Precies iedere minuut 3 seconden packet loss?
  • Damsplaat
  • Laatst online: 07-10 20:02
Ik had wat haperingen bij Steam Remote play van desktop naar laptop over de wifi. Nu ben ik er wat verder ingedoken en zie ik structureel dat er precies iedere minuut ongeveer 3-5 seconden heel veel packet loss is.
Met iperf3 steeds dit testje gedraaid vanaf mijn laptop:
Bash:
iperf3 -u -b50m -R -t 300
Zie hieronder voor resultaat, heb de regels zonder packet loss er tussen uit geknipt:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
Connecting to host x, port 5201
Reverse mode, remote host x is sending
[  5] local x port x connected to x port 5201
[ ID] Interval           Transfer     Bitrate         Jitter    Lost/Total Datagrams
[  5]   0.00-1.00   sec  5.40 MBytes  45.3 Mbits/sec  0.526 ms  0/3913 (0%)
[  5]   1.00-2.00   sec  5.96 MBytes  50.0 Mbits/sec  0.561 ms  0/4318 (0%)
[  5]   2.00-3.00   sec  5.96 MBytes  50.0 Mbits/sec  0.474 ms  0/4319 (0%)
[  5]   3.00-4.00   sec  5.96 MBytes  50.0 Mbits/sec  0.475 ms  0/4316 (0%)
[  5]  42.00-43.00  sec  5.96 MBytes  50.0 Mbits/sec  0.654 ms  0/4315 (0%)
[  5]  43.00-44.00  sec  5.12 MBytes  42.9 Mbits/sec  0.024 ms  0/3709 (0%)
[  5]  44.00-45.00  sec  3.47 MBytes  29.0 Mbits/sec  0.015 ms  2410/4922 (49%)
[  5]  45.00-46.00  sec  3.35 MBytes  28.1 Mbits/sec  0.030 ms  1281/3708 (35%)
[  5]  46.00-47.00  sec  4.07 MBytes  34.3 Mbits/sec  0.516 ms  1981/4930 (40%)
[  5]  47.00-48.00  sec  5.95 MBytes  50.0 Mbits/sec  0.572 ms  0/4312 (0%)
[  5]  48.00-49.00  sec  5.96 MBytes  50.0 Mbits/sec  0.537 ms  0/4318 (0%)
[  5] 102.00-103.00 sec  5.96 MBytes  50.0 Mbits/sec  0.025 ms  0/4318 (0%)
[  5] 103.00-104.00 sec  5.96 MBytes  50.0 Mbits/sec  0.595 ms  0/4318 (0%)
[  5] 104.00-105.00 sec  3.69 MBytes  31.0 Mbits/sec  0.037 ms  1413/4086 (35%)
[  5] 105.00-106.00 sec  3.63 MBytes  30.4 Mbits/sec  0.027 ms  1026/3658 (28%)
[  5] 106.00-107.00 sec  4.22 MBytes  35.4 Mbits/sec  0.539 ms  2153/5206 (41%)
[  5] 107.00-108.00 sec  5.96 MBytes  50.0 Mbits/sec  0.501 ms  0/4313 (0%)
[  5] 108.00-109.00 sec  5.97 MBytes  50.0 Mbits/sec  0.457 ms  0/4320 (0%)
[  5] 162.00-163.00 sec  5.96 MBytes  50.0 Mbits/sec  0.030 ms  0/4314 (0%)
[  5] 163.00-164.00 sec  5.97 MBytes  50.0 Mbits/sec  0.029 ms  0/4320 (0%)
[  5] 164.00-165.00 sec  3.92 MBytes  32.8 Mbits/sec  0.042 ms  784/3622 (22%)
[  5] 165.00-166.00 sec  3.21 MBytes  26.8 Mbits/sec  0.032 ms  2260/4581 (49%)
[  5] 166.00-167.00 sec  3.79 MBytes  31.9 Mbits/sec  0.030 ms  1828/4569 (40%)
[  5] 167.00-168.00 sec  5.63 MBytes  47.2 Mbits/sec  0.570 ms  419/4493 (9.3%)
[  5] 168.00-169.00 sec  5.98 MBytes  50.1 Mbits/sec  0.392 ms  0/4328 (0%)
[  5] 169.00-170.00 sec  5.95 MBytes  49.9 Mbits/sec  0.438 ms  0/4308 (0%)
[  5] 222.00-223.00 sec  5.97 MBytes  50.0 Mbits/sec  0.040 ms  0/4320 (0%)
