[Ervaringen] Starlabs Labtop MK IV (Linux laptop)
  • Daantje20
  • Laatst online: 21-09 06:30
Daantje20
Je moet leven om te leren.
Afbeeldingslocatie: https://tweakers.net/i/T8I7jdJg_-8qSZsvwkJbMIhC3JA=/800x/filters:strip_icc():strip_exif()/f/image/TsK2YUkCASs2sVrgV3JFIiqy.jpg?f=fotoalbum_large
Website fabrikant
https://starlabs.systems/
Van de website een korte samenvatting
Prepare for warp speed. The LabTop has always outperformed competitors in its class. The Star LabTop Mk IV has been forged to uphold its legacy, with processing speeds up to 4.7GHz and data read-speeds up to 3400MB/s. It also improves usability with an Arc display; a matte display that has both a 21% Haze and a hard coat which boasts both durability and glare-free viewing.
Firmware updates lopen via LVFS, dit voor alles firmwares in de laptop, dus ook de NVMe SSD.
Garantie en reserve onderdelen
Open warranty. Laptops designed for open-source software need open warranties. Our 1-year limited warranty allows you to take your laptop apart, replace parts, install an upgrade and use any operating system, all without voiding the warranty.
Regardless of the change, be it a simple SSD upgrade or a display replacement, the only tool you will ever need is a small Phillips screwdriver.
Ondersteunde en geteste Linux distributies
https://starlabs.kb.help/compatibility-reports/
• Ubuntu (alle varianten)
• CentOS
• Deepin
• EndeavourOS
• Fedora
• Kali
• Linux Mint
• MX Linux
• Manjaro
• Parrot OS
• Peppermint
• Qubes OS
• RHEL
• Solus
• Zorin
• Elementary OS
• OpenSUSE
• (Werkt ook met Windows 10, maar niet de bedoeling natuurlijk :P )
De specificaties
• Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz of Intel® Core® i3-10110u CPU
• Intel UHD 620
• 16GB 2400MHz DDR4
• StarDrive NVMe SSD (Phison controller) meerdere opslag hoeveelheden beschikbaar
• 13,3" Full-HD 1920x1080 IPS scherm met ARC (anti reflectie coating)
• Intel Corporation Wireless-AC 9462
• Toetsenbord met backlight
• HDMI
• UCB-C (met power delivery en beeld/video)
• 2x USB-A (3.0)
• DC-aansluiting (ronde aansluiting) kabel apart verkrijgbaar
• 3.5mm koptelefoon aansluiting
• Micro-SD kaart slot
De topic start is mogelijk nog niet helemaal goed of compleet, maar geeft een beeld van de machine en het bedrijf er achter.
  • Daantje20
Daantje20
Uit de zoektocht naar een goede laptop om met Linux te gebruiken ben ik bij Starlabs uitgekomen. Een voor mij onbekende partij uit de UK met een passie voor machines die Linux (misschien later ook BSD's) draaien.
Je krijgt een laptop waarop zo goed als alles Linux distrubuties kunnen draaien, je zit niet vast aan wat ze zelf leveren op de machine. Ook is een enorme lijst aan distributies al getest.
Op dit moment zijn er twee known issues.
- Wifi was heel traag, is al beter maar er is meer ruimte voor verbetering.
- De headphone jack-sense heeft een aanpassing in ALSA instellingen nodig om goed te werken.
De UEFI revisies volgen elkaar snel op, men werkt snel om zaken die spelen op te lossen. Voor Debian/Ubuntu en afgeleiden is er een PPA met wat tools en .deb's die specifieke configuraties voor je doen zodat je niet perse zelf zaken hoeft aan te passen.
