Docker & container Wireguard
  • CAD-tekenaar
  • Laatst online: 10-11 23:37
Ik heb container Wireguard gemaakt via docker run.
Maar ik zie verschillende foutmeldingen in de log die ik niet kan oplossen.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] 01-envfile: executing... ,
[cont-init.d] 01-envfile: exited 0.,
[cont-init.d] 10-adduser: executing... ,
usermod: no changes,
          _         (),
         | |  ___   _    __,
         | | / __| | |  /  \ ,
         | | \__ \ | | | () |,
         |_| |___/ |_|  \__/,
Brought to you by linuxserver.io,
To support the app dev(s) visit:,
WireGuard: https://www.wireguard.com/donations/,
To support LSIO projects visit:,
https://www.linuxserver.io/donate/,
GID/UID,
User uid:    1000,
User gid:    1000,
[cont-init.d] 10-adduser: exited 0.,
[cont-init.d] 30-config: executing... ,
Hit:1 http://archive.raspberrypi.org/debian buster InRelease,
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease,
Hit:3 http://ppa.launchpad.net/wireguard/wireguard/ubuntu bionic InRelease,
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB],
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [74.6 kB],
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB],
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf Packages [813 kB],
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe armhf Packages [1,163 kB],
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-security/main armhf Packages [547 kB],
Fetched 2,775 kB in 3s (882 kB/s),
Reading package lists...,
Raspbian kernel naming convention detected, attempting to install raspbian kernel headers,
Warning: apt-key output should not be parsed (stdout is not a terminal),
OK,
Hit:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease,
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease,
Hit:3 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease,
Hit:4 http://archive.raspberrypi.org/debian buster InRelease,
Hit:5 http://ppa.launchpad.net/wireguard/wireguard/ubuntu bionic InRelease,
Hit:6 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease,
Building dependency tree...,
Reading state information...,
raspberrypi-kernel-headers is already the newest version (1.20200601-1).,
wireguard is already the newest version (1.0.20200513-1~18.04).,
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.,
1 not fully installed or removed.,
After this operation, 0 B of additional disk space will be used.,
Setting up flash-kernel (3.98ubuntu11~18.04.1) ...
flash-kernel: deferring update (trigger activated)
Processing triggers for flash-kernel (3.98ubuntu11~18.04.1) ...
Unsupported platform.
dpkg: error processing package flash-kernel (--configure):
 installed flash-kernel package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 flash-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1),
Server mode is selected,
External server address is set to ****.duckdns.org,
External server port is set to 51820. Make sure that port is properly forwarded to port 51820 inside this container,
Internal subnet is set to 10.13.13.0,
PEERDNS var is either not set or is set to "auto", setting peer DNS to 10.13.13.1 to use wireguard docker host's DNS.,
No changes to parameters. Existing configs are used.,
[cont-init.d] 30-config: exited 0.,
[cont-init.d] 99-custom-scripts: executing... ,
[custom-init] no custom files found exiting...,
[cont-init.d] 99-custom-scripts: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
[#] ip link add wg0 type wireguard,
RTNETLINK answers: Operation not supported,
Unable to access interface: Protocol not supported,
[#] ip link delete dev wg0,
Cannot find device "wg0",
.:53,
CoreDNS-1.6.9,
linux/arm, go1.14.1, 1766568,
Caught SIGTERM signal!,
wg-quick: `wg0' is not a WireGuard interface,
Docker draait op raspberry 3B+.
Container Wireguard heb ik (met user 'pi') gestart met:
docker pull linuxserver/wireguard
docker run \
--name=wireguard \
--cap-add=NET_ADMIN \
--cap-add=SYS_MODULE \
-e PUID=1000 \
-e PGID=1000 \
-e TZ=Europe/Amsterdam \
-e SERVERURL=[mijn.duckdns.org] \
-e SERVERPORT=51820 \
-e PEERS=1 \
-e PEERDNS=auto \
-p 51820:51820/udp \
-v /home/pi/wireguard/config:/config \
-v /home/pi/wireguard/modules:/lib/modules \
--sysctl="net.ipv4.conf.all.src_valid_mark=1" \
--restart unless-stopped \
linuxserver/wireguard:arm32v7-latest
Bron: https://hub.docker.com/r/linuxserver/wireguard
Poort 51820 is geforward.