[  5] 223.00-224.00 sec  5.95 MBytes  49.9 Mbits/sec  0.052 ms  0/4311 (0%)
[  5] 224.00-225.00 sec  5.18 MBytes  43.3 Mbits/sec  0.016 ms  540/4291 (13%)
[  5] 225.00-226.00 sec  3.43 MBytes  28.8 Mbits/sec  0.011 ms  1622/4106 (40%)
[  5] 226.00-227.00 sec  3.12 MBytes  26.2 Mbits/sec  0.014 ms  1989/4250 (47%)
[  5] 227.00-228.00 sec  4.65 MBytes  39.0 Mbits/sec  0.039 ms  1246/4615 (27%)
[  5] 228.00-229.00 sec  5.96 MBytes  50.0 Mbits/sec  0.545 ms  0/4316 (0%)
[  5] 229.00-230.00 sec  5.96 MBytes  50.0 Mbits/sec  0.032 ms  0/4316 (0%)
[  5] 283.00-284.00 sec  5.96 MBytes  50.0 Mbits/sec  0.496 ms  0/4316 (0%)
[  5] 284.00-285.00 sec  5.96 MBytes  50.0 Mbits/sec  0.454 ms  0/4318 (0%)
[  5] 285.00-286.00 sec  3.52 MBytes  29.6 Mbits/sec  5.839 ms  1763/4314 (41%)
[  5] 286.00-287.00 sec  4.08 MBytes  34.1 Mbits/sec  0.060 ms  697/3652 (19%)
[  5] 287.00-288.00 sec  3.95 MBytes  33.3 Mbits/sec  0.036 ms  2120/4981 (43%)
[  5] 288.00-289.00 sec  5.96 MBytes  50.0 Mbits/sec  0.453 ms  0/4315 (0%)
[  5] 299.00-300.00 sec  5.97 MBytes  50.1 Mbits/sec  0.453 ms  0/4321 (0%)
[  5]   0.00-300.00 sec  1.75 GBytes  50.0 Mbits/sec  0.000 ms  0/1294494 (0%)  sender
[SUM]  0.0-300.0 sec  495 datagrams received out-of-order
[  5]   0.00-300.00 sec  1.71 GBytes  49.0 Mbits/sec  0.453 ms  25532/1294494 (2%)  receiver
iperf Done.
Precies iedere minuut wordt het signaal verstoord, maar ik heb geen idee waardoor. Wat ik heb geprobeerd:
  • Zonder wifi, helemaal bekabeld: geen packet loss. Ligt dus niet aan router/bedrading in huis oid.
  • Verschillende AP's, ik heb er drie. allemaal zelfde beeld. Eentje hangt in de schuur achter in de tuin, 0p 15m van het huis. Lijkt me dat hetdus geen lokale verstoring kan zijn.
  • Op zowel 2.4Ghz als 5Ghz zelfde problemen, ligt dus niet aan de exacte wifi band. Mijn AP's hebben ook allemaal een andere band
  • Zowel vanaf mijn Macbook als een desktop met wifi zie ik dit probleem, dus daar zou het ook niet aan moeten liggen
Wat zou deze periodieke wifi verstoring kunnen veroorzaken, en wat zou ik er aan kunnen doen? Iemand een idee, ik weet het niet meer. Ik woon trouwens vlak bij het Prins Clausplein mocht dat van belang zijn.
Naar aanleiding vragen:
  • 3x Unifi AP-Lite, met controller, zie config hieronder
  • DHCP lease staat op 86000s
  • Wifi AI staat aan, 1x per dag
  • Airtime fairnes optie staat uit
  • Geen DPI, (zit ook geen USG tussen, dus dat kan ook niet)
  • Met wireshark zo goed als geen ander verkeer dan de iperf3 test
Ik heb net getest met een publieke iperf3 server, met mijn telefoon als AP (die verder niet op de wifi zit, alleen op mobiele netwerk), en macbook als client. Ik zie weer hetzelfde patroon: iedere minuut een hapering.we kunnen dus denk ik wel uitsluiten dat het aan mijn netwerk ligt.
