Met zeer grote spoed hulp gezocht op plesk server
  • 779 views
  • Soulmaster
  • Laatst online: 04-10 18:34
Soulmaster
iPhone, iTypos. iApologize
Wij hebben ineens grote problemen op onze server met plesk als schilletje.. email werkt niet weer, krijg ineens meldingen dat de configuratiebestanden niet goed zijn en dat deze opnieuw moeten worden geconfigureerd. alles gedaan en nog steeds.. geen mail en deze foutmelding..
hieronder plesk log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
[2020-08-29 10:27:09.620410] Installation started in background
[2020-08-29 10:27:09.620450]
Getting bootstrapper packages to installation list:
[2020-08-29 10:27:09.620496] skip package 'pp18.0.29-bootstrapper-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64' from component qmail - same or newer version of this package is already installed (in system pp18.0.29-bootstrapper-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64)
[2020-08-29 10:27:09.620529] skip package 'sw-engine-cli-2.29-2.29.0-ubuntu.18.04.200720.1803.amd64' from component qmail - same or newer version of this package is already installed (in system sw-engine-cli-2.29-2.29.0-ubuntu.18.04.200720.1803.amd64)
[2020-08-29 10:27:09.620577] skip package 'pp18.0.29-bootstrapper-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64' from component panel - same or newer version of this package is already installed (in system pp18.0.29-bootstrapper-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64)
[2020-08-29 10:27:09.620617] skip package 'sw-engine-cli-2.29-2.29.0-ubuntu.18.04.200720.1803.amd64' from component panel - same or newer version of this package is already installed (in system sw-engine-cli-2.29-2.29.0-ubuntu.18.04.200720.1803.amd64)
[2020-08-29 10:27:09.620647] Following bootstrapper packages will be installed: (empty)
[2020-08-29 10:27:09.620657] ----------------
[2020-08-29 10:27:09.620665] Getting packages to installation list:
[2020-08-29 10:27:09.620692] skip package 'psa-mail-driver-common-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64' from component qmail - same or newer version of this package is already installed (in system psa-mail-driver-common-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64)
[2020-08-29 10:27:09.620732] Following packages will be installed: plesk-mail-qc-driver-18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64 psa-qmail-3:1.03-v.ubuntu.18.04+p18.0.29.2+t200817.1747.amd64 psa-qmail-rblsmtpd-0.88-v.ubuntu.18.04+p18.0.20.0+t191009.1747.amd64
[2020-08-29 10:27:09.620746] ----------------
[2020-08-29 10:27:09.620770] Controleren of de onderlinge afhankelijkheid van pakketten is vastgesteld.
[2020-08-29 10:27:10.797276] add to install list openvas-9.0.2
[2020-08-29 10:27:10.797332] add to install list openvas-scanner-5.1.1-3
[2020-08-29 10:27:10.797362] add to install list redis-server-5:4.0.9-1ubuntu0.2
[2020-08-29 10:27:10.797407] (regen obsoletes cache)
[2020-08-29 10:27:10.797497] Check package set before installation
[2020-08-29 10:27:10.797732] The following packages from not selected components will be installed because they are required by other components' packages you selected for installation:
[2020-08-29 10:27:10.797842] Bezig met installatie van pakketten
[2020-08-29 10:27:10.820953] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_29', sequence='prep', stage='execute', sequence_order='-2', operation='install', exec_cmd='touch /var/lock/plesk-report-update.flag; :'', m_arch='', output: ~empty
[2020-08-29 10:27:10.884130] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_29', sequence='prep', stage='execute', sequence_order='-1', operation='install', exec_cmd='touch /tmp/pp-bootstrapper-mode.flag; touch /var/lock/parallels-panel-maintenance-mode.flag; rm -f /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', output: ~empty
[2020-08-29 10:27:16.196926] Bootstrapper has finished action (exec time: 6 sec.): parent_name='qmail', sequence='prep', stage='execute', sequence_order='0', operation='install', exec_cmd='/opt/psa/bootstrapper/pp18.0.29-bootstrapper/bootstrapper.sh prep-install mail-qc-driver'', m_arch='', output: ~empty
[2020-08-29 10:27:16.197258] WARNING: Failure of previous installation was detected! Bootstrapper post-actions will be executed for all components at the end of the current installation.
[2020-08-29 10:27:16.264521] Reading package lists...
Building dependency tree...
Reading state information...
openvas is already the newest version (9.0.2).
openvas-scanner is already the newest version (5.1.1-3).
redis-server is already the newest version (5:4.0.9-1ubuntu0.2).
The following packages will be REMOVED:
 plesk-mail-pc-driver* postfix*
The following NEW packages will be installed:
 plesk-mail-qc-driver psa-qmail psa-qmail-rblsmtpd
0 upgraded, 3 newly installed, 2 to remove and 10 not upgraded.
3 not fully installed or removed.
Need to get 980 kB of archives.
After this operation, 18.5 MB disk space will be freed.
