Proxmox bluetooth op mijn NUC
  • mn_box
  • Laatst online: 15-12-2023
Allen,
Ik draai inmiddels enig tijd op mijn NUC Proxmos met verschillende VMs. Belangrijkste is voor Home Assistant. Eigenlijk allemaal goed behalve bluetooth. Ik ben geen linux expert, en ken de basis maar heb jullie hulp nodig om bluetooth aan de praat te krijgen (en door te sturen naar mijn HA VM). Bluetooth op de host heb ik niet nodig.
Hierbij wat achtergrond: Proxmox 6.4.4
apt iinstall luetooth
apt install bluez
root@pve:/lib/firmware/intel# ls -l
total 1808
-rw-r--r-- 1 root root 18 Feb 23 14:30 ibt-11-5.ddc
-rw-r--r-- 1 root root 588196 Feb 23 14:30 ibt-11-5.sfi
-rw-r--r-- 1 root root 14 Feb 23 14:30 ibt-12-16.ddc
-rw-r--r-- 1 root root 585744 Feb 23 14:30 ibt-12-16.sfi
-rwxr-xr-x 1 root root 14 May 31 22:41 ibt-17-16-1.ddc
-rwxr-xr-x 1 root root 653852 May 31 22:41 ibt-17-16-1.sfi
dmesg | grep -i blue
[ 4.266598] Bluetooth: Core ver 2.22
[ 4.266617] Bluetooth: HCI device and connection manager initialized
[ 4.266620] Bluetooth: HCI socket layer initialized
[ 4.266622] Bluetooth: L2CAP socket layer initialized
[ 4.266624] Bluetooth: SCO socket layer initialized
[ 4.277848] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[535194.871978] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[535196.238649] Bluetooth: hci0: urb 00000000e3691b0a failed to resubmit (2)
[1107074.859874] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1107076.232433] Bluetooth: hci0: urb 0000000065cddfc2 failed to resubmit (2)
[1107968.717382] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1107970.122375] Bluetooth: hci0: urb 00000000142f67c0 failed to resubmit (2)
[1109084.932892] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1109086.311258] Bluetooth: hci0: urb 000000006897703c failed to resubmit (2)
[1110013.586516] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1110014.971605] Bluetooth: hci0: urb 0000000086195a60 failed to resubmit (2)
[1112940.454157] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1112942.026207] Bluetooth: hci0: urb 00000000a249e5bb failed to resubmit (2)
[1113693.901842] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1113695.284402] Bluetooth: hci0: urb 00000000365a5ada failed to resubmit (2)
[1486742.576231] Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
[1486743.969246] Bluetooth: hci0: urb 000000000bbe6ba8 failed to resubmit (2)
[3205760.341635] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[3205760.341636] Bluetooth: BNEP filters: protocol multicast
[3205760.341639] Bluetooth: BNEP socket layer initialized
bluetoothctl
show on: No default controller available
Het lijkt eigenlijk al mis te gaan bij hci. Iemand die mij hierbij in de goede richting ken helpen?
Bedankt
Beste antwoord (via mn_box op 13-07-2021 23:44)
  • spone
Als het een HCI is dan zit ie als het goed is op de PCI bus? Kan je dan niet het hele PCI device doorzetten naar je VM?
Dit is een block diagram van jouw NUC en daar zie ik dat de intel wireless op PCIe x1 en USB 2.0 zit. Gok PCIe voor de wifi, USB 2.0 voor de bluetooth.
Afbeeldingslocatie: https://tweakers.net/i/tZN4SE6vi-vxK788_Zn1xt8frdM=/800x/filters:strip_exif()/f/image/z1sCAJomEmKp0pOySh5ha8Cx.png?f=fotoalbum_large
[ Voor 67% gewijzigd door spone op 11-07-2021 22:27 ]
Game: 7800X3D, 32GB DDR5-6000, RTX 5070 Ti; Laptop: MacBook Pro M1 Pro 14" 16/512; Server: R9-7950X, 96GB DDR5-5600; Woonkamer: Mac Mini M4 16/256
  • Lethalis
Wat voor generatie NUC is het?
Ask yourself if you are happy and then you cease to be.