[ Voor 4% gewijzigd door Damsplaat op 28-02-2020 11:03 ]
Beste antwoord (via Damsplaat op 28-02-2020 20:12)
  • padoempats
  • Laatst online: 06-10 14:03
Mac? Location services uitzetten en het is opgelost :)
Elke minuut checkt die service de wifi channels en dat zorgt voor korte happeringen. Doe maar een ping en dan alt-wifi icoontje, heb je het ook ff
[ Voor 65% gewijzigd door padoempats op 28-02-2020 19:21 ]
  • Damsplaat
O ja, alle AP's zijn van type Unify AP lite
  • Axewi
  • Laatst online: 08-10 13:00
Damsplaat schreef op vrijdag 28 februari 2020 @ 10:15:
Heb je ook een controller draaien? En zo ja hoe ziet die config eruit? En heb je dingen aanstaan als airtimefairness en fast roaming (802.11r)?
Als de lat te hoog ligt kun je er nog altijd onderdoor lopen.
  • pyrofielo
waar staat je DHCP lease time op?
Astennu lvl 110 Warrior - Bethesda lvl 104 Warlock - Ezrah lvl 110 Druid
  • lier
  • Laatst online: 18:44
lier
MikroTik nerd
Unifi heeft een aantal opties om WiFi te "optimaliseren". Maak je gebruik van bijvoorbeeld AI of auto channel? En zoals @Axewi terecht opmerkt: hoe ziet je config eruit (in de Controller, Settings, Maintenance kan je de 'Show System Config' vinden)? En hoe zit het met draadloze netwerken in de buurt?
  • Damsplaat
86400s
  • Damsplaat
lier schreef op vrijdag 28 februari 2020 @ 10:20:
Ik kan het even niet netjes formatten, maar dit is de config
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
version
5.12.35
DPI
Enabled
Geo IP Filtering
Disabled
Intrusion Prevention System
Enabled
Conn Monitor
Disabled
Remote Access
Enabled
AP
UAP-AC-Lite (3)
Network
LAN
Wireless Networks
Multicast And Broadcast Filtering
Guest Portal
Enabled
Authentication
Simple Password
Expiration
8h
Landing Page
Original
Portal Customization
Disabled
AP-Kantoor
UniFi AP-AC-Lite
4.0.80.10875
11 HT20 / Medium (13 dBm)
122 124,+1 VHT80 / High (23 dBm)
10 dBm / 13 dBm (EIRP)
20 dBm / 23 dBm (EIRP)
Off
Disabled
Disabled
Wire, 1,000 FDX
192.168.1.102
1d 13h 31m 49s
AP-Boven
UniFi AP-AC-Lite
4.0.80.10875
11 HT20 / Low (7 dBm)
106 100,+1 VHT80 / High (23 dBm)
4 dBm / 7 dBm (EIRP)
0
0
Off
Disabled
Disabled
Wire, 1,000 FDX
192.168.1.101
1d 13h 30m 16s
AP-Woonkamer
UniFi AP-AC-Lite
4.0.80.10875
1 HT20 / High (20 dBm)
42 36,+1 VHT80 / High (20 dBm)
17 dBm / 20 dBm (EIRP)
  • Damsplaat
  • HenkEisDS
  • Laatst online: 10-10 18:30
Heb je al eens geprobeerd te luisteren met Wireshark? Je zegt dat het zowel op 2.4 als op 5ghz is, dus je zou op een willekeurig kanaal eens kunnen kijken of er rond jouw verstoringen veel door de lucht gaat. Zou gek zijn dat dit dan op zowel 2.4 als op 5 ghz gebeurt, maar je weet het maar nooit.
Een magnetron zou nog kunnen, maar die doet dit nooit op zulke intervallen denk ik. Tenzij iemand hem op een hele lage stand heeft staan en het apparaat dus maar 5 seconden per minuut aan staat. Magnetrons kunnen volgens mij niet harder of zachter, alleen aan/uit.
