Hp cd-writer 7100 (foutmelding)
  • 112 views sinds 30-01-2008
Beste,
M'n cd-writer heeft het begeven denkik :(
wat kan ik nog proberen als ik deze foutlog krijg :
Recorder: <HP CD-Writer+ 7100> Version: 3.01 - HA 1 TA 0 - 5.5.3.5
Adapter driver: <atapi> HA 1
Drive buffer : 768kB
CD-ROM: <HP CD-Writer+ 7100>Version: 3.01 - HA 1 TA 0 - 5.5.3.5
=== Scsi-Device-Map ===
DiskPeripheral : IBM-DCAA-34330 atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : HP CD-Writer+ 7100 atapi Port 1 ID 0 DMA: Off
DiskPeripheral : Promise 1+0 Span 1.10 fasttrak Port 2 ID 0 DMA: ?
AutoRun : 1
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261688kB)
Free physical memory: 126MB (129176kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: On
CD-ROM (ISO)
9.8.2001
19:52:25#1 Text 0 File Burncd.cpp, Line 1110
Write proposal for that compilation:
19:52:25#2 Text 0 File Burncd.cpp, Line 1122
Session 1:
19:52:25#3 Text 0 File Burncd.cpp, Line 1129
Track 01:
19:52:25#4 Text 0 File Burncd.cpp, Line 1167
TRM_DATA_MODE1
19:52:29#5 Text 0 File Reader.cpp, Line 131
Reader running
19:52:29#6 Text 0 File Writer.cpp, Line 122
Writer CD-Writer+ 7100 running
19:52:29#7 ISO9660GEN -11 File geniso.cpp, Line 4226
First writeable address = 0 (0x00000000)
19:52:30#8 Text 0 File ThreadedTransferInterface.cpp, Line 666
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 600 (600) = #600/0:8.0
relocatable, CD pos for caching/writing not required/required, no patch infos
19:52:35#9 Text 0 File Burncd.cpp, Line 1110
19:52:35#10 Text 0 File Burncd.cpp, Line 1122
Session 1:
19:52:35#11 Text 0 File Burncd.cpp, Line 1129
Track 01:
19:52:35#12 Text 0 File Burncd.cpp, Line 1167
TRM_DATA_MODE1
19:52:43#13 Text 0 File Burncd.cpp, Line 1699
Recorder: HP CD-Writer+ 7100;
CDR code: 00 97 26 39; OSJ entry from: OPTICAL DISC CORPRATION
ATIP Data: ?
First writeable address from drive: 0 (0x0), used: 0 (0x0)
19:52:43#14 Text 0 File ThreadedTransferInterface.cpp, Line 801
Prepare recorder CD-Writer+ 7100 for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 1536000
19:52:43#15 Text 0 File ThreadedTransferInterface.cpp, Line 829
Removed 2 run-out blocks from end of track 1.
19:52:43#16 Text 0 File ThreadedTransferInterface.cpp, Line 666
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 598 blocks [CD-Writer+ 7100 ]
19:52:43#17 Phase 24 File dlgbrnst.cpp, Line 1368
Caching of files started
19:52:45#18 Phase 25 File dlgbrnst.cpp, Line 1368
Caching of files completed
19:52:45#19 Phase 36 File dlgbrnst.cpp, Line 1368
Burn process started at 2x (300 KB/s)
19:52:46#20 Text 0 File ThreadedTransferInterface.cpp, Line 1839
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
19:53:00#21 SCSI -1015 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02308070
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x00 0x00 0x00 0x19
0x00 0x04 0x91 0x91 0x73 0x02
19:53:00#22 mmc -1015 File Writer.cpp, Line 308
Calibration area full
19:53:00#23 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
19:53:01#24 CDR -201 File WriterStatus.cpp, Line 170
Invalid writestate
19:53:01#25 TRANSFER -18 File WriterStatus.cpp, Line 170
Could not perform EndTrack
19:53:01#26 SCSI -1023 File Cdrdrv.cpp, Line 1152
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x19
0x00 0x04 0x91 0xAA 0x2C 0x00
19:53:01#27 mmc -1023 File WriterStatus.cpp, Line 209
Command sequence error
19:53:01#28 TRANSFER -19 File WriterStatus.cpp, Line 209
Could not perform Fixation
19:53:01#29 Text 0 File WriterStatus.cpp, Line 218
falling back to disc fixation
19:53:01#30 SCSI -1023 File Cdrdrv.cpp, Line 1152
Sense Code: 0x2C
Sense Qual: 0x00
0x00 0x04 0x91 0xAF 0x2C 0x00
19:53:01#31 mmc -1023 File WriterStatus.cpp, Line 209
19:53:01#32 TRANSFER -19 File WriterStatus.cpp, Line 209
19:53:01#33 Phase 38 File dlgbrnst.cpp, Line 1368
Burn process failed at 2x (300 KB/s)
19:53:01#34 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 4/08/2001 12:45:30
  • GiLeX
GiLeX
Ook analoog fotograferend
Dat is een gevalletje schoon maken, de lens van je brander is smerig(veel voorkomende kwaal bij de hp7100 serie(is eigelijk een philips 3610)
Kortom demonteren en met een wattenstaafje gedrenkt in isopropylalcohol heel voorzichtig de lens schoonmaken.
