RedHat: Kan niet meer compilen
Hi,
I heb sinds een paar dagen een probleem. Hieronder staat, in het engels, dat wel, een bericht dat in een news-group gepost heb maar die blijft nauwelijks actief te zijn dus dat schiet niet op.
= ze mezzage ================================
I run a Sun UltraSparc IIi box (Ultra 10). I have upgrade the entire
system by now with the sparc RPM's from rawhide.
Amongst the new rpm's are gcc 2.96-81 en glibc 2.2.2-10.
This setup works fine. No problems at all. Hell, i build the entire
Ximian Gnome 1.4 distro from scratch and it runs fine.
However, since a few days a lot of programs won't compile anymore.
They all die with an "internal compiler error" and all these because
of "-skells.c" files.
Also, they all die with that "-skels.c:1284: Internal compiler error in
eliminate_regs, at reload1.c" message.
At least these compilations die with the same error. Makes it easier to
find an answer.
Here is a example of one of the sources that won't compile anymore:
make[4]: Entering directory `/usr/src/redhat/BUILD/ORBit-0.5.8/src/services/name'
gcc -DHAVE_CONFIG_H -I. -I. -I../../.. -I. -I../../../src -I../../../src/ORBitutil -I../../../src -I/usr/include/glib-1.2 -I/usr/lib/glib/include -g -O2 -mcpu=ultrasparc -Wall -c new-name-server.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../.. -I. -I../../../src -I../../../src/ORBitutil -I../../../src -I/usr/include/glib-1.2 -I/usr/lib/glib/include -g -O2 -mcpu=ultrasparc -Wall -c CosNaming-skels.c
CosNaming-skels.c: In function `_ORBIT_skel_CosNaming_NamingContext_list':
CosNaming-skels.c:1284: Internal compiler error in eliminate_regs, at reload1.c:2529
Please submit a full bug report.
See <URL:http://bugzilla.redhat.com/bugzilla/> for instructions.
make[4]: *** [CosNaming-skels.o] Error 1
make[4]: Leaving directory `/usr/src/redhat/BUILD/ORBit-0.5.8/src/services/name'make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/usr/src/redhat/BUILD/ORBit-0.5.8/src/services'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/src/redhat/BUILD/ORBit-0.5.8/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/redhat/BUILD/ORBit-0.5.8'
make: *** [all-recursive-am] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.36960 (%build)
It's alway a <blahblah>-skels.c file that failes. This happens to bonobo,
ORBit, gtkhtml.
I'm dead in the water and i haven't got a clue what happened or what
causes this.
The versions of Bonobo and ORBit that i want to compile are actually
recompilations. I build these versions before (orbit v0.5.8 and bonobo
1.0.7).
The reason for this seamingly unnescessary compilation came when i tried
to upgrade gtkhtml to version 0.11.1.
I need that version to compile Evolution 0.12 (beta-2).
The compile gtkhtml 0.11.1(from ftp.ximian.org) died on such a
"<something>-skell.c" file.
However, when i did compile without bonobo support it compiled
fine. So i thought, there must be something wrong with bonobo.
I tried to recompile bonobo 1.0.7 only to find out that i would not
compile anymore. Dies on a "-skels.c" file. Hey, i see a pattern here i
thought.
The message was about an ORBit related file. So let's recompile ORBit
0.5.8 just for a test. Bingo, won't recompile anymopre either. Again dies
on a "-skels.c".
Can anyone please send me in the direction of a solution. My system is
fucked up and i don't know why. Normally one would downgrade the last
package from the time before the trouble began etc. but i don't see a
link to something i installed/upgraded before. And i can't downgrade half
my system. that's undo-able.
It's always these <something>-skells.c file that kill a compile and it
seems to be gnome related.
Please help,
Steven
welke redhat?
redhat is vrij kut qua compiler en libraries, zeer knap zoals zij alpha-compilers à la windows als stabiel durven mee te leveren.....
Ik zou zeggen, download alle updates van www.redhat.com en probeer nogmaals.
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Trek gcc 2.93.3 of gcc 3.0 van het net. Aan internal compiler errors doe je weinig. 3.0 draait prima hier, de meeste ICE's die ik had zijn opgelost.
