HalfLife map editing
  • 114 views sinds 30-01-2008
  • MWAD
  • Laatst online: 22-12-2025
MWAD
Morron With A Dress
Ik een fet mooie map maken voor HL-CS
(screenies komen eraan!)
ik er vet veel instouwen en doet ie het ineens niet meer hij geeft een error, deze error :
** Executing...
** Command: Change Directory
** Parameters: D:\Games\Half-Life
** Executing...
** Command: Copy File
** Parameters: "D:\Games\Half-Life\valve\maps\ah.map" "D:\Games\Half-Life\valve\maps\ah.map"
** Executing...
** Command: C:\Program Files\WorldCraft\hlcsg.exe
** Parameters: "D:\Games\Half-Life\valve\maps\ah"
hlcsg v2.5.3 rel (May 2 2001)
Based on Valve's version, modified with permission.
Submit detailed bug reports to (zoner@gearboxsoftware.com)
----- BEGIN hlcsg -----
Command line: "C:\Program Files\WorldCraft\hlcsg.exe"D:\Games\Half-Life\valve\maps\ah
-= Current hlcsg Settings =-
Name | Setting | Default
threads [ 1 ] [ Varies ]
verbose [ off ] [ off ]
log [ on ] [ on ]
developer [ 0 ] [ 0 ]
chart [ off ] [ off ]
estimate [ off ] [ off ]
max texture memory [ 4194304 ] [ 4194304 ]
priority [ Normal ] [ Normal ]
noclip [ off ] [ off ]
onlyents [ off ] [ off ]
wadtextures [ on ] [ on ]
skyclip [ on ] [ on ]
hullfile [ None ] [ None ]
min surface area [ 0.500 ] [ 0.500 ]
brush union threshold [ 0.000 ] [ 0.000 ]
Wadinclude list :
[zhlt.wad]
entering D:\Games\Half-Life\valve\maps\ah.map
CreateBrush:
10..20..30..40..50..60..70..80..90.. (262.11 seconds)
SetModelCenters:
10..20..30..40..50..60..70..80..90.. (0.00 seconds)
CSGBrush:
10..20..30..40..50..60..70..80..90.. (46.68 seconds)
Using WAD File: \games\half-life\valve\ajawad.wad
Using WAD File: \games\half-life\valve\as_tundra.wad
Using WAD File: \games\half-life\valve\cached.wad
Using WAD File: \games\half-life\valve\cs_747.wad
Using WAD File: \games\half-life\valve\cs_assault.wad
Using WAD File: \games\half-life\valve\cs_cbble.wad
Using WAD File: \games\half-life\valve\cs_dust.wad
Using WAD File: \games\half-life\valve\cs_office.wad
Using WAD File: \games\half-life\valve\cs_thunder.wad
Using WAD File: \games\half-life\valve\cstrike.wad
Using WAD File: \games\half-life\valve\de_aztec.wad
Warning: ::: Larger than expected texture (348972 bytes) Wad:wad[\games\half-life\valve\de_aztec.wad] Texture[547:SPECIAL_THANKS]
Warning: ::: Larger than expected texture (348972 bytes) Wad:wad[\games\half-life\valve\de_aztec.wad] Texture[548:THANKS]
Using WAD File: \games\half-life\valve\de_vegas.wad
Using WAD File: \games\half-life\valve\decals.wad
Using WAD File: \games\half-life\valve\halflife.wad
Using WAD File: \games\half-life\valve\itsitaly.wad
Using WAD File: \games\half-life\valve\jos.wad
Using WAD File: \games\half-life\valve\liquids.wad
Using WAD File: \games\half-life\valve\n0th1ng.wad
Using WAD File: \games\half-life\valve\pldecal.wad
Using WAD File: \games\half-life\valve\prodigy.wad
Using WAD File: \games\half-life\valve\spraypaint.wad
Using WAD File: \games\half-life\valve\xeno.wad
Using WAD File: \games\half-life\valve\alberthein.wad
added 5 additional animating textures.
