Ik weet dat er veel topics over de portmapping van MSN gaan, maar ik heb m'n antwoord niet kunnen vinden
Ik weet dat je via MSN kunt praten, poorten staan hier, bij MS gehaald:
Alvast bedankt
Maar hoe moet ik dit nu op m'n router instellen om dit op meerdere pc's te kunnen.To configure your network for voice communications and file transfer
Note: This is part of the Guide for Network Administrators. It is not intended for end users.
This topic describes the settings that undefined uses for voice communications and file transfer. Perhaps they will be useful to you in configuring your firewall or proxy server.
For voice communications undefined establishes an outgoing TCP connection from port 6901 for all voice communications.
In the case of computer-to-computer communications, the call recipient also uses TCP port 6901.
In the case of computer-to-phone communications, the TCP destination (Net2Phone) port is between 7801 and 7825.
All voice traffic also uses UDP packets. The user's computer sends and receives UDP packets at port 6901.
The Net2Phone service sends and receives UDP packets using ports 6801, 6901, and 2001 to 2120.
For file transfer Both incoming and outgoing TCP connections use this range of ports: 6891 to 6900. This allows up to 10 simultaneous file transfers per sender. If you open only Port 6891, users will be able to do only one file transfer at a time.
The TCP ports need to be configured so that sockets on a port remain open for extended periods of time.
Alvast bedankt