  • Hero of Time
  • Laatst online: 18-10 21:48
Hero of Time
Moderator LNX
There is only one Legend
Waarom installeer je software voor bluetooth op je Proxmox omgeving? Je zegt dat je daar helemaal geen bluetooth nodig hebt.
Het is ook belangrijk hoe je HomeAssistent precies draait. Je hebt het over VMs, maar HA kan je ook via een docker container draaien. Proxmox kan dat ook vziw. Afhankelijk van hoe je HA draait, zal je iets anders moeten doen. Maar als het echt een VM is via KVM, is het kinderlijk eenvoudig je bluetooth erheen te brengen. Je hoeft alleen maar het USB apparaat naar de VM te sturen.
Kom dus nog even met wat meer informatie over je omgeving en wat je al hebt gedaan en welke bronnen je hebt geraadpleegd om te doen wat je wilt bereiken. Want al het onderzoek en eigen inzet ontbreekt momenteel.
Commandline FTW
  • mn_box
HA draait als VM op mijn proxmox. Ik wil de bluetooth van mijn NUC gebruiken en dit is geen USB device (anders zou het eenvoudiger zijn).
Het betreft de NUC7i5BNK.
Ik heb het proxmos forum redelijk afgestruind een kwam o.a. het volgende tegen:
https://forum.proxmox.com...ut-working-on-host.50561/
https://forum.proxmox.com...462-wireless.42427/page-2
https://forum.proxmox.com...vieren.83863/#post-368840
https://community.home-assistant.io/t/bluetooth-on-nuc/51624
Meer mensen lijken op zoek te zijn naar een oplossing. Als het helpt om meer details te delen hoor ik het graag.
Dank voor het meedenken!
  • Beste antwoord ✓
  • spone
  • mn_box
Oke, dit helpt inderdaad! Mijn bedoeling was om het eerst werkend te krijgen in Proxmox voordat ik het doorzet naar een VM (dit om issues uit te sluiten). Ik zou idd de hele PCI kunnen doorzetten, alleen dat wil ook nog niet lukken (zie plaatje).
Ik heb inmiddels bestand /etc/defult/grub met
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
omgezet naar:
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_iommu=on"
zonder succes (incl. upgrade-grub en reboot).
Afbeeldingslocatie: https://tweakers.net/i/fzvTWFhYEIP-2IPe8TPszZ9xuWE=/800x/filters:strip_exif()/f/image/CBOUk827F7HBkFtDkMhzLpvP.png?f=fotoalbum_large
Edit: okay ik ben weer een stukje verder; welke device uit deze lijst zou ik moeten doorzetten? 00.14.0?
Afbeeldingslocatie: https://tweakers.net/i/cbk2uHMElCegojJM7lWGIowigxc=/800x/filters:strip_exif()/f/image/Hs2l30GcyDnuhwQg2OFyNgtd.png?f=fotoalbum_large
Edit2: PCI passthrough werkt nu, dank voor het meedenken!
[ Voor 23% gewijzigd door mn_box op 12-07-2021 21:40 ]
  • Hero of Time
Hero of Time
Moderator LNX
Maar met PCI passthrough stuur je dus je wifi kaart naar de VM, niet het bluetooth gedeelte. Dat zit op een USB 'poort'. Een complete USB bus naar een VM sturen is wat overkill en weet ook niet zeker of dat consequenties heeft voor de host. In je 'lspci' uitvoer zie je ook alleen de wireless controller, niet de bluetooth adapter.
Ik heb op m'n werklaptop via KVM en Virt-Manager zonder problemen m'n bluetooth adapter, dat onderdeel is van de Intel AX200 kaart, naar een VM kunnen sturen via de USB redirect functionaliteit. En op m'n pc thuis heb ik direct de usb apparaten voor een tweede toetsenbord en muis naar de VM gestuurd zonder de USB redirect van virt-viewer/SPICE.
Dus wat heb je nou werkelijk naar je VM gestuurd? De bluetooth adapter of de hele USB bus waar die adapter eigenlijk op aangesloten is (met als potentieel gevolg dat je een fysieke USB poort niet kan gebruiken omdat die ook in de VM zit)?