Texture usage is at 0.68 mb (of 4.00 mb MAX)
328.45 seconds elapsed [5m 28s]
----- END hlcsg -----
** Executing...
** Command: C:\Program Files\WorldCraft\hlbsp.exe
hlbsp v2.5.3 rel (May 2 2001)
----- BEGIN hlbsp -----
Command line: "C:\Program Files\WorldCraft\hlbsp.exe"D:\Games\Half-Life\valve\maps\ah
-= Current hlbsp Settings =-
log [ on ] [ on ]
nofill [ off ] [ off ]
notjunc [ off ] [ off ]
subdivide size [ 240 ] [ 240 ] (Min 64) (Max 240)
max node size [ 1024 ] [ 1024 ] (Min 64) (Max 4096)
>>>>>BSP generation successful, writing portal file 'D:\Games\Half-Life\valve\maps\ah.prt'
Error: Exceeded MAX_MAP_MODELS
Description: The maximum number of brush based entities has been reached
Howto Fix: Remove unnecessary brush entities, consolidate similar entities into a single entity<<<<<
----- END hlbsp -----
wat is dit en hoe verhelp ik het of ga ik het tegen oid
Thnx
De Som van de Momenten ten opzichte van punt " A " = NUL
  • rove
  • Laatst online: 02-06-2022
Erm..lmFd?
dunno
  • MM-
  • Laatst online: 30-11-2023
MM-
is dat toch niet dezelfde fout als in deze topic : [topic=196500]
Op maandag 06 augustus 2001 14:13 schreef MM- het volgende:
ja, maar ipv dat meneer eens op een van de links die ik heb gegeven gaat kijken blijft hij hier roepen dattie een coole map heeft roepen maar hem niet kan compilen....
*zucht*
www.vlatitude.com/links.php maar weer
  • MWAD
MWAD
Morron With A Dress
Ja zorrie hoor maar die andere topic mag een slotje op (weet niet hoe ik die moet sluiten) want daar staat alleen maar gezeur in ik wil gewoon een degelijke topic.:7
maar wat is (een)ifmd????
kan ik het daarmee verhelpen???
en hij zegt dat ik teveel enteties heb hoe kan ik van zeg maar 10 dingen 1 entetie maken??????
  • rove
Groupen? en het is lmfd en dat betekend dus lijkt me fucking duidelijk.
dunno
  • MWAD
MWAD
Morron With A Dress
Op maandag 06 augustus 2001 16:18 schreef RoVe het volgende:
Groupen?
dat heb ik al geprobeerd maar hij blijft het geven ik heb ook "tie to entity gedaan (13 objecten tegelijk) maar dat werkt ook niet
  • MWAD
MWAD
Morron With A Dress
EN NU WAT SCREENIES : we zijn net begonnen en de rand van de WINKEL is nog niet gedaan
Afbeeldingslocatie: http://members.home.nl/vdkolk/winkel.jpg
Afbeeldingslocatie: http://members.home.nl/vdkolk/bonus.jpg
Afbeeldingslocatie: http://members.home.nl/vdkolk/kassas.jpg
Dit is zoals je ziet een winkel (voor de mensen uit zwolle zuid (DIT IS DE ALBERTHEIJN(excact nagemaakt)))
maar hij doet het nog niet
hellup (zie hierboven)
tip 1:
real-life locaties werken 9/10 keer niet, als je het dan toch doet: probeer er aan te denken dat je het ook speelt en niet alleen in rondloopt, maak het dus interessant voor de mensen die het niet kennen.
tip 2:
die schappen lijken me nogal een aanslag op je fps maak ze wat simpeler (gooi d'r een paar textures tegen aan ofzo)
  • Reefer
  • Laatst online: 21-02-2025
Reefer
madness
ja geen wonder als je een rij met 20 kassas heb elk bestaande uit 30 brushes, ik denk dat jullie hebben lopen carven (?) , waardoor je heel veel brushes krijgt, hetzelfde met die schappen, maak een texture zodat het lijkt alsof er dingen instaan enzo
A Breakbeat A Day Keeps Religion Away.
  • MWAD
MWAD
Morron With A Dress
Op maandag 06 augustus 2001 17:58 schreef GummiEnte het volgende:
tip 2:
je kan niet door het glas heen kijken want dan moet ie het heele level laden en dat wil natuurlijk niet (dan is het toch goed)
en hij is nog lang niet klaar er komen nog allemaal dingen bij
  • MWAD
MWAD
Morron With A Dress
Op maandag 06 augustus 2001 18:06 schreef Reefer het volgende:
carven ja 2x en hoe krijg ik er 1 enity van dan???? om dat te verhelpen ??????
daar gaat deze topic eigenlijk over maar ik heb (ja zorrie hoor) nog geen zuiver antwoord gehoord(gelezen)
  • MWAD
MWAD
Morron With A Dress
heeft dan nog niemand met worldcraft een map gemaakt???
of uberhaubt mee gewerkt
Op maandag 06 augustus 2001 19:03 schreef MWAD het volgende:
nee ik gebruik als het ff kan quark, www.planetquake.com/quark
  • MWAD
MWAD
Morron With A Dress
jah dat heb ik ook
(SNAP IK GEEN HOL VAN!!)
