[redhat71] MOD_PERL compileren...
  • DPLuS
Wat gaat hier fout?
Kan dat kwaad??
29
Will run tests as User: 'nobody' Group: 'root'
Checking CGI.pm VERSION..........ok
Checking for LWP::UserAgent......failed
Can't locate LWP/UserAgent.pm in @INC (@INC contains: ./lib /usr/lib/perl5/5.6.0/i386-linux /usr/lib/perl5/5.6.0 /usr/lib/perl5/site_perl/5.6.0/i386-linux /usr/lib/perl5/site_perl/5.6.0 /usr/lib/perl5/site_perl .) at Makefile.PL line 1136.
The libwww-perl library is needed to run the test suite.
Installation of this library is recommended, but not required.
Checking for HTML::HeadParser....failed
Can't locate HTML/HeadParser.pm in @INC (@INC contains: ./lib /usr/lib/perl5/5.6.0/i386-linux /usr/lib/perl5/5.6.0 /usr/lib/perl5/site_perl/5.6.0/i386-linux /usr/lib/perl5/site_perl/5.6.0 /usr/lib/perl5/site_perl .) at Makefile.PL line 1154.
The HTML-Parser package is needed (by libwww-perl) to run the test suite.
Checking if your kit is complete...
Looks good
Writing Makefile for Apache
Writing Makefile for Apache::Connection
Writing Makefile for Apache::Constants
Writing Makefile for Apache::File
Writing Makefile for Apache::Leak
Writing Makefile for Apache::Log
Writing Makefile for Apache::ModuleConfig
Writing Makefile for Apache::PerlRunXS
Writing Makefile for Apache::Server
Writing Makefile for Apache::Symbol
Writing Makefile for Apache::Table
Writing Makefile for Apache::URI
Writing Makefile for Apache::Util
Writing Makefile for mod_perl
[root@bigtower mod_perl-1.26]#
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Hij kan libwww-perl niet vinden, en die is nodig om een aantal tests te runnen. Niets om je zorgen over te maken.
Wil je echter dat ie wel tests draait, moet je even 'perl -MCPAN -e 'install libwww' en 'perl -MCPAN -e 'install HTML::HeadParser' typen.