suc6
editje: linkje toegevoegd hier staat namelijk nog wel een howto :)
Canon Eos 35mm film & digitaal met veel glas en filmrolletjes 😁
Mostly analog at: https://www.flickr.com/photos/photobygms & Digital and some analog at: https://www.instagram.com/photobygms
Hehe, dit is toeval. Had de cd-writer meegegeven aan iemand die wel wat van die soort dingen kent om hem te laten repareren. Maar deze zei dat er niet veel aan te maken was (laser vervangen kost bijna evenveel als nieuwe writer), maar hij had wel de lensjes schoongemaakt. Heeft hij dit dan niet goed gedaan of is m'n writer gewoon dood ? :'(
  • GiLeX
GiLeX
Euh, Ik ga niet zeggen of hij het verkeerd heeft gedaan :P
Ik heb er zelf ook nog twee philips 3610's
en een 2600(scsi variant, met zelfde loopwerk)
die ik alledrie al een paar keer "behandelt" heb, met succes:) Maar ooit gaan ze een keer kapot :{
Bij mij is dus inmiddels ook een van de 3610's een donor voor die andere twee als die ook problemen gaan geven :)
Heb voor de gestorven 3610 sindskort een liteon 12x10x40 >:)
  • GiLeX
GiLeX
ohja:
heb je wat meer syteem specs :?
en hoe heb je brander zitten :?
primair, secundair, master of slave :?
Alhoewel ik daar persoonlijk met de mijne geen verschil in had, zijn er ook berichten van lui die daar wel problemen mee hadden.
en wat voor OS, dma aan of uit?
Vooral met dma aan willen deze branders nog wel eens raar doen :)
Eventueel zou je al s je DMA aan het staan in je bios em kunnen vast zetten als een PIO mode 3 device.
edit btw dit hoort eigenlijks in http://gathering.tweakers.net/listtopics.php/21 thuis :)
  • EvolutionX
  • Laatst online: 11-09 15:31
je moet het loopwerkje van de lens ook invetten....
Had ik bij mijn oude HP7200i ook gedaan en toen werkte hij weer perfect!
  • Grrrrrene
[HA] --> [OM]
Euhm, hij zit als secondary master samen met een gewone cd-romspeler. Draai windows2000 op een 300mhz bakkie met 256mb geheugen. Met alleen pio-modus. (maar daar ligt het volgens mij niet echt aan want in een ander bakkie heeft hij ook deze problemen).
Maar de lens-kuis-tip ga ik zeker ens proberen straks (mag ik dit gewoon doen met een oorstokje en ontsmettingsalcohol ?)
En hoe vet ik het loopwerkje in ?! :?
ps : dank voor de website gellie .. :) denk dat ik hem zodadelijk eens uit elkaar haal in de hoop dat ik niks kapot(ter) maak ;)
  • EvolutionX
Gewoon de brander openschroeven en dan het loopwerkje waar de lens op zit insmeren :)
Ik deed gewoon wat vet op mijn wijsvinger en smeerde hem zo in...
Op Google stond ergens een site met plaatjes,maar die kan ik nu even niet meer vinden (was trouwens Spaanstalig geloof ik)
  • GiLeX
GiLeX
Geen dank :) was effe de search gebruiken en de hulp van Google
:P had je misschien zelf ook kunnen bedenken :P
Maar succes iig :) met de reanimatie :?
Heb em ff uit elkaar gehaalt, alles verliep zoals verwacht. Zag het lensje, heb ik dan schoongemaakt met oorstokje en ontsmettingsalcohol. Dan dat ijzeren ding waar de lens zich over beweegt proper gemaakt .. doet nog nix :( :(
Zou invetten helpen (maar heb niet direct 'vetsel' liggen vrees ik)
  • EvolutionX
Bij mij hielp schoonmaken ook niet,
maar na het invetten werkte hij weer perfect :)
Dit heb ik trouwens 2 x gedaan :
1x met vaseline,maar toen deed hij het na 2 maanden weer niet meer
toen daarna met lagervet ingesmeerd en heb ik hem nog een half jaar gebruikt en verkocht :D (in werkende staat)
Ik gebruikte trouwens na het vetten het programma Sisoft Sandra om de drive te stressen, zodat alles lekker ingesmeerd werd.
Probeer het nu maar, ik weet "bijna" zeker dat het lukt.....
(Maar ik denk dat je beter een andere brander kunt kopen, ik heb een paar weken terug een liteon 16x10x40 burnproof voor zo'n 320,- gekocht en die is het geld meer dan waard, nog geen cd verknoeid :) )
Ok, strax hem weer eventjes openzwieren en invetten ;)
Ben es benieuwd ...
ps : een nieuwe kopen is idd een leuk idee, maar deze HP heeft me in de begintijd (toen er nog niet veel mensen waren met een writer) redelijk veel geld gekost, daarmee wou ik hem toch graag weer aan de praat krijgen.
