• Helvetios
  • Registratie: Augustus 2019
  • Laatst online: 09-11 08:13
Hi everyone,
First of all, sorry for typing in English but Dutch is not my first language and it is very difficult for me to get the terminology below right. Thank you for the understanding!
Last night I took my liquid cooling for regular 6th month cleaning cycle. To my surprise I found galvanic corrosion in the EK FC Vega block that is nickel plated copper. The loop is made entirely of EK components, therefore I cannot understand why there is corrosion. There are no aluminium parts as far as I can see:
- Fittings - Brass nickel plated
- CPU block - Acetal and copper nickel plated
- GPU block - Acrylic and copper nickel plated
- Radiators - Brass chambers and copper flow channels/fins
- Tubing - EPDM rubber
As coolant I always used the same EK Cryofuel Premix without adding more additives. Interestingly, the place which is discolored does not have running coolant by design. It's a sandwiched area between the block and the acrylic cover. I checked the rest of the the components and I do not see any discoloration in the micro fin stacks of the blocks.
The block was purchased new 1.5 years ago and still has the EK Quality Control sticker intact. Do you think that such damage should be covered by warranty? I do not see if I am doing something wrong since all components are EK and this is probably 5-6 time I am building a loop so maintenance and contamination control were done accordingly.
Afbeeldingslocatie: https://tweakers.net/i/JR4TvQPupwtLi5qcLwsni4bq4yg=/800x/filters:strip_icc():strip_exif()/f/image/oH9bQdma1RAm4gFvJHQswSQU.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/UkEXzImXfSAc-Yyn7xSuLJvyd6M=/x800/filters:strip_icc():strip_exif()/f/image/gUdNEasYyBhz9wSZGKrzzE2e.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/y-podwzhq4bHTFICiXuJekqGVqk=/x800/filters:strip_icc():strip_exif()/f/image/2gZSbimB9tYNxPJqcCt27uuw.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/0uX0wv2WfmlpK48PGJlsbabbRes=/800x/filters:strip_icc():strip_exif()/f/image/ytRVrSxbH5p7WqgDaBddPvwT.jpg?f=fotoalbum_large
On a separate note their stacked tolerances calculation is all over the place. Having designed and machined several water blocks in the past, they should not have a failure mode where gap pads are not compressed. I think the problem boils down the the standardized standoffs that they use in every single EK block. That way the milling waste is less compared to making everything from a single block of metal. There is tolerance of the SMD component, tolerance of the reflow process, tolerance of the standoff, tolerance of the standoff contact surface, tolerance of the thermal contact surface, tolerance of the gap pad. These are all very tiny on their own but on a 1mm thin gap pad that compression ratio variation can be huge! If the complete block was one piece including standoffs it will be more expensive to manufacture, the standoff tolerance and the plinth reference are eliminated completely. Anyway mechanical engineering OCD kicks in...
Afbeeldingslocatie: https://tweakers.net/i/UOeFBGg1-zYwwXKJBRf7GWEabAs=/800x/filters:strip_icc():strip_exif()/f/image/BdBxvCyBAH7oAJpqQsH6IGzf.jpg?f=fotoalbum_large
Your input will be greatly appreciated,
Ivan!
AMD Ryzen 5900x | Nvidia RTX 4090 FE | Ncase M1 | Asus ROG X570-i | G.Skill 2x32GB 3600 | Samsung 980 Pro 2TB | Samsung 970 Evo 1 TB | Corsair SF1000
