Dit heeft mijn problemen verholpen:
AGP Program May Hang When Using Page Size Extension on Athlon Processor
The information in this article applies to:
Microsoft Windows 2000 Professional
Microsoft Windows 2000 Server
Microsoft Windows 2000 Advanced Server
IMPORTANT: This article contains information about editing the registry. Before you edit the registry, make sure you understand how to restore it if a problem occurs. For information about how to do this, view the "Restoring the Registry" Help topic in Regedit.exe or the "Restoring a Registry Key" Help topic in Regedt32.exe.
SYMPTOMS
A Windows 2000-based computer may stop responding (hang) when you use an Accelerated Graphics Port (AGP) program such as Ziff Davis 3D WinBench 2000. This behavior may occur more frequently depending on the computer's processor, memory, and graphics configuration. This problem is known to occur with Nvidia GeForce 256 and Matrox G400 video adapters on computers with AMD Athlon processors. This issue is not specific to any specific video adapter type.
CAUSE
Memory that is allocated by the video driver is being corrupted.
RESOLUTION
WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that problems resulting from the incorrect use of Registry Editor can be solved. Use Registry Editor at your own risk.
For information about how to edit the registry, view the "Changing Keys and Values" Help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" Help topics in Regedt32.exe. Note that you should back up the registry before you edit it. If you are running Windows NT or Windows 2000, you should also update your Emergency Repair Disk (ERD).
The following workaround for this issue prevents Memory Manager from using the processor's Page Size Extension feature and may affect the performance of some programs, depending on the paging behavior. This registry value also limits non-paged pool to a maximum of 128 MB instead of 256 MB.
Start Registry Editor (Regedt32.exe).
Locate and click the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
On the Edit menu, click Add Value, and then add the following registry value:
Value Name: LargePageMinimum
Data Type: REG_DWORD
Radix: Hexadecimal
Value: 0xffffffff
Quit Registry Editor.
Restart the computer.
MORE INFORMATION
For additional information, check the frequently asked question (FAQ) pages on the AMD Web site:
http://www.amd.com/support/faqs.html
The third-party contact information included in this article is provided to help you find the technical support you need. This contact information is subject to change without notice. Microsoft in no way guarantees the accuracy of this third-party contact information.
The third-party products discussed in this article are manufactured by vendors independent of Microsoft; we make no warranty, implied or otherwise, regarding these products' performance or reliability.
Additional query words:
Keywords : kbgraphic kbhw
Version : WINDOWS:2000
Platform : WINDOWS
Issue type : kbprb
Technology : kbwin2kAdvSerSearch kbwin2kSSearch kbwin2kSearch kbwin2kProSearch
Suc6
