adsl delen 1 kaart vervolg
  • 74 views sinds 30-01-2008
  • LAG
  • Laatst online: 26-09-2004
Ja, ik weet het, het is bij het zeurderige af maar ik wil hier graag duidelijkheid over hebben. Ik had al geaccepteerd dat het niet mogelijk was en de topic provisorisch gesloten, en toen las ik het volgende op de site van Sygate dat me er toch weer van overtuigde dat het wél mogelijk is.
Nu is mijn engels ook niet meer wat het geweest is, dus vandaar hier volgt de tekst.
Scalable Licensing:
Sygate Home Network software is licensed in 3, 6, and 10, 25, and unlimited user versions. Should your network grow, you can simply add more user licenses to your network.
System Requirements
Gateway Machine:
486-class processor or higher
Microsoft Windows 95, 98, ME, NT 4.0 and Windows 2000 Pro/Server
32 MB RAM or greater
One Network Interface Card -Works with Ethernet, Home PNA and Wireless Interface cards
An analog modem with a working Internet account with Microsoft Dial-Up Networking 1.2 (or higher) or America On Line 4.0 or higher
-or-
An ISDN, xDSL, DirectPC or cable modem and Internet Service Provider
-Note: Broadband Internet connections can be shared using a single Network Interface Card.
Client Machines:
Any TCP/IP client including Windows, BeOS, Mac, or Unix-based systems
How Single NIC Technology is made possible:
Sygate Technologies, Inc. Single NIC is made possible by creating a virtual NIC. The real/installed NIC is used to connect to the cable/DSL modem. The virtual NIC is used to communicate with the other computers in the LAN.
Figure 2 Single NIC Internet sharing
The server PC (PC-1) has one real IP assigned by the ISP. Sygate runs on PC-1 and creates a virtual NIC with a virtual IP 192.168.0.1
Single NIC Technology installation:
The steps to connect the Ethernet cable:
1.Remove the PC-1 side of Ethernet cable between Cable/DSL and PC-1
2.Connect that end to a HUB (In most of the cases, no need to use Uplink port)
3.Connect the rest of the computers to the HUB
Lijkt mij dat hier duidelijk omschreven wordt hoe, met behulp van Sygates software, een internet sharing connectie tot stand te brengen met behulp van één netwerk kaart in de asdl computer.
Heb ik verkeerd gelezen? Graag reakties.
Rets mij nog de vraag: hoe zien de kabels eruit in deze constructie. Dezelfde kabels tussen computers, computer>hub, hub>modem en niet crossed-over?
Waarom ga je niet gewoon verder in je vorige topic?
  • Ramon
  • Laatst online: 07:31
in dat tekstje hebben ze het over analoog of ISDN. dus mocht jij een analoge of ISDN verbinding willen delen dan is dat mogelijk met een NIC ja.
=edit=
niet alles gelezen nog... virtual NIC? jazeker... als je al zo slim bent dat je dit hebt uitgezocht... wat doe je hier dan nog? ga de site van sygate maar lekker uitpluizen... :)
  • happy3736
  • Laatst online: 30-12-2024
Op zaterdag 18 augustus 2001 17:09 schreef Tampie2000 het volgende:
nee sygate werkt ook met kabel en adsl
  • Ramon
Op zaterdag 18 augustus 2001 17:11 schreef happy3736 het volgende:
duh
  • LAG
"An analog modem with a working Internet account with Microsoft Dial-Up Networking 1.2 (or higher) or America On Line 4.0 or higher
-or-
An ISDN, xDSL, DirectPC or cable modem and Internet Service Provider"
"Note: Broadband Internet connections can be shared using a single Network Interface Card."
Volgens mij staat hier analoog OF Isdn, xdsl etc. en
NB Breedband verbindingen kunnen gedeeld worden met gebruik van één enkele netwerkkaart.
  • Ramon
oke meneer lag
paar vraagjes:
1. waarom wil je per se maar een (1) NIC gebruiken?
2. als jij het al zo goed weet... wat doe je dan hier? je gelijk halen ofzo?
Je hebt voor ADSL en kabel ook andere oplossingen (helaas niet verkrijgbaar in NL) zoals een ADSL modem op een PCI-kaartje of een kabelmodem op PCI-kaartje. Aangezien de makers van Sygate waarschijnlijk uitgaan van een amerikaanse situatie zullen ze vast dit bedoelen, in zo'n geval heb je namelijk maar een (1) network interface card.
en natuurlijk de belangrijkste vraag: Waarom probeer je het niet gewoon uit???? :? En dan kan je die kennis fijn met ons delen.
  • Jordi
Jordi
#1#1
Ga alsjeblieft verder in je oude topic:
[topic=208034/1/50]
Het zal wel niet, maar het zou maar wel.
