik als foutmelding:
Er trad een fout op bij het benaderen van het 'token' endpoint: error transferring https://192.168.0.249/index.php/login/v2 - server replied: not found
  • nelizmastr
  • Laatst online: 14:29
nelizmastr
Goed wies kapot
Klinkt alsof Nextcloud niet meer draait op je NAS of in ieder geval niet meer werkt.
Als je op je NAS inlogt, zie je het pakket dan wel als geïnstalleerd en actief?
Anders eens het pakket opnieuw installeren.
  • Cyberdemon
Ja hoor. Ik kan gewoon inloggen op nextcloud die op mijn nas geïnstalleerd is.
  • Cyberdemon
Is er niemand die een oplossing weet?
Ik kan nog inloggen op nextcloud dus ik denk dat daar het probleem niet ligt. Het is volgens mij het php pakket. Gezien het een php fout is
