Krijg port-forwaring op EdgeRouter 4X niet werkend...
  • t013463
  • Laatst online: 21-09 15:20
Mijn vraag
Ik heb een EdgeRouter 4X en ik krijg port-forwarding niet werkend.
Nu ben ik ook nog in het buitenland en kan ik alleen via de CLI bij m'n EdgeRouter.
Dit is mijn portforward config:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
auto-firewall enable
 hairpin-nat enable
 lan-interface switch0.1
 rule 1 {
     description Syno-DSM_https
     forward-to {
         address 192.168.1.5
         port 5001
     original-port 5001
     protocol tcp
 rule 2 {
     forward-to {
         address 192.168.1.5
         port 5000
     original-port 5000
     protocol tcp
 rule 3 {
     description Syno-Backup
     forward-to {
         address 192.168.1.5
         port 6281
     original-port 6281
     protocol tcp
 rule 4 {
     description Syno-Drive
     forward-to {
         address 192.168.1.5
         port 6690
  rule 5 {
     description bitwarden
     forward-to {
         address 192.168.1.5
         port 5554
     original-port 5554
     protocol tcp
 rule 6 {
     description OPENVPN_TO_SYNO
     forward-to {
         address 192.168.1.5
         port 1194
     original-port 1194
     protocol udp
 wan-interface eth5
Mijn interface configuratie zit er zo uit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
ethernet eth0 {
     description "LAN - To Managed Switch"
     duplex auto
     poe {
         output off
     speed auto
 ethernet eth1 {
     description "LAN - eth1 (empty)"
     disable
     duplex auto
     poe {
         output off
     speed auto
 ethernet eth2 {
     description "LAN - eth2 (empty)"
     disable
     duplex auto
     poe {
         output off
     speed auto
 ethernet eth3 {
     description "IPTV - Master Bedroom"
     duplex auto
     poe {
         output off
     speed auto
 ethernet eth4 {
     description "IPTV - Living Room"
     duplex auto
     poe {
         output off
     speed auto
 ethernet eth5 {
     description "WAN - Fiber"
     duplex auto
     speed auto
 loopback lo {
 switch switch0 {
     description Switch
     mtu 1500
     switch-port {
         interface eth0 {
             vlan {
                 pvid 1
         interface eth1 {
             vlan {
                 pvid 1
         interface eth2 {
             vlan {
                 pvid 1
         interface eth3 {
             vlan {
                 pvid 640
         interface eth4 {
             vlan {
                 pvid 640
         interface eth5 {
             vlan {
                 vid 640
                 vid 300
         vlan-aware enable
     vif 1 {
         address 192.168.1.1/24
         description "Switch - VLAN - Local"
     vif 300 {
         address dhcp
         description "Switch - VLAN - Internet"
         firewall {
             in {
                 name WAN_IN
             local {
                 name WAN_LOCAL
         mtu 1500
     vif 640 {
         description "Switch - VLAN - IPTV"
         mtu 1500
Heeft iemand een idee waarom ik niet vanaf buiten bij de bovenstaande port-forward poorten kan?
Beste antwoord (via t013463 op 04-05-2021 21:10)
  • ElCondor
  • Laatst online: 29-10 11:16
ElCondor
Geluk is Onmisbaar
Ik kan het helemaal mis hebben want ik heb geen EdgeRouter, maar je Lan wijst naar Switch0.1, is dat niet Eth1 op de Switch? Moet het niet Switch0.0 zijn om te verwijzen naar Eth0 waar jouw LAN kabel in zit.
Nogmaals, ik heb geen ervaring met de syntax van EdgeRouters, maar meestal zijn die dingen zero-based.
Hay 365 dias en un año y 366 occasiones para festejar (Boliviaans spreekwoord)
  • Beste antwoord ✓
  • ElCondor
ElCondor
Geluk is Onmisbaar
  • t013463
ElCondor schreef op dinsdag 4 mei 2021 @ 19:57:
Dit was inderdaad het probleem. Toen ik het volgende commando via de CLI gaf, werkte het weer!
configure
set port-forward wan-internet switch0.300
commit
save
