Bootable USB windows does not work, but linux does
  • WingGraph
  • Laatst online: 21-10-2023
My computer does not boot into windows anymore after an update (i thought)
It just shows a black screen after the windows logo.
So i tried using a windows bootable USB to restore it, but it does not boot.
It's the same it shows the windows logo and then goes to a black screen.
I tested the bootle USB and it works on other computers.
Then i went and installed linux on a USB drive and tried it and that works like a charm
It boots into linux, I can see my harddrive and my files.
So at least I have my data.
But i also want windows to work on this machine....
Any ideas?
Computer is an Asus sonic master premium
  • 99ruud99
  • Laatst online: 23-10 12:45
Could you please post the specs / a link to the specs?
Did you already try to reinstall a fresh version of windows?
Did you try to update the GPU drivers?
  • PD2JK
  • Laatst online: 18:41
PD2JK
ouwe meuk is leuk
How did you create the USB drive, with the Media Creation Tool I presume? :)
You sure it is booting from the thumbdrive, i.e. does the thumbdrive have a LED wich flashes while loading the setup files?
You could also do a memory (RAM) test with Memtest86+ to make sure that's ok.
Toen waren beige computers heel gewoon.
  • deagan1337
  • Laatst online: 05-10 13:09
Try to boot into safe mode ( keep pressing F8 during boot / just before windows start ). If you can, try to run 'netplwiz' in start > run and check if you can (recreate) a user there.
  • tdn135
Wat is de reden dat je dit in het Engels post, terwijl je historie in het Nederlands is en dit een Nederlands forum is? Just wondering ;)
  • WingGraph
@deagan1337
Ik geraak niet in safe mode (F8) lijkt niet te werken volgens verschillende fora in de laatste updates van w10.....
Vandaar dat ik met een bootable USB aan het proberen ben
  • WingGraph
@PD2JK
Ja met Rufus , de bootable USB werkt op een andere computer en geraak ermee zonder issues in de Windows installer
  • WingGraph
@99ruud99
Windows opnieuw installeren lukt niet. Ik geraak niet in de installer van Windows...
  • WingGraph
@tdn135 sorry, force of habit...
Zal in het Nederlands verdegaan 😉
  • PD2JK
PD2JK
ouwe meuk is leuk
Probeer die stick toch eens te maken met het tooltje van MS. Misschien gaat er wat mis bij Rufus; partitie / MBR / UEFI of iets in die geest...
  • brambo123
  • Laatst online: 23-10 08:23
Rufus is heel wat anders als Media Creation Tool
Juiste tool kun je hier downloaden (de knop "Hulpprogramma nu downloaden"):
https://www.microsoft.com/nl-nl/software-download/windows10
  • The_Doman
WingGraph schreef op zondag 23 mei 2021 @ 08:46:
@PD2JK
Waarschijnlijk dan BIOS/UEFI verschil in instellingen op de computers.
Rufus Dual BIOSUEFI cheat mode
  • WingGraph
@brambo123 @PD2JK
Geprobeerd met de officiële MS tool.
Ik zie het Windows logo en de dotted waiting circle onde het Windows logo, maar verder gaat hij niet.....
Het enige verschil dat ik hier zie met de Rufus is dat die van Rufus na dit scherm naar een zwart scherm ging en deze blijft gewoon op het logo scherm staan (de puntjes bewegen wel nog altijd, dus hij is niet vast gelopen).....
  • Question Mark
  • Laatst online: 17:03
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
WingGraph schreef op zondag 23 mei 2021 @ 08:51:
Pas je topicstart dan meteen even aan. Het is een Nederlandstalig forum.
  • The_Doman
Probleem met de disk?
Test eens of je wel kan booten zonder aangesloten HDD/SSD of andere extra rand-apparatuur.
  • WingGraph
@The_Doman
Booten naar een Linux USB kan ik perfect
En dan kan ik zelfs de files openen op de SSD...
Alleen Windows booten likt niet.
Als ik de Windows op de SSD wil booten dan gaat hij in recovery mode maar ook hier krijg ik na een tijdje gewoon een zwart scherm...
De pc is zo een all in one scherm waar ik niet direct vijzen zie aan de achterkant, dus moeilijk om hem open te doen zonder enige zichtbare schade vrees ik.
Daarom dacht ik te booten van een Windows USB en zo een system Restore te doen.
Of in het slechtste geval booten in Linux files kopiëren op een externe disk en dan Windows opnieuw installeren.
Alleen krijg ik ook niet de Windows install USB geboot...
Alleen een Linux USB. Echt vreemd
  • The_Doman
WingGraph schreef op zondag 23 mei 2021 @ 21:38:
@The_Doman
OK, dat maakt het een stuk lastiger natuurlijk.
Welke AIO is het dan precies?
Dan maar met Linux of WINPE eens HDD diagnose/test doen?.
Hiren’s BootCD PE, Sergei Strelec WinPE
Eventueel nog image backup maken en HDD wissen?
  • TheVMaster
  • Laatst online: 18:07
TheVMaster
Moderator WOS
WingGraph schreef op Sunday 23 May 2021 @ 07:48:
Any ideas?
Is het heel raar dat ik me afvraag waarom je dit topic in het Engels begint. Vervolgens reageer je verderop wel in het Nederlands. Dus mijn verzoek om het vervolgens bij het Nederlands te houden :-)
Mijn Apps: DiscVault - MealieShopper - SintMaarten
