Nextcloud op server, geen SSL-certificaat
  • manusjevanalles
  • Laatst online: 09:04
Ik ben bezig op mijn thuisserver Nextcloud te installeren. Het is operationeel, echter https werkt niet, alleen http op poort 80. Ik gebruik het volgende script via docker-compose:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
version: '2'
services:
  portainer:
    container_name: portainer
    image: portainer/portainer
    volumes:
       - /home/henk/nextcloud/portainer:/data
       - /var/run/docker.sock:/var/run/docker.sock
    restart: always
    ports:
       - "9000:9000"
  proxy:
    image: jwilder/nginx-proxy:alpine
    labels:
      - "com.github.jrcs.letsencrypt_nginx_proxy_companion.nginx_proxy=true"
    container_name: nextcloud-proxy
    networks:
      - nextcloud_network
    ports:
      - 80:80
      - 443:443
    volumes:
      - ./proxy/conf.d:/etc/nginx/conf.d:rw
      - ./proxy/vhost.d:/etc/nginx/vhost.d:rw
      - ./proxy/html:/usr/share/nginx/html:rw
      - ./proxy/certs:/etc/nginx/certs:ro
      - /etc/localtime:/etc/localtime:ro
      - /var/run/docker.sock:/tmp/docker.sock:ro
    restart: unless-stopped
  letsencrypt:
    image: jrcs/letsencrypt-nginx-proxy-companion
    container_name: nextcloud-letsencrypt
    depends_on:
      - proxy
    networks:
      - nextcloud_network
    volumes:
      - ./proxy/certs:/etc/nginx/certs:rw
      - /var/run/docker.sock:/var/run/docker.sock:ro
  db:
    image: mariadb
    container_name: nextcloud-mariadb
    networks:
      - nextcloud_network
    volumes:
      - /home/henk/nextcloud/mariadb:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=WACHTWOORD
      - MYSQL_PASSWORD=WACHTWOORD
      - MYSQL_DATABASE=DATABASE
      - MYSQL_USER=USER
    ports:
      - "3306:3306"
  app:
    image: nextcloud:latest
    container_name: nextcloud-app
    networks:
      - nextcloud_network
    depends_on:
      - letsencrypt
      - proxy
      - db
    volumes:
      - /home/henk/nextcloud/nextcloud:/var/www/html
    environment:
      - VIRTUAL_HOST=10.0.0.157
      - LETSENCRYPT_HOST=10.0.0.157
volumes:
  nextcloud:
  db:
networks:
  nextcloud_network:
Weet iemand waar de fout zit?
☀️ 7920 Wp | 🔋 Zendure Solarflow 800+ |🌡️ Stiebel Eltron WPL 15 ACS, HM Trend | Home Assistant
  • azerty
  • Laatst online: 08:52
LetsEncrypt reikt geen certificaten uit voor IP adressen, dus een LETSENCRYPT_HOST=10.0.0.157 gaat niet werken.
  • manusjevanalles
A dat verklaart een en ander. Is er een optie om dit te omzeilen? Ik wil mijn server uiteindelijk aan het internet hangen. Ik kan het linken aan mijn domein cloud.DOMEINNAAM.nl, maar liefst gewoon het ip-adres houden.
  • Groentjuh
  • Laatst online: 10-10 19:28
10.0.0.157 gaat het sowieso nooit worden, dat kan letterlijk niet gecontroleerd worden door LetsEncrypt. Die valt immers in de private IP ranges!
Voor publieke IPs zou je nog een certificaat kunnen krijgen (LetsEncrypt doet daar overigens zoals azerty al post niet aan!), maar private IPs gaat geen enkele SSL provider een certificaat voor uitgeven!
  • azerty
manusjevanalles schreef op dinsdag 1 september 2020 @ 11:41:
Dit zal in elk geval, zolang er geen domeinnaam aanhangt die publiek benaderbaar is, moeilijk worden met de letsencrypt-nginx-proxy-companion... Die ondersteunt enkel LE via http challenges, en daarvoor moet LetsEncrypt dus je server publiek kunnen benaderen...
Voor interne domeinen heb ik nog met DNS validatie gewerkt, en dat ging ruwweg als volgt:
- A record voor intern.foo.bar geeft je interne IP terug (10.0.0.157)
- script vraagt certificaat aan voor intern.foo.bar via DNS challenge, slaat de challenge op in je DNS records
- je geeft het verkregen certificaat voor intern.foo.bar door aan je server lokaal
Finaal kan je dan surfen naar intern.foo.bar, wat je lokaal IP zal returnen en een geldig certificaat presenteert. Geen idee of dit concept ergens al in gebruiksvriendelijke software zit daarentegen...
Edit: een wildcard voor je domein aanvragen en dat certificaat er zelf inzetten kan natuurlijk ook in combinatie met een DNS record dat naar je intern IP verwijst...
[ Voor 6% gewijzigd door azerty op 01-09-2020 12:08 ]
  • manusjevanalles
Maar als ik het goed begrijp, als ik cloud.MIJNDOMEIN.nl verwijs naar mijn publieke ip, de juiste poorten in de firewall openzet, er wel een certificaat gemaakt wordt?
  • azerty
manusjevanalles schreef op dinsdag 1 september 2020 @ 12:18:
Correct, dat zou moeten werken
  • manusjevanalles
Geweldig. Nu nog even uitzoeken hoe ik dat doorsturen instel in de DNS, en dan fingers crossed dat het werkt
