x265 video's, waarom eet dit veel resources, what to do?
  • Yzord
  • Laatst online: 15:58
Yzord
Ubi fumus, ibi ignis
Bij het downloaden van x265 videos valt het mij op dat wanneer ik deze afspeel het enorm veel van mijn cpu vraagt. Bij het afspelen van x264 heb ik dit probleem totaal niet.
Helaas zijn 4K video's vaak in x265 formaat en 1080p video's in x264. Maar ik (en wie niet?) wil natuurlijk graag 4K kijken. Moet ik iets inladen op mijn Plex server welke deze content 'schoon' kan afspelen zonder dat het mijn server flink belast?
NAS Synology DS920+ 12GB of ram met latest Plex server
[ Voor 6% gewijzigd door Yzord op 12-07-2021 15:39 ]
De Grote Yzord Mancave Sale
Beste antwoord (via Yzord op 12-07-2021 18:06)
  • psy
  • Laatst online: 15:40
psy
Een van de eerste Google hits:
https://nascompares.com/2...20-ds220-ds720-and-ds420/
One of the most popular reasons that many users invest in a compact desktop Synology NAS solution is for use as a private Plex media server. The appeal of Plex as an alternative to paid subscription streaming services like Netflix and Amazon Prime video is fairly evident, giving you the ability to watch all of your lovely movies and box sets, but still enjoy the slick graphical user interface and background polish (such as trailers, reviews descriptions, thumbnails, watchlists, recommendations and artwork) afforded to those online streaming platforms. The new generation of Synology diskstation NAS’ that arrived in summer 2020 (DS920+, DS220+, DS420+ and DS720+) are all solid solutions for use as a Plex media server NAS, however lately many users have identified a recurring playback problem on these recent Intel Celeron powered NAS’. Namely, the fact that they seem to be having difficulty playing H.265 (also known as HEVC) in even rather simple files even as low as 480p and 720p, despite the fact that the CPU and memory are not what being hit very hard. This is a playback issue that is not apparent in the Synology Video Station app (happily playing and converting these files without issue). So, what gives? I am pleased to confirm though that it CAN BE SOLVED! Just follow the guide below, spare 5 minutes to go through the steps and you will be able to play those pesky H.265 / HEVC files, even at 8bit and 10bit.
  • Greveldinges
  • Laatst online: 10:39
Greveldinges
Thank you, thank you very much
Ondersteunt je GPU misschien geen x265? Het lijkt er op dat x264 via hardware decoding wordt afgespeeld en x265 via software decoding.
  • Greatsword
Dat is juiste de overweging die je maakt.
265 zijn kleinere bestanden maar vragen meer rekenkracht.
En als dit raakvlak heeft met je Synology NAS dan is 265 sowieso een No Go omdat de CPU dit simpelweg niet trekt.
Gewoon goed zoeken en filteren op 264, die zijn er ook in 4K.
  • Yzord
Yzord
Greatsword schreef op maandag 12 juli 2021 @ 15:41:
Dat vind ik best raar want de meeste 2160p x265 video's zijn juist veel groter. Ik neem aan dat mijn NAS zoiets eigenlijk aan zou moeten kunnen toch? Het is een vrij recente NAS met zeker geen misselijke hardware eigenlijk.
@Greveldinges mijn NAS heeft geen GPU en de Plex client is mijn Philips OLED tv.
  • Beste antwoord ✓
  • psy
psy
  • Yzord
Yzord
psy schreef op maandag 12 juli 2021 @ 15:49:
Allereerst mijn dank voor je reply. Dit zou voor mij een oplossing kunnen zijn. Ware dat ik blijf steken op stap 5. Ik open de File Station en dan zou, volgens deze howto er een PLEX folder aanwezig moeten zijn. Maar dat heb ik dus niet in DSM7.
Afbeeldingslocatie: https://i.postimg.cc/7h6SwSdn/Screenshot-2021-07-12-at-16-42-11.png
En hoe ik kan zoeken in de root van de NAS is mij even een raadsel op dit moment :?