Voor het idee, dit stukje XML is bij mij verantwoordelijk om een toetsenbord (of muis) naar de VM te sturen:
XML:
<hostdev mode="subsystem" type="usb" managed="yes">
  <source>
    <vendor id="0x1532"/>
    <product id="0x0109"/>
  </source>
  <address type="usb" bus="0" port="1"/>
</hostdev>
Commandline FTW
  • mn_box
Ik heb momenteel de hele USB bus doorgestuurd, ook niet helemaal happy mee maar het werkt. Ik ga je suggestie even verder bekijken, maar via de usb route kwam ik er dus niet uit. Bedankt voor het meedenken!
  • MsG
  • Laatst online: 18-10 21:16
MsG
Forumzwerver
mn_box schreef op dinsdag 13 juli 2021 @ 23:44:
@mn_box Is het jou uiteindelijk nog gelukt?
  • mn_box
Ja, de hele USB bus werkt prima, maar dus nu wel beperkte mogelijkheden van mijn andere VMs.
  • MsG
MsG
Forumzwerver
mn_box schreef op maandag 13 september 2021 @ 15:32:
Hoe heb je het uiteindelijk ingesteld? Dat was een beetje de eigenlijke vraag ;-).
Gewoon die hele PCI-e interface doorsturen, of toch wel gewoon een usb-poort vanuit de host?
  • mn_box
Hele PCI bus doorzetten
Afbeeldingslocatie: https://tweakers.net/i/kRKZmZHtN_xhBPLqqYoAl8Oygtg=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/5sDBRIaGttGBorpjcnuBiHLy.png?f=user_large
  • Stampre
  • Laatst online: 28-06 21:37
Hoe heb jij dat met IOMMU gedaan? Mijn VM start namelijk niet omdat IOMMU niet beschikbaar is.
http://specs.tweak.to/6635
  • UTMachine
  • Laatst online: 12:51
  • Stampre
Die heb ik ook gezien, echter dan is je VM niet meer migreerbaar. Iets dat je wel wil mijns inziens.
  • UTMachine
Stampre schreef op zaterdag 20 augustus 2022 @ 23:01:
Je doet een pass-through van hardware. Dus volledig logisch dat je niet meer kan migreren.
  • Stampre
UTMachine schreef op zondag 21 augustus 2022 @ 07:47:
Dan is toch het hele idee van een VM weg. Maw dan is het geen oplossing.
  • UTMachine
Stampre schreef op zondag 21 augustus 2022 @ 22:43:
Ik denk dat je de voordelen van VMs dan niet volledig begrijpt. Doordat je VMs gebruikt kan je dan nog steeds het volgende:
  • VM kan zijn eigen OS en afhankelijkheden gebruiken
  • Meerdere VMs draaien op 1 fysieke machine
  • Makkelijk backup en restore op dezelfde of andere fysieke machine
  • Verplaatsen van VM naar andere fysieke machine, MAAR als je pass-through gebruikt, moet de VM uit staan (mogelijk moet je je de hardware eigenschappen aanpassen van je VM)
Maar live-migration problemen had je ook al, als je een cluster bouwde met verschillende CPU merken/types/generaties.
  • Hero of Time
Hero of Time
Moderator LNX
En wat als je speciale software moet draaien dat alleen met een ouder OS werkt wat niet geschikt is voor je fysieke hardware waar het op zou moeten draaien? Super duur pakket, nog duurder stuk hardware en omdat je oude hardware stuk is en niet meer te verkrijgen is, moet de hele investering maar op de schop?
Nee, virtualisatie is voor veel zaken nog een prima oplossing. Je moet alleen goed nadenken over je opzet, configuratie en de mogelijkheden danwel beperkingen die er mee gepaard gaan. Zodra je ook maar iets van passthrough doet, is live migration direct van de tafel. Als je fysiek draait en het moet naar een ander stuk hardware heb je exact hetzelfde, je moet dan ook de hardware uit de oude machine halen en in de nieuwe steken. Is dat dan ook geen oplossing?
