Hallo, ik probeer al 1,5 dag mijn openVPN werkend te krijgen.
Ben een heel eind gekomen maar blijf nu hangen bij het volgende:
- Tunnelblick geeft de hele tijd aan: wachten op antwoord van server;
- OpenVPN op mijn iPhone geeft aan: There was an error attempting to connect to the selected server.
OpenVPN draait op mijn Raspberry Pi, met de verbinding wil ik mijn home assistant ook buitenshuis kunnen bekijken/bedienen.
mijn OVPN bestand ziet er als volgt uit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
# Sample client-side OpenVPN 2.0 config file #
# for connecting to multi-client server.     #
# This configuration can be used by multiple #
# clients, however each client should have   #
# its own cert and key files.                #
# On Windows, you might want to rename this  #
# file so it has a .ovpn extension           #
# Specify that we are a client and that we
# will be pulling certain config file directives
# from the server.
client
# Use the same setting as you are using on
# the server.
# On most systems, the VPN will not function
# unless you partially or fully disable
# the firewall for the TUN/TAP interface.
;dev tap
dev tun
# Windows needs the TAP-Win32 adapter name
# from the Network Connections panel
# if you have more than one.  On XP SP2,
# you may need to disable the firewall
# for the TAP adapter.
;dev-node MyTap
# Are we connecting to a TCP or
# UDP server?  Use the same setting as
# on the server.
;proto tcp
proto udp
# The hostname/IP and port of the server.
# You can have multiple remote entries
# to load balance between the servers.
remote "mijn uitgaand ip adres van de server" "mijn gekozen poort"
;remote my-server-2 1194
# Choose a random host from the remote
# list for load-balancing.  Otherwise
# try hosts in the order specified.
;remote-random
# Keep trying indefinitely to resolve the
# host name of the OpenVPN server.  Very useful
# on machines which are not permanently connected
# to the internet such as laptops.
resolv-retry infinite
# Most clients don't need to bind to
# a specific local port number.
nobind
# Downgrade privileges after initialization (non-Windows only)
user nobody
group nogroup
# Try to preserve some state across restarts.
persist-key
persist-tun
# If you are connecting through an
# HTTP proxy to reach the actual OpenVPN
# server, put the proxy server/IP and
# port number here.  See the man page
# if your proxy server requires
# authentication.
;http-proxy-retry # retry on connection failures
;http-proxy [proxy server] [proxy port #]
# Wireless networks often produce a lot
# of duplicate packets.  Set this flag
# to silence duplicate packet warnings.
;mute-replay-warnings
# SSL/TLS parms.
# See the server config file for more
# description.  It's best to use
# a separate .crt/.key file pair
# for each client.  A single ca
# file can be used for all clients.
;ca ca.crt
;cert client.crt
;key client.key
# Verify server certificate by checking that the
# certicate has the correct key usage set.
# This is an important precaution to protect against
# a potential attack discussed here:
#  http://openvpn.net/howto.html#mitm
# To use this feature, you will need to generate
# your server certificates with the keyUsage set to
#   digitalSignature, keyEncipherment
# and the extendedKeyUsage to
#   serverAuth
# EasyRSA can do this for you.
remote-cert-tls server
# If a tls-auth key is used on the server
# then every client must also have the key.
;tls-auth ta.key 1
# Select a cryptographic cipher.
# If the cipher option is used on the server
# then you must also specify it here.
# Note that v2.4 client/server will automatically
# negotiate AES-256-GCM in TLS mode.
# See also the ncp-cipher option in the manpage
cipher AES-256-CBC
# Enable compression on the VPN link.
# Don't enable this unless it is also
# enabled in the server config file.
#comp-lzo
# Set log file verbosity.
verb 3
# Silence repeating messages
;mute 20
<ca>
-----BEGIN CERTIFICATE-----
"De code"
-----END CERTIFICATE-----
</ca>
<cert>
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 2 (0x2)
        Signature Algorithm:
        Issuer: C=NL, ST=xx, L=xx, O=xxx, CN=xxx CA/name=server/emailAddress=xx
        Validity
            Not Before: Jan 18 12:08:50 2021 GMT
            Not After : Jan 16 12:08:50 2031 GMT
        Subject: C=NL, ST=xx, L=xx, O=xxx, CN=client1/name=server/emailAddress=xx
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                RSA Public-Key: (4096 bit)
                Modulus:
                   "De code"
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Basic Constraints:
                CA:FALSE
            Netscape Comment:
                Easy-RSA Generated Certificate
            X509v3 Subject Key Identifier:
                "De key"
            X509v3 Authority Key Identifier:
                keyid:"de key"
                DirName:/C=NL/ST=XX/L=xx/O=xxx/CN=xxx CA/name=server/emailAddress=xx
                serial:"de code"
            X509v3 Extended Key Usage:
                TLS Web Client Authentication
            X509v3 Key Usage:
                Digital Signature
    Signature Algorithm: sha1WithRSAEncryption
        " de code"
" De code"
</cert>
<key>
-----BEGIN PRIVATE KEY-----
" De code
-----END PRIVATE KEY-----
</key>
Daarnaast heb ik op mijn (Sagemcom F5359 van KPN) bij port forwarding het volgende ingevuld:
Service: Other
Protocol: UDP
External host: "Het uitgaande IP adres van mijn router"
External port "Het poort nummer dat ik bovenstaande bestand heb ingevoerd"
Internal host: "Het internet IP adres van mijn raspberry" 192.168.x.x (de x' en natuurlijk ingevuld met de juiste nummers).
Internal port: "dezelfde poort als de external.
Ik heb mijn filewal (UFW) op de raspberry al uitgezet maar hier lag het niet aan.
Kan iemand mij helpen alsjeblieft?
Mijn dank is groot.
[ Voor 0% gewijzigd door rens-br op 19-01-2021 08:38 . Reden: Quote tags toegevoegd ]
  • Frogmen
En als je UDP en TCP forward?
Voor een Tweaker is de weg naar het resultaat net zo belangrijk als het resultaat.
Dit had ik ook geprobeerd (excuus voor het niet vermelden). Maar dit was zonder resultaat.
  • Ben(V)
  • Laatst online: 15:47
Je moet in ieder geval port 1194 voor Udp forwarden naar die pi.
Verder moet je kijken of je OpenVpn client via udp werkt en niet met tcp.
Oké, ik heb alvast verander in mijn router dat de externe poort 1194 is en deze naar door mij gekozen (die ook in de ovpn file staat) interne poort gaat.
In deze file staat ook het volgende:
# on the server.
;proto tcp
proto udp
dit betekend toch dat hij via udp werkt?
Echter heb ik in de router tcp, udp en tcp-ud beide geprobeerd.
  • laurens0619
  • Laatst online: 23:19
Begin eerst eens wat makkelijker
Doe eerst even een tijdelijke port map van 22 en kijk of je vanaf de buitenkant op het wan ip kunt inloggen met ssh, je hoort dan op de pi uit te komen.
Als dit werkt dan weet je dat port mappings werken. Tcp ssh is een stuk makkelijker testen dan udp openvpn
  • Ben(V)
Die pi werkt zo met udp maar je moet er dan ook voor zorgen dat de ovp client waar je vanaf de connectie wilt maken ook udp gebruikt.