Dus ik ben een beetje stuck nu haha. Ik zou ssh aan kunnen zetten natuurlijk en dan een find kunnen doen, maar waarom ik sowieso geen plex folder zie in mijn File Station is wel heel apart, toch?
Uiteindelijk de file geedit in Vi. Eens zien of het werkt :)
En het werkt :)
  • psy
psy
Top 👍🏻
  • Yzord
Yzord
@Verwijderd sorry, zie nu ineens dat je eenzelfde link had toegestuurd.
  • soedesh
  • Laatst online: 18-09 19:09
Kan je aangeven met welke apparatuur je afpeelt? Niet de Synology lijkt mij, want die heeft geen video uitgang neem ik aan.
SWITCHES=/F DEVICE=HIMEM.SYS /TESTMEM:OFF
  • Yzord
Yzord
soedesh schreef op woensdag 14 juli 2021 @ 07:09:
Mijn setup is Synology DS920+ en Philips 65OLED855
  • soedesh
Yzord schreef op woensdag 14 juli 2021 @ 11:19:
Aha, je gebruikt dus een SmartTV als afpeelapparaat/client en de Synology als media server?
Het hoge CPU gebruik vindt dus plaats op de server. Dat is dan idd een Synology probleem wat eigenlijk niet in de client software rubriek past.
[ Voor 12% gewijzigd door soedesh op 14-07-2021 22:35 ]
  • Yzord
Yzord
soedesh schreef op woensdag 14 juli 2021 @ 22:30:
Met de oplossing in dit topic heb ik daar geen problemen meer mee. Er wordt niet meer geconverteerd.
  • Vis079
  • Laatst online: 03-11 15:52
Yzord, vaak als je die "Plex" map niet ziet komt het door een installatie van Plex.
Die haalt soms de rechten van de map af.
Even in DSM jezelf weer rechten geven aan de Plex folder.
Op die genoemde site plaatsen ze VaapiDriver=”i965″ /> aan het einde erbij.
Bij mij moetst dat VaapiDriver="i965" /> zijn de ”i965″ had de verkeerde aanhalingstekens.
  • Yzord
Yzord
Vis079 schreef op maandag 19 juli 2021 @ 07:26:
Klopt, die aanhalingstekens heb ik ook moeten veranderen. En vraagje, hoe geef ik mijzelf weer rechten aan de Plex folder in DSM? Ik heb de file nu geedit in vi via ssh, maar heb ook het liefst dat ik het via een text editor on screen kan doen :)
  • CH4OS
CH4OS
It's a kind of magic
De 265 content is zwaarder ivm de compressie, maar met de juiste filters (LAV Filters* raad ik altijd aan boven welk codec pack dan ook) kun je het redelijk gemakkelijk altijd hardwarematig laten afspelen op elke moderne client. Wel in Plex even de kwaliteitsinstellingen op maximaal zetten wanneer het over LAN verbindt en you're good to go.
* Op een desktop systeem gemakkelijk te installeren, mobile clients is wat minder, maar die hebben meestal zelf al codecs op basis van de LAV filters aan boord.
  • Vis079
Yzord schreef op maandag 19 juli 2021 @ 09:43:
Control Panel > Shared Folder > Selecteer "Plex" > Edit > Tab "Permissions" > En dan jezelf op Read/Write > OK
Tevens kun je natuurlijk ook je Group Permissions aanpassen :)
Merk dat bij installatie van nieuwere plex versies deze rechten wel weer eens op Default gaan, en dan ontneemt hij normale users de rechten.
  • Yzord
Yzord
Vis079 schreef op maandag 19 juli 2021 @ 11:07:
Zoals ik al aangaf, ik heb die folders helemaal niet in mijn explorer staan :(
Afbeeldingslocatie: https://i.postimg.cc/FzWHGmby/Screenshot-2021-07-19-at-11-13-14.png