Get:1 http://autoinstall.plesk.com/pool/PSA_18.0.29_3817 bionic/all amd64 plesk-mail-qc-driver amd64 18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747 [647 kB]
Get:2 http://autoinstall.plesk.com/pool/PSA_18.0.29_3817 bionic/all amd64 psa-qmail amd64 3:1.03-v.ubuntu.18.04+p18.0.29.2+t200817.1747 [311 kB]
Get:3 http://autoinstall.plesk.com/pool/PSA_18.0.29_3817 bionic/all amd64 psa-qmail-rblsmtpd amd64 0.88-v.ubuntu.18.04+p18.0.20.0+t191009.1747 [21.8 kB]
N: Ignoring file 'plesk.list.ai_back' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
Fetched 980 kB in 0s (3729 kB/s)
dpkg: plesk-mail-pc-driver: dependency problems, but removing anyway as you requested:
 psa-drweb-configurator depends on psa-mail-driver; however:
 Package psa-mail-driver is not installed.
 Package plesk-mail-pc-driver which provides psa-mail-driver is to be removed.
 psa-spamassassin depends on psa-mail-driver; however:
(Reading database ... (Reading database ... 5%(Reading database ... 10%(Reading database ... 15%(Reading database ... 20%(Reading database ... 25%(Reading database ... 30%(Reading database ... 35%(Reading database ... 40%(Reading database ... 45%(Reading database ... 50%(Reading database ... 55%(Reading database ... 60%(Reading database ... 65%(Reading database ... 70%(Reading database ... 75%(Reading database ... 80%(Reading database ... 85%(Reading database ... 90%(Reading database ... 95%(Reading database ... 100%(Reading database ... 221882 files and directories currently installed.)
Removing plesk-mail-pc-driver (18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747) ...
dpkg: postfix: dependency problems, but removing anyway as you requested:
 mailutils depends on default-mta | mail-transport-agent; however:
 Package default-mta is not installed.
 Package postfix which provides default-mta is to be removed.
 Package mail-transport-agent is not installed.
 Package postfix which provides mail-transport-agent is to be removed.
Removing postfix (3.4.8-v.ubuntu.18.04+p18.0.29.2+t200817.1747) ...
Synchronizing state of postfix.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install disable postfix
Selecting previously unselected package plesk-mail-qc-driver.
(Reading database ... (Reading database ... 5%(Reading database ... 10%(Reading database ... 15%(Reading database ... 20%(Reading database ... 25%(Reading database ... 30%(Reading database ... 35%(Reading database ... 40%(Reading database ... 45%(Reading database ... 50%(Reading database ... 55%(Reading database ... 60%(Reading database ... 65%(Reading database ... 70%(Reading database ... 75%(Reading database ... 80%(Reading database ... 85%(Reading database ... 90%(Reading database ... 95%(Reading database ... 100%(Reading database ... 221616 files and directories currently installed.)
Preparing to unpack .../plesk-mail-qc-driver_18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747_amd64.deb ...
Unpacking plesk-mail-qc-driver (18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747) ...
Selecting previously unselected package psa-qmail.
Preparing to unpack .../psa-qmail_3%3a1.03-v.ubuntu.18.04+p18.0.29.2+t200817.1747_amd64.deb ...
Unpacking psa-qmail (3:1.03-v.ubuntu.18.04+p18.0.29.2+t200817.1747) ...
Selecting previously unselected package psa-qmail-rblsmtpd.
Preparing to unpack .../psa-qmail-rblsmtpd_0.88-v.ubuntu.18.04+p18.0.20.0+t191009.1747_amd64.deb ...
Unpacking psa-qmail-rblsmtpd (0.88-v.ubuntu.18.04+p18.0.20.0+t191009.1747) ...
Setting up psa-qmail (3:1.03-v.ubuntu.18.04+p18.0.29.2+t200817.1747) ...
Setting up redis-server (5:4.0.9-1ubuntu0.2) ...
Job for redis-server.service failed because a timeout was exceeded.
See "systemctl status redis-server.service" and "journalctl -xe" for details.
invoke-rc.d: initscript redis-server, action "start" failed.
* redis-server.service - Advanced key-value store
 Loaded: loaded (/lib/systemd/system/redis-server.service; disabled; vendor preset: enabled)
 Active: activating (auto-restart) (Result: timeout) since Sat 2020-08-29 10:28:18 CEST; 4ms ago
 Docs: http://redis.io/documentation,
 man:redis-server(1)
dpkg: error processing package redis-server (--configure):
 installed redis-server package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of openvas-scanner:
 openvas-scanner depends on redis-server; however:
 Package redis-server is not configured yet.
dpkg: error processing package openvas-scanner (--configure):
 dependency problems - leaving unconfigured
Setting up psa-qmail-rblsmtpd (0.88-v.ubuntu.18.04+p18.0.20.0+t191009.1747) ...
dpkg: dependency problems prevent configuration of openvas:
 openvas depends on openvas-scanner (>= 5.1.0); however:
 Package openvas-scanner is not configured yet.
dpkg: error processing package openvas (--configure):
Setting up plesk-mail-qc-driver (18.0-v.ubuntu.18.04+p18.0.29.2+t200817.1747) ...
