Barracuda 18XL versus 36ES
  • mr_a
  • Laatst online: 23-05-2023
Barracuda 18 XL 18.4 GB (ST318436LW) - fl 925 (Xenon webstore)
     INTERNAL TRANSFER RATE (mbits/sec)________195 to 315
     INTERNAL FORMATTED TRANSFER RATE (MB/sec)_24.7 to 39.4
     EXTERNAL TRANSFER RATE (mbyte/sec) _______40 Sync
        Low Voltage Differential(LVD) _______80/160 Sync
     SPINDLE SPEED (RPM) ______________________7,200
     AVERAGE LATENCY (mSEC) ___________________4.17
     BUFFER (/option LWV and LCV) _____________2MB/4MB
       Read Look-Ahead, Adaptive,
       Multi-Segmented Cache
     INTERFACE ________________________________Ultra SCSI Wide
          Low Voltage Differential __________Ultra3-SCSI Wide
          ASA II, SCAM level 2 (1 default)
     BYTES PER TRACK __________________________213Kbytes avg
     SECTORS PER DRIVE ________________________35,885,168
     TPI (TRACKS PER INCH) ____________________18,145
     BPI (PEAK KBITS PER INCH) ________________328.2
     AVERAGE ACCESS (ms read/write)____________6.0/6.5
       Drive level without controller overhead
     SINGLE TRACK SEEK (ms read/write) ________0.7/0.7
     MAX FULL SEEK (ms read/write) ____________10.5/11.0
     MTBF (power-on hours) ____________________1,200,000
Barracuda 36 ES 18.4 GB (ST318437LW) - fl 575 (SWW comp.)
     INTERNAL TRANSFER RATE (mbits/sec)________308 to 498
     INTERNAL FORMATTED TRANSFER RATE (MB/sec)_28.1 to 50.7
     BUFFER ___________________________________2048KB
     BYTES PER TRACK __________________________384Kbytes avg
     SECTORS PER DRIVE ________________________35,937,500
     TPI (TRACKS PER INCH) ____________________32,197
     BPI (PEAK KBITS PER INCH) ________________490.9
     AVERAGE ACCESS (ms read/write)____________8.5/9.1
     SINGLE TRACK SEEK (ms read/write) ________0.4/0.5
     MAX FULL SEEK (ms read/write) ____________14.9/15.5
     MTBF (power-on hours) ____________________800,000
Waarom hebben ze in godesnaam dan de 26 ES uitgebracht? De 18XL is overall veel beter :?
Is seagate echt van mening dat 7200 rpm geforceerd uitgefaseerd moet worden ofzo? De 18 XL is een professionele drive, de 36 ES maar een vaag cheapass ding, zo te zien...
Op StorageReview staat een interessante uitleg van waarom de 18XL zo goed is.
"There's just a nice looking, quiet computer..." | Mac mini 1.42 | AMD 64 dual core power! | pc specs
  • Papillon
  • Laatst online: 29-08 14:36
Papillon
Spring 's in the Air...
De ene reeks is een stuk ouder als de ander en levert zodoende de performance verschillen op. Tevens zijn de HD's met de tijd goedkoper geworden. Kijk eens naar 2e hands schijven, men betaalt nog f 200,= voor een 10 GB IDE schijf terwijl voor hetzelfde bedrag ook een 2e hands 20GB te halen valt. Met nieuwe schijven is ook hetzelfde het geval, die schijven zijn kennelijk voor een bepaalde prijs ingekocht en berekend men de prijs met behulp van een een of ander margecalculatie (ongeacht de marktwaarde)
F u cn rd ths, u mght hv a gd jb n cmptr prgmmng.
Kijk eens naar de prijs vriendelijke vriend. DE ES is een geval van een SCSI schijf, qua HDA vergelijkbaar met een Barracuda ATA-II, in het extreem goedkope marktsegment. De volgende stap daarboben zijn de Cheetah 18XL en Barracuda 18XL. Nog steeds low budget SCSI schijven. Kijk je daarna verder, dan kom je bij schijven als de 36LP/73HH (beide ook al weer +/-1.5 jaar oud alswel de Barracuda 180 en (zoooo mooi :) :)) de 73LP
  • mr_a
ok thx, is duidelijk nu :)