....maarja....
Lol , een alberthein level :)
  • frim
ik vroeg me eerst al af wat ah betekende :)
MWAD mietjuh !
mijn vet relaxe schuif deur en cool box staan er niet bij !
w8 hier komen ze !
Afbeeldingslocatie: http://members.home.nl/looney/rek1.jpg
Afbeeldingslocatie: http://members.home.nl/looney/rek2.jpg
Afbeeldingslocatie: http://members.home.nl/looney/rek3.jpg
Afbeeldingslocatie: http://members.home.nl/looney/rek4.jpg
deze foto's zijn niet in de AH map gemaakt deze foto's zijn uit een Prefab map !!
  • rove
Het lijkt me ontzettend saai om te spelen ofniet? Het is net een doolhof. als je allebei loopt ben je een half uur bezig elkaar te zoeken..
dunno
  • frim
als je echt cool wil zijn, zorg je dat de deuren meteen dicht gaan als iemand buiten het bereik van dar roie boxje is (lees: door de deuropning gaan) :)
hoef je gelijk geen einde aan het level meer te knopen :/
Tis Half-Life CS level 3 ingangen aan vookant hosties achterin! en zo heel erg groot is ie niet. al zo er een DM level van komen dan zou je over de schappen kunnen klimmen.
Op maandag 06 augustus 2001 21:41 schreef LooneyD het volgende:
hosties? het is toch geen katholieke kerk?
Op maandag 06 augustus 2001 22:11 schreef GummiEnte het volgende:
LOL
  • frim
och nee toch, ik d8 al, echt zo'n lars-antwoord
  • BasieP
  • Laatst online: 19-10-2025
er zijn al meer levels idd met winkels, en ik vond die wel wat saai, omdat je altijd overal heen kunt.. je zou eigenlijk een paar wagentjes in de gangen noeten keilen zodat je niet overal meer door kunt.
This message was sent on 100% recyclable electrons.
Dit word niks, zie ik nu al... Namaken is niet kewl en je map krijgt totaal geen GamePlay. Mijn tip; maak een map en ga hem afmaken tijdens een lan. Telkens ff spelen met z'n allen en weer wat dingen veranderen. Zo krijg je echt leuke maps >:)
  • MWAD
MWAD
Morron With A Dress
DAS een heeeel goed iedeej jah dat je niet door alle gangen kunt
of dat er wat uit is gevallen of er liggen allemaal dozen ofzo
JA doen we tof idee!!!
maar nou heb(ben) ik/we nog steeds een probleem dat er teveel enities zijn maar ik/we weet(en)niet hoe ik /we dat ga(an) verhelpen
  • MWAD
MWAD
Morron With A Dress
Op dinsdag 07 augustus 2001 02:37 schreef PC-ICE het volgende:
volgende week krijgen we lan met collega's die daar werken
ZIJN HEEL ENTOUSIAST ->weet ik nu al!
maar ok ideeen wisselen is een goed idee (:?)
Maak wat fancy Luchtschachten, zodat ct of t zoek dat zelf maar uit, daar door kunnen sneaken. Zorg dat er plenty ruimte is voor dat je elkaar tegen komt, niet dat de een nog wapens aan het kopen is en ondertussen wordt afgeknald door dat je elkaar kan zien aan de overkant (zo ziet het er namelijk uit)
als die klaar is, stuur em mij dan ffkes
  • MWAD
MWAD
Morron With A Dress
Op dinsdag 07 augustus 2001 12:07 schreef Childsplay het volgende:
ja maar dan wordt het een assault lookalike en dat wil ik niet want die bestaat al!!
(....of is dat juist coel....)
maar hoe kan het nou dat assault dus HELEMAAL niet laggie gaat maat toch 2 heeele grote ruimten moet laden ???????
Op maandag 06 augustus 2001 23:38 schreef frim het volgende:
Pieterje, wist je dat ook 2 maadnen lid moet zijn voor je de huiskamer in mag!!
  • Reefer
Reefer
madness
het kan ook komen doordat je zoveel verschillende wads gebruikt misschien?
(newbie talking here)
en over dat carven , je moet gewoon slim carven dat je niet 10 kleine blokjes krijgt waar je het met 3 kunt doen.