OS: Raspbian Buster (32-bit)
Portainer heb ik ook geinstalleerd.
Volgens de bron hoef ik niets meer in te stellen.
Toch zie ik foutmeldingen over kernel, interface, protocol en device wg0.
Wie kan me helpen wat hier fout gaat?
  • DaFeliX
  • Laatst online: 07:37
DaFeliX
Tnet Devver
Welke host os draai je? Raspbian of Ubuntu?
With regards to arm32/64 devices, Raspberry Pi 2-4 running the official ubuntu images prior to focal or Raspbian Buster are supported out of the box. For all other devices and OSes, you can try installing the kernel headers on the host, and mapping /usr/src:/usr/src and it may just work (no guarantees).
Einstein: Mijn vrouw begrijpt me niet
  • patviev
  • Laatst online: 10-11 21:49
Kloppen je puid en guid? Zie deze site om te controleren of beide 1000 zijn. https://www.geeksforgeeks...d-in-linux-with-examples/
  • CAD-tekenaar
DaFeliX schreef op dinsdag 23 juni 2020 @ 07:19:
Host OS = Raspbian Buster
pi@raspberrypi3b-plus:~ $ uname -a
Linux raspberrypi3b-plus 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
[ Voor 5% gewijzigd door CAD-tekenaar op 23-06-2020 08:08 ]
  • CAD-tekenaar
patviev schreef op dinsdag 23 juni 2020 @ 07:24:
Ja die kloppen.
pi@raspberrypi3b-plus:~ $ id pi
UID=1000(pi) GID=1000(pi) groepen=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),60(games),100(users),105(input),109(netdev),999(spi),998(i2c),997(gpio),995(docker)
  • patviev
Op GitHub is ook een melding te vinden over een probleem met de flash-kernel. https://github.com/TheRem...pi4-unofficial/issues/112
Waarbij iemand als oplossing het volgende schrijft
apt-mark hold flash-kernel
  • CAD-tekenaar
patviev schreef op dinsdag 23 juni 2020 @ 08:29:
Je regel 'apt-mark hold flash-kernel' ingevoerd in CLI met root-rechten en RP3B+ herstart.
(Werkt je oplossing ook voor de RP3B+ ?)
Container wireguard herstart.
Dit zijn de logs.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
[INFO] SIGTERM: Shutting down servers then terminating,
[cont-finish.d] executing container finish scripts...,
[cont-finish.d] done.,
[s6-finish] waiting for services.,
[s6-finish] sending all processes the TERM signal.,
[s6-finish] sending all processes the KILL signal and exiting.,
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
          _         (),
         | |  ___   _    __,
         | | / __| | |  /  \ ,
         | | \__ \ | | | () |,
         |_| |___/ |_|  \__/,
GID/UID,
User uid:    1000,
User gid:    1000,
Hit:1 http://ppa.launchpad.net/wireguard/wireguard/ubuntu bionic InRelease,
Hit:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease,
Hit:4 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease,
Hit:5 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease,
Hit:6 http://archive.raspberrypi.org/debian buster InRelease,
OK,
Hit:5 http://archive.raspberrypi.org/debian buster InRelease,
 flash-kernel
External server address is set to wireguard-martin.duckdns.org,
[services.d] done.,
.:53,
CoreDNS-1.6.9,
Klopt het dat ik geen verschil zie? (de fouten blijven aanwezig)
  • CAD-tekenaar
Kernel heb ik ook geupdate.
pi@raspberrypi3b-plus:~ $ ls /lib/modules
4.19.118+  4.19.118-v7+  4.19.118-v7l+  4.19.118-v8+  5.3.0-1027-raspi2
Foutmeldingen blijven.
Iemand nog ideeen wat de oplossing is?
