Export-CSV comes out empty
  • 131 views
I Want to import a list of users and then i want select only the usernames. After that i want to export the usernames to a .CSV or .txt file
I try to run the following code but unfortunately the CSV or TXT file it comes out empty.
My Script:
#Variable
$Users = get-content "C:\Temp\Project\saxousers.txt"
#Convert Display Name to SamAccountName
Foreach ($User in $Users) {
Get-ADUser -filter { DisplayName -eq $User} | Select samAccountName | export-csv "c:\temp\project\NameToSamAccountName.txt"}
When I run the code without exporting it, I do can see the output in Powershell.
Am i missing a PIPE somewhere?
Many thanks ahead!
[ Voor 6% gewijzigd door Verwijderd op 11-09-2020 11:43 ]
  • Bolletje
  • Laatst online: 28-10 18:18
Bolletje
Hi, the language on this forum is typically Dutch. Also we request from our users to be a bit more detailed in their problem description. Lastly, it seems you have more a of coding problem which does not have anything to do with hardware / laptops. Due to the reasons listed above, I'm closing the topic.
Please see our software / coding section at Softwareontwikkeling
