Google fotos uploaden
  • sgouman
  • Registratie: Juli 2013
  • Laatst online: 09-09 22:55
Ik heb ongeveer 200GB aan foto's in mapjes die ik naar google foto's wil uploaden. Aangezien de mappen nest groot zijn werkt dit heel slecht om via de vrowser te uploaden. Via de synch yool van google kan ik alleen hele mappen synchen en worden dr fotos niet in albums in google fotos geplaatst.
Weet iemand een andere methodr zodat ik toch mijn fotos naar albums in google fotos kan uploaden zonder dit via de browser te doen.
  • Berlinetta
  • Registratie: Juli 2015
Add photos & videos from Google Drive to Google Photos
To organize your photos and videos across services, you can add photos from Google Drive to Google Photos.
Before you get started
The photo must be larger than 256 pixels.
The file type must be .jpg, .gif, .webp, .tiff, or .raw.
If you use a Google Account through work or school, you’ll have to download from Google Drive and re-upload to Google Photos.
You can add photos and videos from Google Drive on a computer.
On your computer, go to photos.google.com.
At the top right, click Upload and then Google Drive.
Find and select your photos.
Click Upload.
What happens when you change or delete a photo
Any changes you make in Drive will only apply to Drive. Any changes you make in Photos will only apply to Photos.
Check your storage
Your photos and videos are stored using your Google Account's storage space.
Items copied from Google Drive to Google Photos are uploaded based on your upload size, like High quality or Original quality.
If you copy an item in Original quality from Google Drive to Google Photos, the new copy in Google Photos will also count against your storage quota.
If you upload in High quality using Google Photos or Backup and sync, it will not count against your storage quota.
Learn how to change your upload size.
https://support.google.com/photos/answer/6156103
[ Voor 50% gewijzigd door Berlinetta op 22-04-2020 01:24 ]
  • sgouman
Oke, Echter is drive maar 15GB dan moet ik dit riedeltje heel vaak herhalen. Is er geen andere oplossing?
  • Jester-NL
Jester-NL
... pakt een botte bijl
Upgrade naar Google One, dan wordt het al 100GB: https://one.google.com/about#upgrade
En dat is vast weer te vergroten ;)
[ Voor 17% gewijzigd door Jester-NL op 23-04-2020 13:44 ]
The sky above the port was the color of television, turned to a dead channel
me @ last.fm
  • Ad de Jong
  • Laatst online: 22:24
Jester-NL schreef op donderdag 23 april 2020 @ 13:43:
Yep ;-)
Afbeeldingslocatie: https://tweakers.net/i/bDnJOeV2C7ZWkGjNjbkGIOFW0hA=/800x/filters:strip_exif()/f/image/o8Q2niqqQBwvRlGBJWHIR9CF.png?f=fotoalbum_large
Mijn profiel op Discogs
  • Tha Masternoop
  • Registratie: Maart 2015
  • Laatst online: 22-09 10:46
Hey mede Tweakers,
Ik ben blijkbaar te noob om een forum post te starten dus doe ik maar een reply, hoop dat iemand dit toch ziet en het antwoord heeft of me kan vertellen hoe ik een eigen draadje start.
Google gaat volgend jaar stoppen met gratis opslag. Nu heb ik een aantal foto's in originele kwaliteit ge-upload voordat ik doorhad dat je dat kon instellen (jaren geleden) nooit mee op gelet want ik zit op 75% en die laatste 25% zou ik toch niet meer vol maken omdat ik nu alles in de gecomprimeerde kwaliteit opsla. Nu mijn vraag. Ik zou graag de foto's die ik in originele kwaliteit heb ge-upload willen downloaden om ze vervolgens gecomprimeerd op te slaan. Ik maak dan van het origineel een back-up op een externe drive. Ik kan nergens op internet iets vinden over hoe ik de foto's kan vinden die ik in originele kwaliteit heb opgeslagen. Iemand een idee?
Voor het antwoord op de vraag hier. Ik heb al mijn foto's van mijn PC ge-upload en het kost me geen extra data omdat ik voor gecomprimeerd heb gekozen. https://photos.google.com/apps?hl=nl hier kun je de app downloaden waarmee ik dat heb gedaan. Stel je Google foto's account in op hoge kwaliteit en je kunt je hele foto archief in een keer uploaden.