Als je bagage meeneemt in een aanhanger en 1 koffer ligt in de kofferbak, moet je bij het wisselen van auto ook nog die ene koffer uit de kofferbak halen ipv alleen maar de aanhanger omhangen. Of zou jij je gezin in de kapotte auto achter laten terwijl je met vervangend vervoer met de aanhanger wegrijdt? :+
Commandline FTW
  • Stampre
Sorry mensen dan heb ik het inderdaad niet goed begrepen. Ik was in de veronderstelling dat je helemaal niet meer kon migreren. Ik dacht dat als ik mijn NUC omwissel vloor een nieuwe ik van scratch af aan moest beginnen. Ik begrijp nu dat dat niet hoeft maar het niet live kan danwel er even iets niet werkt. Dat is uiteraard geen probleem. Tnx voor de toelichting!
  • UTMachine
Stampre schreef op maandag 22 augustus 2022 @ 23:41:
Nee, je kan nog steeds backup/restore gebruiken om te VM te verplaatsen. Live-migratie is alleen relevant als je een Proxmox cluster bouwt, alleen daar moet je wel hard over nadenken of de voordelen afwegen tegen de nadelen.
Ikzelf draai geen cluster, want je hebt normaliter 3 nodes nodig (om een quorum te hebben, moet een oneven nummer zijn). Ook wil je een cluster file-systeem hebben zoals Ceph (kan zonder, maar als je het doet - moet je het ook goed doen).
Daarom draai ik 1 NUC en maak dagelijkse backups naar een Pi Zero2, en als de eerste NUC uitfikt, dan restore ik die backup naar mijn andere NUC (daarom staat wel Proxmox, zonder VMs) en USB kabels overpluggen en gaan met die banaan. Clustering had voor mij meer nadelen dan voordelen (3 NUCs aan en een Ceph levert meer onderhoud/design op).
  • treshed
  • Laatst online: 12-06 23:11
Met het lsusb in de proxmox shell kan je gemakkelijk achterhalen waar de Bluetooth USB aansluiting zit:
Bus 001 Device 002: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Als je daarna het USB device/Vendor ID (hier 8087) aan de VM koppelt, wordt deze direct gedetecteerd door HomeAssistant
  • BarryS
  • Laatst online: 18-10 18:15
treshed schreef op zondag 25 december 2022 @ 11:00:
Ik heb dit geprobeerd. Echter vind mijn home assistant niet de bluetooth adapter.
Ik denk dat er in Proxmox iets niet goed gaat. grep Bluetooth geeft bij mij het volgende:
root@pve:~# dmesg | grep Bluetooth
[ 3.883834] Bluetooth: Core ver 2.22
[ 3.884258] Bluetooth: HCI device and connection manager initialized
[ 3.884261] Bluetooth: HCI socket layer initialized
[ 3.884265] Bluetooth: L2CAP socket layer initialized
[ 3.884270] Bluetooth: SCO socket layer initialized
[ 5.925062] Bluetooth: hci0: command 0xfc05 tx timeout
[ 5.925095] Bluetooth: hci0: Reading Intel version command failed (-110)
root@pve:~#
lijkt wel alsof de bluetooth disabled is of zo.
AMD Ryzen 7 9800X3D - Corsair Vengeance 64 GB DDR5 @ 6000 MHz C36 - ASUS ROG Strix B650E-F - Gigabyte GeForce RTX 5090 Gaming OC - Samsung 990 Pro 2TB, 980 Pro 2TB, 970 EVO Plus 2TB - Corsair Nautilus 360 RS ARGB, Cooler Master MWE Gold 1250 V2 ATX 3.1
  • deHakkelaar
  • Registratie: Februari 2015
  • Laatst online: 27-07-2024
Meestal als je passthrough toepast, dan moet je wel zorgen dat de Proxmox VMM/hypervisor host zelf al niet de driver/kernel module laad voor het desbetreffende stukje HW:
https://wiki.debian.org/KernelModuleBlacklisting
EDIT:
$ man modprobe.d
       blacklist modulename
           Modules can contain their own aliases: usually these are aliases
           describing the devices they support, such as "pci:123...". These
           "internal" aliases can be overridden by normal "alias" keywords,
           but there are cases where two or more modules both support the same
           devices, or a module invalidly claims to support a device that it
           does not: the blacklist keyword indicates that all of that
           particular module's internal aliases are to be ignored.
[ Voor 59% gewijzigd door deHakkelaar op 30-03-2023 21:58 ]
There are only 10 types of people in the world: those who understand binary, and those who don't
