MicroSD 512GB Samsung doet raar op Raspberry 3 - Raspbian
  • BCC
  • Laatst online: 12:44
Mijn vraag
Moet mijn MicroSD terug naar de winkel, of doe ik iets verkeerd:
29
30
31
32
33
34
Aug  6 21:29:43 raspberrypi systemd[1]: media-test.mount: Succeeded.
Aug  6 21:30:03 raspberrypi kernel: [  507.360675]  sda: sda1
Aug  6 21:31:20 raspberrypi kernel: [  584.189298] usb 1-1.4: reset high-speed USB device number 4 using dwc_otg
Aug  6 21:31:20 raspberrypi kernel: [  584.321699] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Aug  6 21:31:20 raspberrypi kernel: [  584.321752] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 af 03 de 00 00 f0 00
Aug  6 21:31:20 raspberrypi kernel: [  584.321785] blk_update_request: I/O error, dev sda, sector 11469790 op 0x0:(READ) flags 0x84700 phys_seg 2 prio class 0
Aug  6 21:31:20 raspberrypi kernel: [  584.558912] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Aug  6 21:31:20 raspberrypi kernel: [  584.558950] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x6 [current]
Aug  6 21:31:20 raspberrypi kernel: [  584.558973] sd 0:0:0:0: [sda] tag#0 ASC=0x28 ASCQ=0x0
Aug  6 21:31:20 raspberrypi kernel: [  584.559001] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 af 04 ce 00 00 10 00
Aug  6 21:31:20 raspberrypi kernel: [  584.559029] blk_update_request: I/O error, dev sda, sector 11470030 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Aug  6 21:31:20 raspberrypi kernel: [  584.559177] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:20 raspberrypi kernel: [  584.559199] blk_update_request: I/O error, dev sda, sector 11470046 op 0x0:(READ) flags 0x84700 phys_seg 5 prio class 0
Aug  6 21:31:20 raspberrypi kernel: [  584.559331] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:20 raspberrypi kernel: [  584.559351] blk_update_request: I/O error, dev sda, sector 11470286 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Aug  6 21:31:20 raspberrypi kernel: [  584.559462] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:20 raspberrypi kernel: [  584.559480] blk_update_request: I/O error, dev sda, sector 11469790 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug  6 21:31:21 raspberrypi kernel: [  585.609330] usb 1-1.4: reset high-speed USB device number 4 using dwc_otg
Aug  6 21:31:22 raspberrypi kernel: [  585.741693] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Aug  6 21:31:22 raspberrypi kernel: [  585.741734] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 af 1c f6 00 00 40 00
Aug  6 21:31:22 raspberrypi kernel: [  585.741761] blk_update_request: I/O error, dev sda, sector 11476214 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Aug  6 21:31:22 raspberrypi kernel: [  585.979181] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Aug  6 21:31:22 raspberrypi kernel: [  585.979218] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x6 [current]
Aug  6 21:31:22 raspberrypi kernel: [  585.979241] sd 0:0:0:0: [sda] tag#0 ASC=0x28 ASCQ=0x0
Aug  6 21:31:22 raspberrypi kernel: [  585.979269] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 af 1d 36 00 00 40 00
Aug  6 21:31:22 raspberrypi kernel: [  585.979294] blk_update_request: I/O error, dev sda, sector 11476278 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
Aug  6 21:31:22 raspberrypi kernel: [  585.979437] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:22 raspberrypi kernel: [  585.979458] blk_update_request: I/O error, dev sda, sector 11476214 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug  6 21:31:22 raspberrypi kernel: [  585.979681] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:22 raspberrypi kernel: [  585.979701] blk_update_request: I/O error, dev sda, sector 11476214 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug  6 21:31:22 raspberrypi kernel: [  585.981873] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:22 raspberrypi kernel: [  585.981903] blk_update_request: I/O error, dev sda, sector 11476214 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug  6 21:31:22 raspberrypi kernel: [  585.982366] sd 0:0:0:0: [sda] tag#0 device offline or changed
Aug  6 21:31:22 raspberrypi kernel: [  585.982450] sd 0:0:0:0: [sda] tag#0 device offline or changed
fsck en reformatten van de MicroSD. Hij zit via een SanDisk kaartlezer aan een usbpoort aangesloten van de Raspberry en ik boot van een 16GB microscoop.
Ik kan nog proberen om de 16GB eruit te halen en van de 512GB te boord , maar via een kaartlezer leek mij beter ivm de hogere snelheid en eenvoudig te swappen en de mogelijke problemen met booten van grote microsds.
Kan het zijn dat de SDKaart teveel stroom trekt van de pi?
[ Voor 3% gewijzigd door BCC op 06-08-2020 23:10 ]
  • MainframeX
  • Laatst online: 11:19
De kernel log ziet er niet fraai uit. Verder begrijp ik je verhaal niet. Als ik het letterlijk interpreteer is je sd kaart via een Sandisk op een usb poort aangesloten. Dat slaat echt als een tang op een varken. Kan je dit eens opnieuw uitleggen?
Idempotent.
  • BCC
Ik heb het wat rot verwoord zie ik: ik boot Raspbian van een 16GB sdkaart en als extra storage heb ik een 512GB sdkaart via een usb kaartlezer aangesloten. Zo kan ik de 512 GB er eenvoudig uithalen zonder dat ik het os om zeep help.
[ Voor 8% gewijzigd door BCC op 06-08-2020 23:10 ]
  • MainframeX
@BCC Meestal is sda je boot device. Dan vind ik eerder het 16GB kaartje verdacht. Door "lsblk" in te voeren op de terminal weet je zeker welk kaartje het is.
Sd kaartjes in raspberry pi's willen na verloop van tijd nog wel eens stuk gaan. Dit komt omdat ze dan hun maximale levensduur w.b.t. schrijfacties bereikt hebben. Deze ligt veel lager dan bijv disken of ssd's.
Idempotent.
  • BCC
Het os is /dev/mmcblk0p1
  • BCC
Ik heb even een pi geleend en het lijkt aan de pi te liggen. Zelfde voeding en sd kaarten en het werkt prima. Erg vreemd.
  • DukeBox
Heb wel eens een SD kaart gehad die met hogere temperaturen raar deed. Je kan de oude anders even testen met wat actieve koeling ?
  • BCC
Ik boot er nu van en alle problemen zijn verdwenen. Zou dan toch de usb sd kaart adapter te veel stroom hebben getrokken 🤔
  • DukeBox
Denk dan eerder een slecht contact in je usb naar sd converter
  • Bamboozled
  • Laatst online: 12:54
io error = meestal sd kaart kapot
check de hele sd even met h2testw dan zie je gauw genoeg r/w errors
[ Voor 51% gewijzigd door Bamboozled op 16-08-2020 13:49 ]
