Gaming PC for 2k, 144hz
  • fredddy
  • Registratie: Maart 2020
  • Laatst online: 18-02-2025
Hello dear Tweakers!
I'm planning to buy a PC for home, that would be used for home stuff, work and gaming 50/50. My budget is ~1800-2000.
Home usage would include video editing (amateur, GO pro style videos from vacation, non-professional), programming and other less demanding stuff.
Gaming - 2k, non-competitive gaming. I'd like it to handle 144hz just not to be an outsider =)
I'm Intel guy, well, that's just a fact.
What I want from PC:
- it should work
- be moderately quiet
What I don't want and not planning to do:
- overclock anything, except setting XMP profile for the memory
- I don't want to have too much illumination
- I won't be sad if instead of 130fps I'll get 120 because of my hardware
Comments from my list:
- 9700f - as I don't want to overclock and I'll have external video card, why pay extra for 9700K?
Doubts:
- watercooling - seems like this stuff is more or less stable and doesn't break a lot, but I have zero experience and hope installation wouldn't be that hard
Questions to those, who know much more than me:
1) memory - is one that I've chosen fine?
2) is selected power supply fine?
3) should I select a regular fan instead of watercooling?
Thanks for your comments and I'm sorry, that this message is not in Dutch =)
https://tweakers.net/pricewatch/bestelkosten/2242482
1ProcessorsIntel Core i7-9700F Boxed€ 336,50€ 336,50
1MoederbordenGigabyte Z390 Gaming X€ 143,16€ 143,16
1VideokaartenGigabyte GeForce RTX 2080 Super Gaming OC 8G (rev. 2.0)€ 784,06€ 784,06
1BehuizingenCooler Master MasterBox MB520 RGB€ 66,01€ 66,01
1WaterkoelingCooler Master MasterLiquid 240€ 62,50€ 62,50
1Geheugen internG.Skill Ripjaws V F4-3200C16D-32GVK€ 155,45€ 155,45
1VoedingenCorsair TX650M V2€ 89,90€ 89,90
1Solid state drivesXPG SX8200 Pro 1TB€ 165,46€ 165,46
1UPS en stekkerdozenAPC Back-UPS ES 550VA (NL/DE stekker)€ 89,-€ 89,-
Bekijk collectie
Importeer producten
Totaal€ 1.892,04
  • MAX3400
  • Laatst online: 23-10 08:51
MAX3400
XBL: OctagonQontrol
  • Uszka
  • Registratie: Maart 2018
  • Laatst online: 01:10
Intel fan of niet, met Ryzen doe je domweg een betere koop.
Een budget waterkoeler is nooit een goed idee en zeker die van CM niet. De Masterliquid is luid en heeft een vrij slechte pomp. Beter een goede luchtkoeler voor dat geld.
  • fredddy
@MAX3400 thanks for your reply. Do you have any suggestions for the regular fan that would work for my set up?
  • fredddy
@MAX3400 I wanted to add something to protect from electricity spikes (and this UPS has good reviews). Apartment where I live has some problems with sockets (I recently caused an electricity shut down just by plugging my laptop charger, followed by a flash). So protecting 1800 purchase seems like a must in my case.
  • D-dark
  • Laatst online: 23:31
Dit zijn de standaard aanbevelingen qua luchtkoelers:
pricewatch: Scythe Mugen 5 PCGH Edition
pricewatch: be quiet! Dark Rock Pro 4
  • fredddy
@D-dark thanks for your suggestion! TDP for i7-9700f is 65W. Would it be reasonable to opt out for a smaller cooler, like https://tweakers.net/pric...-rock-slim/specificaties/ (TDP 180W)?
  • D-dark
@fredddy Waarom niet. Al zou ik dan voor de Scythe gaan. Die is een stuk stiller dan de Dark Rock slim.
  • fredddy
@D-dark I changed the cooler to suggested Scythe in my list. It looks massive but if it's quiet, then it's gonna serve it's purpose.
If there is a chance you can give your opinion on memory and power supply, I'd appreciate that. Anyway, thanks for your help!
  • D-dark
@fredddy
De koeler is behoorlijk groot maar moet passen. Je houd 20 mm over qua ruimte.
145,5 hoog en in je kast past 165.
Qua geheugen ga je voor een Intel processor en die is minder veeleisend dan de AMD Ryzen's
De Ripjaws zijn goed geprijsd en zullen werken. Wil je iets nieuwer geheugen dan kan je gaan voor: pricewatch: Crucial Ballistix Sport AT BLS2K16G4D32AEST
Wat betreft je voeding zou je kunnen kijken naar de pricewatch: Seasonic Focus GX-650 Redelijk recente voeding welke goed uit de reviews komt.
