Cache 60 GB op SSD – com.apple.iLifeMediaBrowser.ILPhotosTra
  • ChrisAB
  • Laatst online: 13-10 22:45
Hello,
Ik kwam er achter dat 60GB vol zit in de map:
/Users/*****/Library/Containers/com.apple.ScreenSaver.iLife-Slideshow-Extension/Data/Library
com.apple.iLifeMediaBrowser.ILPhotosTranscodeCache
Dit lijken wel al mijn foto’s en videos van iCloud. Kan dit weggegooid worden of er voor zorgen dat niet meer voller raakt? Iemand ervaring mee?
De ruimte op mijn MacBook Pro 15 inch (256GB) begint beetje vol te raken en weet nu deels waarom;)
Kan ik dit weggooien of uitzetten?
Thanks
  • Harm
I don't think you should have to worry about the disk space being used by this. macOS should be treating that sort of thing as "Purgable", so if you are ever running low on space, macOS would automatically be able to remove that data to give you operational space back. So as far as space you can use on the disk, you should be able to consider the space currently used by that as free.
