Hello guys.
I bough the HK 151S around 2 years ago, I had a TV and I plugged all the HDMIs in the receiver and only one HDMI connected from the receiver to the TV, worked perfect and I never had any problems.
Last week I bought a new TV(Samsung Q90R) and as it is 4K, I have my PS4 and Ziggo box connected to the TV and only one cable from the TV to the receiver in the ARC port, I use the receiver only for sound now.
Right now when I connect had no problems, sound works as expected and now I control the receiver via the TV remote control.
Problem:
When I turn off the TV, it also turns off the receiver, but sometimes when I turn the TV on, not always the receiver starts, and when that happens, even if I power on the receiver manually, the TV doesn't find the receiver. I tried to disconnect and connect the cable again but it does not work, it only works if I unplug the power of the receiver, wait a few seconds and plug it again, then the TV recognizes the audio device.
Also, even if everything is ok, after a few hours the TV control stops working with the receiver... when I press down the volume, in the TV it shows the icon of the receiver and the sound going down, but nothing happens, it only goes down if I use the HK control... it is like it looses the link after a while.
First I though this was a TV problem, but as disconnecting the power cord of the receiver makes it work, I guess it is a problem of the ARC port of the receiver.
My firmware version is V005.006 and I'm sure it is an outdated one but I could not find a new version in HK website.
Any ideas ? :(
[ Voor 10% gewijzigd door Verwijderd op 18-05-2020 13:22 ]
