router probleem
als ik freesco draai gata het delen perfect, maar hij gooit het internet eruit.
Als ik dan in de log kijk zie ik dit:
kernel: MASQ: failed TCP/UDP checksum from 212.113.202.50!
Aug 12 16:47:35 - kernel: MASQ: failed TCP/UDP checksum from 213.86.246.40!
Aug 12 16:47:41 - kernel: MASQ: failed TCP/UDP checksum from 213.86.246.40!
Aug 12 16:47:51 - kernel: MASQ: failed TCP/UDP checksum from 212.113.202.50!
Aug 12 16:48:03 - kernel: MASQ: failed TCP/UDP checksum from 212.113.202.50!
Aug 12 16:48:58 - dhcpd: DHCPREQUEST for 192.168.0.2 from 00:00:c0:e5:57:2e via eth0
Aug 12 16:48:58 - dhcpd: DHCPACK on 192.168.0.2 to 00:00:c0:e5:57:2e via eth0
Aug 12 16:49:09 - named[159]: sysquery: findns error (2) on ns1.dn.net?
Aug 12 16:52:24 - pppd[2547]: Hangup (SIGHUP)
Aug 12 16:52:24 - pppd[2547]: Modem hangup
Aug 12 16:52:24 - pppd[2547]: Connection terminated.
Aug 12 16:52:25 - pppd[2547]: Exit.
Aug 12 16:52:25 - diald[283]: Link died on remote end.
Aug 12 16:52:28 - diald[283]: Running connect (pid = 2945).
Aug 12 16:52:29 - connect: Dialing [wanadoo] t4
Aug 12 16:52:29 - (-: chat:  Aug 12 16:52:29 CONNECT
Aug 12 16:52:29 - connect: Chat finished successfully
Aug 12 16:52:29 - diald[283]: Running pppd (pid = 2954).
Aug 12 16:52:29 - diald[2954]: Running pppd: /bin/pppd -detach modem crtscts mtu 1500 mru 1500 noipdefault
Aug 12 16:52:29 - pppd[2954]: pppd 2.3.5 started by root, uid 0
Aug 12 16:52:29 - pppd[2954]: Using interface ppp0
Aug 12 16:52:29 - pppd[2954]: Connect: ppp0 <--> /dev/cua0
Aug 12 16:52:30 - pppd[2954]: Remote message:
Aug 12 16:52:30 - pppd[2954]: local  IP address 212.64.78.213
Aug 12 16:52:30 - pppd[2954]: remote IP address 195.96.98.253
Aug 12 16:52:30 - diald[283]: New addresses: local 212.64.78.213, remote 195.96.98.253.
Aug 12 17:08:24 - named[159]: sysquery: findns error (2) on DNS-02.ICQ.NET?
iemand enig idee wat het is, of hoe ik het kan verhelpen?
B.V.D.
Marc
*schop*
geen ervaring met freesco...
maar ehm het lijkt erop dat tie het modem de verbinding laat verbreken. Maar aan het ip te zien heb je geloof ik kabelinet, kan da?
+het lijkt erop dat tie de dnsserver niet kan vinden, kan misschien een gevolg zijn van de verbroken verbinding.
ja ik heb kabelinternet, en de dns'en staan goed ingesteld
in ieder geval bedankt voor je suggestie
*kick* *schop* *boom*