  • Axewi
In je config zie ik zo niet echt een aanleiding, je zou DPI uit kunnen schakelen als je daar verder niets mee doet om de load wat te verminderen.
En de configuratie van de AP's zelf?
Afbeeldingslocatie: https://help.ubnt.com/hc/article_attachments/115019860888/Pasted_image_at_2017_08_18_02_04_PM.png
ps: probeer je vorig post aan te passen i.p.v. 3 keer achter elkaar te posten, dat waarderen ze hier niet zo :)
Axewi schreef op vrijdag 28 februari 2020 @ 10:32:
Ik mag hopen dat voor een thuisnetwerkje DPI gewoon aan moet kunnen staan zonder maximale load te verbruiken. :P
  • Damsplaat
Heb de openingspost aangepast, maar dus geen DPI op de access points, bovendien zijn er bedraad geen problemen, en dat gaat door dezelfde router
  • pyrofielo
Heb je je wireless kanalen vaststaan?
  • Damsplaat
Ik heb net getest met een publieke iperf3 server, met mijn telefoon als AP (die verder niet op de wifi zit, alleen op mobiele netwerk). Ik zie hetzelfde patroon: iedere minuut een hapering.we kunnen dus denk ik wel uitsluiten dat het aan mijn netwerk ligt.
[ Voor 11% gewijzigd door Damsplaat op 28-02-2020 11:02 ]
  • Remz
  • Laatst online: 10-10 08:14
Dus het ligt niet aan je netwerk, want je ziet de drops zowel op je thuis verbinding als op je 4G verbinding.
Bekijk ook eens de event log. Misschien crasht je netwerk driver wel regelmatig.
[ Voor 17% gewijzigd door Remz op 28-02-2020 11:06 . Reden: Te snel gelezen ]
  • Falcon
  • Laatst online: 18:45
Falcon
DevOps/Q.A. Engineer
Als ik https://iperf.fr/ mag geloven dan zijn er wat known issue’s rondom iperf zelf die ook dit gedrag kunnen verklaren.
Ik zou een “ping -t tweakers.net” uitvoeren en bekijken of hier ook de packetloss zichtbaar is.
Das de baseline met kleine packages, daarna zou ik heel langzaam de brandbreedte en package grote gaan verhogen met iPerf. Kijk wanneer er kantelpunt ontstaat.
Parallel daar aan zou ik per testfase de lokale resources ook willen zien. Cpu, geheugen, je netwerkadapter metrics.
En de test met je mobiel als hotspot zou ik ook even ergens anders dan thuis uitvoeren, om echt verstoringen uit te sluiten binnen je eigen huis, al is die kans zeer klein.
[ Voor 52% gewijzigd door Falcon op 28-02-2020 11:21 ]
  • Mel33
  • Laatst online: 09-10 23:13
ter info ik krijg altijd een request time out bij ping -t tweakers.net
edit
Oh ships, dat heeft met mijn IPv6 te maken, (die uitzetten lost het op)
[ Voor 36% gewijzigd door Mel33 op 28-02-2020 11:34 ]
Ik ben zo blij dat de pen en de som nog steeds machtiger zijn dan het zwaard. ringo-remasterd
  • HenkEisDS
Mel33 schreef op vrijdag 28 februari 2020 @ 11:26:
edit
Ik niet. Best kans dat je eigen router/firewall het blokkeerd.
Afbeeldingslocatie: https://i.imgur.com/H4qNv55.png
[ Voor 3% gewijzigd door HenkEisDS op 28-02-2020 11:36 ]
  • Mel33
HenkEisDS schreef op vrijdag 28 februari 2020 @ 11:35:
ja kheb die ziggo compal, alles aan in de firewall op ip ipv6.
Is het dns? of het je een tip waar te kijken,
Missc heeft de ts dit ook
  • Damsplaat
Ik heb zojuist met een andere machine ook exact 1x per minuut verhoodge packet loss geconstateerd. (verbonden in interne netwerk, zal zo nog eens via telefoon proberen). Moest wel de bandbreedte wat opschroeven naar 200Mbit, en dan zag ik continu ongeveer 0.5% packet loss, met eens per minuut een enkele uitschieter naar 10%.
