GF 3 Ultra ??
  • Gamer
  • Laatst online: 15-08 12:23
Gamer
Electrified
Geforce3 Ultra/Ultra Advanced
-Gpu clock 300Mhz (Ultra and Ultra A only)
-.13 micron design
-Videoboards slighty reworked and using 3.5NS 285Mhz DDR X 2 = 570Mhz DDR (Ultra and Ultra A)
-Higher Ramdac 360 (Ultra and Ultra A)
-Improved 2d RF filters (Ultra and Ultra A)
-128 meg memory as standard (Ultra and Ultra A)
-2 additonal vertex shaders (Ultra and Ultra A)
-Improved AA(Quintex) Max AA of 8x (Ultra and Ultra A)
-Dual head Monitor support on videoboard . (Ultra,Ultra,and MX )
-Tv/Cable Tv/HD tuner (Ultra Advanced only )
-Fm tuner (Ultra Advanced only)
Now Eclispe(Geforce4)
(Rember these are alpha/beta and could change)
-Completely New videoboard design
-Newly designed Copper Gpu .13 micron design with clock of 315Mhz
-3.1NS 322Mhz DDR chips X 2 = 644Mhz DDR
-New ramdac improved chip Ramdac @ 360
-NfiniteFX 2
-Improved Color methods
-B.O.D.E. Body ,Object,Design,envioment .This tells the Gpu if it`s drawing a body ,a object ,designing,or a envioment.
-6 pipes
-512 bit artecture
-5 vertex shaders
-Improved AA(Quintex) Max AA of 10x
-New 128tap Anastropic Filtering .Which the NfiniteFX 2 can do in OpenGL mode without much performance hit .Plus it can do Trilinear filtering at the same time!
http://www.guru3d.com/
bron
Homey Pro | 4600Wp Z - 4800Wp W- 4800Wp O | SH4.0RS | SH5.0RS | SBR192 accu| Zendure 2400AC + 5 AB3000X| Easee Charge Lite | Corsa-e 50kWh | Mercedes EQA 250+ 70kWh
wow... impressive specs :)
is dit informatie die bij Nvidia zelf vandaan komt, of is dit verwacht?
  • Gamer
Gamer
Electrified
mjammie :9 128mb ddr :9~
nu eerst een "gewone" Gforce 3 :)
  • Gamer
Gamer
Electrified
Ok I`m getting more reports from people I know.
Apparently Nvidia is pissed about Ati`s R200.
Hence some Geforce 3 Ultra spec`s have changed.
I have also gotten some info Eclispe due out 2003.
Yup their changing videocard names again.
The revised Geforce 3 has been killed!
There will be a Ultra Advanced.
Which has a tv tuner,catv,dvd play back, and fm tuner built in.
The MX Geforce 3 have 2 pipes not four and reduced clocks
hmmmm...
je hebt gelijk...
enig idee wanneer ie gaat komen, die ultra?
staat er namelijk nergens bij vermeld...
kdenk toch dat ik dan voor de ultra ga 8-)
hmmm en die prijzen wordn net zoals de video kaart VET :(
veel te veel voor een gf 3 1300,- ;(
dikke mik mak en de gf4 zeker 2000,- ;(
ik koop wel een gf 2 300,-
is te minste betaalbaar! :)
geforce 3 heb ik al gezien voor 999 piek erges... De hercules kaart is 1300 piek ofzo, echt dUUr :(
ik weet een ding wel zeker, kmoet nog flink wat uurtjes werken voor dat ding ;)
  • Gamer
Gamer
Electrified
nja, met de komst van dien nieuwe R200 zal dat niet zo lang meer duren denk ik.
Nvidia zal de snelste kaart (en marktleider) willen hebben, dus .....
dat heet "conccurentiestrijd"(leuk scrabblewoord :+ ), dat is voor de tweakers en gamers hier alleen maar interessant
die r200 ziet er ook errug lekker uit...
  • Gamer
Gamer
Electrified
nja, hij schrijft "is vaporware", dus kan zijn dat hij er volledig naast zit ook natuurlijk, maar ik denk het niet.
  • Brahman
  • Laatst online: 24-07 11:53
kweenie hoor,maar een FM tuner op je videokaart????? waar is da goed voor?
verder ziet het er :9~ :9~ :9~ uit
een tv tuner op je videoplankie...
hmmm dat lijkt me alleen maar handig :)
je nieuwe games spelen en tegelijkertijd naar homeshoppingchannel kijken *D op die dualhead technologie die dr op zou zitten :9
nou nog ff kijken hoe duur ie is :)
  • Gamer
Gamer
Electrified
het wordt precies een alles in 1 kaartje :) :)
jah maar zit er ook een 3d bril er bij kep het ding wel mar gebruiken NEE
wat moet je we meer zwaar en het werkt niet eens jha een beetje dan maar kogels om je oren zien vliegen NEE :(
it's gewoon >:) al dat geld af trogelen van on slijkt nintendo wel met pokemon B-)
mar de mzzls ik ga :Z
