Greetings computer people! As the title states, I am having several concerns about my first PC build, as I am very inexperienced when it comes to PC parts and I only got into it a few days ago. I'm going to attach a screenshot of the PC build and I'd be glad if you could help me out :) Keep in mind that I am going to be using this PC mostly for gaming, but considering that I am a Game Design student I will probably be doing some 3D rendering and such... Also, my budget is around 1500-1600 euros (with the case and 144Hz monitor)
So this is the first look of the PC:
Afbeeldingslocatie: https://tweakers.net/i/4AeBlOkX05OGIMR8w1Qxtv7DgCU=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/WScJTamuLGXtsKLlVvbY1E97.png?f=user_large
I think that it looks okay overall, I got some feedback from friends and they said that it's okay, but it could use some improvements, such as replacing the video card with a stronger one and lowering the CPU power. I made a list of potential replacement parts as well:
Afbeeldingslocatie: https://tweakers.net/i/HSQjCe8NgTWxuoVgztDCNKPhPxY=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/d4qsHFYTWulh9W3PhzfReYEa.png?f=user_large
So my idea was to either change the motherboard, because I got the advice that motherboards and GPUs work better if they are under the same manufacturer, or to change the video card and the processor. I generally want a system that would last me long while, as I don't have the money to invest in upgrades and such (at least in the next several years I don't plan on upgrading/replacing parts).
I would be very grateful if you could help me out :) Thanks in advance and I hope that you have a nice day! :)
P.S. I would also be glad if you could give me an idea for what casing I should get for the PC (not too expensive of course)
  • Napsju
  • Laatst online: 14:42
Je bent hier op een Nederlandstalig forum. Voor Engelstalige forums zou je eens op Google kunnen zoeken. Doe er je voordeel mee.
Verder zou je de FAQ eens kunnen doornemen: Forum FAQ
Lekker!
  • kyrillajax
  • Registratie: Oktober 2018
  • Laatst online: 14-11 15:30
1ProcessorsAMD Ryzen 7 3700X Boxed€ 298,45€ 298,45
1MoederbordenMSI B450M Mortar Max€ 102,25€ 102,25
1VideokaartenMSI GeForce RTX 2070 Super Ventus OC€ 569,90€ 569,90
1BehuizingenFractal Design Meshify C€ 79,90€ 79,90
1Geheugen internCrucial Ballistix BL2K8G32C16U4B€ 78,29€ 78,29
1Voedingenbe quiet! Straight Power 11 550W€ 99,90€ 99,90
1Solid state drivesWD Blue SN550 1TB (WDS100T2B0C)€ 138,90€ 138,90
Bekijk collectie
Importeer producten
Totaal€ 1.367,59
An aftermarket cooler is not necessary, but if you want less noise you could go for the Gelid Solutions Tranquillo Rev.4 version B. Crucial ram is more stable and compatible than corsair. If Nvidia is not necessary you can switch it for a 5700XT.