[ Voor 12% gewijzigd door Damsplaat op 28-02-2020 11:49 ]
  • Gomez12
  • Laatst online: 17-10-2023
Damsplaat schreef op vrijdag 28 februari 2020 @ 11:48:
Is dit wireless of niet?
Want het kan ook gewoon zijn dat je bijv een weerstationnetje buiten hebt met een ontvanger binnen en dat die 1x per minuut communiceert en dan je wifi stoort...
Wat je zou kunnen proberen is op een andere plek de test met je telefoon herhalen, als het dan niet zo is, dan ligt het aan je lokatie en is er iets wat daar stoort.
  • Damsplaat
Test met andere machine was wireless, zoals gezegd heb ik wired geen problemen. Heb al met drie verschillende AP's getest, die 20m uit elkaar staan. Maar ik kan de telefoon test natuurlijk herhalen op grotere afstand.
  • Gomez12
Damsplaat schreef op vrijdag 28 februari 2020 @ 11:55:
Denk met grotere afstand eens aan een andere stad oid, er is genoeg apparatuur die 1 km oid ver kan doordringen en dus kan storen.
  • Simba
  • Laatst online: 19:10
Tijd om op zoek te gaan naar draadloze zenders zoals weerstations oid.
En als dat niet lukt het Agentschap Telecom inlichten en laten uitpeilen.
  • gitaarwerk
gitaarwerk
Plays piano,…
Zit er nog een andere service die wellicht DHCP aanbied? je zegt dat er bedraad niets is, dus gok van niet. Tenzij die vaste ip's hebben wellicht.
[ Voor 44% gewijzigd door gitaarwerk op 28-02-2020 12:36 ]
Ontwikkelaar van NPM library Gleamy
  • dion_b
  • Laatst online: 15:55
dion_b
say Baah
Hier en daar is de draad een beetje warrig, maar klopt het dat je dit geprobeerd hebt:
- Mobiele telefoon ingesteld als AP, dan ander apparaat via WiFi verbonden met mobiel, dan via 4G naar buiten? En dan wel probleem?
- Laptop/telefoon van jou op andere locatie via WiFi verbonden? Geen probleem?
Zo ja heb je je gehele eigen netwerk uitgesloten en moet het in de lucht zitten bij jou in de buurt. Zo niet, doe de ontbrekende test hierboven.
Als het daadwerkelijk in de lucht moet zitten *en* zowel 2.4GHz als 5GHz wegblaast is het een raar geval. Ik heb het exact een keer gezien: in A'dam, vlakbij marineterrein. Er stond een marineschip afgemeerd met een ronddraaiend radar erop. Iedere keer dat de radar onze kant op stond was het raak: alle WiFi dood. Die radar zond niet eens uit op de WiFi-frequenties, maar zond dermate hard uit dat ontvangers overstuurd werden en dus uitsloegen op hun eigen frequenties, vgl iets proberen te lezen vlak naast de zon. Toen het schip weg ging, was probleem ook weg.
Het kan ook iets veel kleiners dichterbij (binnenhuis) zjn.
Kun je in dat geval je omgeving beschrijven. Waar woon je? Wat zit er in de onmiddellijke omgeving qua bedrijvigheid? En hebben de buren ook last van zelfde probleem? (zo ja, dan is het iets groots, zo nee, dan is het iets bij jou binnenhuis)
Oslik, blyat! Oslik!
  • Damsplaat
dion_b schreef op vrijdag 28 februari 2020 @ 12:46:
Exact dit geprobeerd, en dan ook precies 1 keer per minuut een storing. Net ergens op bezoek geweest op ongeveer 500m afstand van mijn huis, en met mijn telefoon + laptop zelfde testje gedaan, met zelfde resultaat: 1 keer per minuut een storing.
Dus tenzij ik iets over het hoofd zie is er een externe oorzaak die over een breed spectrum 1 keer per minuut in (een gedeelte van) Voorburg overlast geeft.
