Ik heb bij mijn DVD speler geen afspeel applicatie gekregen, en ik wil wel graag DVD's kijken met me pc. Dus vroeg ik me af of er gratis DVD afspeel software bestaat? WinDVD, PowerDVD, zijn alleen maar trials voor...
Die bestaat! Het heet Freedvd
ftp://ftp.cdrom.com/.2/sac/graph/freedvd.zip
De website van de makers www.mapleware.com is om de een of andere reden uit de lucht..
ST03R! meteen ff proberen. Alvast bedankt he
What do you think about this?
Here is a little Registry hack which allows you to play your DVD movies using Microsoft Windows Media Player2 v6.4 (WMP6) 32-bit for Windows 9x/NT.
If you are using Microsoft Windows Media Player2 v7.0/7.1 (WMP7) 32-bit for Windows 98/2000/ME, note that the DVD play feature has been disabled.
After installing WMP6, run Regedit and go to:
HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\Player\Settings
Right-click in the right hand pane -> select New -> String Value -> name it EnableDVDUI. Double-click on it -> type yes in the Value data box -> click OK.
Close the Registry Editor and restart Windows when done.
From now on you can open Media Player2 -> click File -> Open -> select DVD -> finally hit the Play button.
You'll also notice a new DVD icon which shows the DVD menu when clicked.
You can also use the Microsoft free dedicated DVD Player included on the Windows 98/98 SE(U) Setup CD-ROM. Pop in your Setup CD (replace the CD-ROM/DVD drive letter if different on your system) and then run:
EXTRACT /A /L %temp% D:\WIN98\BASE4.CAB DVD*.*
Now you should see these 5 files extracted into your TEMP directory (default is C:\Windows\Temp): DVDPLAY.CHM, DVDPLAY.CNT, DVDPLAY.EXE, DVDRGN.EXE and DVDPLAY.HLP. Move the .CHM, .CNT and .HLP files to C:\Windows\Help and the two executables (.EXE) to C:\Windows\System (if you installed Windows 98/98 SE into C:\Windows, otherwise sustitute the folder names to match yours).
Create a shortcut to Dvdplay.exe, eventually on your Desktop, if you watch a lot of DVD movies.
Note that you also need to install the 32-bit DVD Drivers/Codecs, i.e. Microsoft DirectX Media 6 or CineMaster, to be able to use ANY DVD player.
move naar [forum=10]
Simpel ding, zonder toeters en bellen (zoals bij Powerdvd), maar werkt prima.Op zaterdag 04 augustus 2001 20:17 schreef joey6666 het volgende:
