Max payne cheats here !!
  • 73 views sinds 30-01-2008
  • Mary Wana
  • Laatst online: 28-07 22:43
Mary Wana
keyboard nut
ik heb even een probleempje ik heb lekker cewle cheats gevonden maar ut werkt niet :(
kan iemand me ffies helpen , ik wil alleen fatsoenlijke wapens hebben :7
Max Payne
PLATFORM: PC
SUBMITTED BY: Numerous Sources
Related Links:
- SUBMIT YOUR CHEATS
Activate Cheats
To get access to the game console, you need to start maxpayne.exe with the command line parameter "-developer". Once you have the game running in developer mode, you get access to the game console with [F12].
Example: C:\maxpayne\maxpayne.exe -developer
See our "Cheat Essentials" page for more info on command-line shortcuts.
Cheat Codes
Press [F12] to bring up the console, then type: Code Result
coder God Mode, All Weapons, Unlimited Ammo, etc.
god God Mode
mortal God Mode Off
getallweapons All Weapons
getinfiniteammo Unlimited Ammo
noclip No Clipping Mode
noclip_off No Clipping Mode Off
getbullettime Fill Up When Bullet-Time Runs Out
showfps Show Frame Rate
getpainkillers Get 8 PainKillers
c_addhealth ( 100 ) Add 100 to Health
jump10 Jump Higher (set to 20 or 30 for even higher)
SetWoundedState Walk as if Wounded
SetNormalState Walk Normally
Get Item Cheats
You can use the "get" command to add individual weapons and items to your arsenal:
GetBaseballbat
GetBeretta
GetBerettaDual
GetDualBeretta
GetDesertEagle
GetSawedShotgun
GetPumpShotgun
GetJackhammer
GetIngram
GetIngramDual
GetDualIngram
GetMP5
GetColtCommando
GetMolotov
GetGrenade
GetM79
GetSniper
GetHealth
GetPainkillers
GetBulletTime
Easter Egg
In Act 3: Level 4 (the garage), there is an Easter Egg featuring members of Max Payne's production team and some surprises. After the opening animation ends, take out the four guys that the car has dropped off. Now, before entering the garageon the right, face the garage and look just to the right of the opening. There are 3 barrels (one, and then two on top of each other), and an A/C unit coming out of the wall. Jump from one to another to reach the roof of the garage. You will now be facing a little shack on the roof, with a door-shaped section painted slightly lighter than the rest -- shoot this with any weapon, and it will fall away, leading to a room with a small grating on the floor. Stand on the grate, and you will fall into a room with a dead hostage, a sniper rifle and ammo, and a radio that plays a conversation between members of the production team with a bit of humor at the end.
XP2600+ @ 2500mhz 1024mb Twinmos PC2700 @ CS2 WD1800JB Plextor 40x CDRW Ti 4600 ULTRA
goed lezen? en andere topic lezen?
  • JeroenNietDoen
  • Laatst online: 15:21
het werkt niet...wat werkt er dan niet?
  • Mary Wana
Mary Wana
keyboard nut
als ik bij mijn snelkoppeling
dit
"C:\Program Files\Max Payne\MaxPayne.exe"
naar dit verander
"C:\Program Files\Max Payne\MaxPayne.exe"-developer
dan wilt hij eht neit veranderen , zegt dat het niet kan end at ik eht mot controlleren zelfs zonder al die "
  • Sick Nick
  • Laatst online: 15:05
Sick Nick
Drop the top!
Op zaterdag 04 augustus 2001 17:36 schreef funkflex het volgende:
dit
naar dit verander
Je moet ook zo doen:
"C:\Program Files\Max Payne\MaxPayne.exe" -developer
Dus met een spatie tussen MaxPayne.exe" en -developer
  • MWAD
  • Laatst online: 22-12-2025
MWAD
Morron With A Dress
SNEUE HONDEN JE GAAT TOCH NIET CHEATEN
het is best wel te doen zonder cheats , het is mij ook gelukt!!!!!
De Som van de Momenten ten opzichte van punt " A " = NUL
Op zaterdag 04 augustus 2001 17:56 schreef MWAD het volgende:
Ja mij ook hoor :)
jah,duh is no best wel makkelijk spel...
  • IceStorm
  • Laatst online: 25-08 20:43
IceStorm
This place is GoT-like!!!
Argh, haast.
Ok, niet hier, ander topic kun je verder gaan. Zoek :D