Dit is wat ik heb gebruikt als test:
iperf3 -c ping-ams1.online.net -u -b50m -R -t 300 -p 5200 -l 1500
Iemand zin om dit testje te herhalen? Met name in regio Den Haag? Eventuele benodigde bandbreedte om te reproduceren zou natuurlijk kunnen variëren. Meer dan 50Mbit haal ik niet op mijn telefoon. Nu even kijken of ik mijn android telefoon wired kan tetheren is aan een macbook
  • Simba
Een klus voor Agentschap Telecom dus om de stoorbron uit te peilen.
  • HenkEisDS
Net maar even iperf3 geinstalleerd op mijn linux vm. Komt maar 1 of 2 keer keer in die 300 seconden onder de 4 Mbit/s en de seconde erna is de snelheid dubbel.
Zie dit maar als je nulproef:
Amsterdam Centrum: Geen problemen
Beloof je ons wel op de hoogte te houden? Vervelend voor jou, maar wel super interessant om te volgen!
[ Voor 18% gewijzigd door HenkEisDS op 28-02-2020 13:33 ]
  • Simba
Precies elke minuut lijkt me geen (scheeps) radar.
  • DataGhost
  • Laatst online: 09-10 13:23
DataGhost
iPL dev
Het enige wat je nog niet veranderd hebt is je telefoon. Kijk daar eens naar voordat je begint over "WiFi-jamming" in regio Den Haag zonder ladingen storingsmeldingen. TS niet goed onthouden nadat alle andere berichten het over een telefoon hadden.
[ Voor 20% gewijzigd door DataGhost op 28-02-2020 13:36 ]
  • Damsplaat
Ik ga even ergens koffie halen waar ze wifi hebben, stukje uit de buurt. Zal daar via telefoon als AP en via de open wifi testje doen. Afhankelijk van de resultaten zal ik wel/niet melding maken. Ben nu wel erg benieuwd waar het aan ligt. Zijn er beter testje om periodieke storingen te detecteren dan een 50mbit udp stream? Gaat wel hard zo met mijn telefoon data ;)
  • Damsplaat
De koffie is lekker, maar wifi is sowieso slecht hier.
- laptop op open wifi: Structureel 7-76% packet loss.
- laptop via telefoon: 1x per minuut storing op 10mbit.
- iperf3 vanaf telefoon (net een android iperf3 client gevonden): geen packet loss op 4g / 1mbit (-b50m wordt genegeerd lijkt het)
Dus nog even geen conclusies. Ga nog stukje verder weg om te kijken of ik met laptop - telefoon/4g 50mbit zonder packet loss kan halen ergens. Als dat niet lukt ligt het mogelijk aan mijn spullen. Lukt dat wel, dan moet er een externe oorzaak zijn lijkt me an zal ik Agentschap inlichten
  • Mel33
Je hebt wel op malware enz gelet?
  • HenkEisDS
Moet dit niet -b 50M zijn?
  • mcDavid
  • Laatst online: 05-10 22:13
Damsplaat schreef op vrijdag 28 februari 2020 @ 14:16:
Vertel eens wat meer over de omgeving? Zit je in een drukke stad, hutje op de hei, industrieterrein, what?
Probeer evt. voor de grap eens al je eigen apparatuur uit te schakelen (alle stoppen eruit, behalve misschien eentje voor je accesspoint)
En werk je met 2,4GHz of met 5GHz wifi? In dat laaste geval: Gebruik je de DFS channels?
  • fastedje
  • Registratie: Oktober 2016
  • Laatst online: 28-09 05:35
Ping is niet echt betrouwbaar als netwerk test-tool, je zou beter een curl kunnen doen op een simpele pagina. Probleem met ping is dat het ICMP gebbruikt wat op veel routers en firewalls geblokeerd.
  • Beste antwoord ✓
  • padoempats
  • Damsplaat
padoempats schreef op vrijdag 28 februari 2020 @ 19:20:
Bedankt, dat verklaart alles! Blijkbaar is de scan zo sterk dat ie ook de wifi van andere apparaten in de buurt stoort, want andere apparaten hadden onderling ook last 1x per minuut interferentie. Heb het nu uitgezet, eens kijken of ik nu eindelijk fatsoenlijk kan streamen over wifi!