Created symlink /etc/systemd/system/multi-user.target.wants/qmail.service -> /lib/systemd/system/qmail.service.
Processing triggers for rsyslog (8.32.0-1ubuntu4) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Errors were encountered while processing:
 redis-server
 openvas-scanner
 openvas
E: Sub-process /usr/bin/dpkg returned an error code (1)
Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_29', sequence='pkgs', stage='rollback', sequence_order='1', operation='install', exec_cmd='rm -f /tmp/pp-bootstrapper-mode.flag; rm -f /var/lock/parallels-panel-maintenance-mode.flag; touch /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', output: ~empty
[2020-08-29 10:28:29.273321] Wprowadzanie korektorów komponentów i produktu...
[2020-08-29 10:28:29.273360] FileFetcher: get file (~empty)/report-update
[2020-08-29 10:28:29.273484] Bestand downloaden report-update: 0%
[2020-08-29 10:28:29.302427] Bestand downloaden report-update: 100% gereed.
[2020-08-29 10:28:29.302586] FileFetcher: get file (~empty)/pool/PSA_18.0.29_3817/examiners/py_launcher.sh
[2020-08-29 10:28:29.302614] Bestand downloaden pool/PSA_18.0.29_3817/examiners/py_launcher.sh: 0%
[2020-08-29 10:28:29.310908] Bestand downloaden pool/PSA_18.0.29_3817/examiners/py_launcher.sh: 100% gereed.
[2020-08-29 10:28:29.782774] Examination executed ["/root/parallels/pool/PSA_18.0.29_3817/examiners/py_launcher.sh" "/root/parallels/report-update" --op update --rc 1 --start-flag /var/lock/plesk-report-update.flag --to=18.0.29.2 --from=18.0.29] with code 0
 Output:
~empty
 Error:
~empty
[2020-08-29 10:28:29.783006] Execute command /opt/psa/admin/bin/send-error-report install --version 18.0.29
[2020-08-29 10:28:29.783889] Warning: Failed to attach to cgroup /sys/fs/cgroup/systemd/user/root/tasks, installer might be unexpectedly killed later by the system
[2020-08-29 10:28:29.785981] Error: Er is een fout opgetreden bij de poging pakketten te installeren.
Let op! Uw software is wellicht niet bruikbaar.
Ga naar https://support.plesk.com/ om een oplossing te vinden.
Wij zoeken dus met hoge spoed iemand die ons per direct kan helpen bij het oplossen van dit probleem
All wiyht, rho sritched mg kegtops awound?
  • 99ruud99
  • Laatst online: 10-10 23:30
Wat is het doel van de server?
zou je niet beter op support.plesk.com kunnen kijken?
  • HKLM_
  • Laatst online: 10-10 18:09
Configuratie bestanden terug uit de backup halen een optie?
Zo niet dan zou ik hier eens op gaan zoeken
 yet.
[ Voor 51% gewijzigd door HKLM_ op 29-08-2020 10:42 ]
Cloud ☁️
  • Soulmaster
Soulmaster
heb ik gedaan maar kan geen oplossing vinden.
De mail heb ik gelukkig weer werkend, alleen ik blijf dus die problemen met de configuratiebestanden houden van de domeinen.. wat ik ook doe met herstellen.
  • HKLM_
Soulmaster schreef op zaterdag 29 augustus 2020 @ 10:43:
Geef eens meer info wat heb je hersteld?
Cloud ☁️
  • Soulmaster
Soulmaster
HKLM_ schreef op zaterdag 29 augustus 2020 @ 10:44:
Plesk heeft dus een optie om de configuratiefiles te herstellen of opnieuw te maken, beiden werken dus niet.. Wij hadden nginx draaien maar 1 website (wordpress) had daar problemen mee.. dus weer terug naar apache, en nu dus deze , zie hieronder, problemen
Er zijn geen nieuwe configuratiebestanden aangemaakt voor de Apache-webserver vanwege fouten in de configuratiesjablonen. nginx: [emerg] cannot load certificate "/opt/psa/var/certificates/certJkJ8uXu": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/opt/psa/var/certificates/certJkJ8uXu','r') error:2006D080:BIO routines:BIO_new_file:no such file) nginx: configuration file /etc/nginx/nginx.conf test failed . Gedetailleerde omschrijvingen van foutmeldingen zijn u via e-mail toegestuurd. Los het probleem op en klik op hier om beschadigde configuratiebestanden opnieuw aan te maken of hier om alle configuratiebestanden opnieuw te genereren.
  • Soulmaster
Soulmaster
Er heeft zich iemand gemeld die voor ons gaat proberen alles weer in orde te krijgen.. van mij mag dit topic worden gesloten.
  • Question Mark
  • Laatst online: 09-10 13:32
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Soulmaster schreef op zaterdag 29 augustus 2020 @ 10:50:
Modbreak:Het is dus absoluut niet de bedoeling om hier een beetje te gaan werven...
dat staat ook duidelijk in het algemeen beleid:
Voor wervingsacties kun je terecht op Tweakers.net Jobs of andere speciaal daarvoor bedoelde sites.
