VBA " out of memory"
  • Sr Juan
  • Laatst online: 25-09 21:32
Sr Juan
7 uur later dan bij jou in NL
Mijn vraag
Ik heb een VBA script geschreven, maar ik krijg nu "out of memory" meldingen elke keer als ik de userform afsluit. Hoe krijg ik dat weg
VBA 7.1
Office 365
Dim iRow As Integer (stond als long)
Option Explicit
Dim Rng As Range, fnd As Range
Dim Ctrl As Control
Dim iRow As Integer
Dim wsAE As Worksheet
In dit stuk code was resize gezet op (,50) Nu 22.
Private Sub CMB_addnew_Click()
Set wsAE = Worksheets("INFO_PAGO")
If MsgBox("Correct entry?", vbYesNo + vbQuestion, "Check the data!") = vbNo Then Exit Sub
iRow = wsAE.Cells.Find(What:="*", SearchOrder:=xlRows, SearchDirection:=xlPrevious, LookIn:=xlValues).Row + 1
wsAE.Cells(iRow, 1).Resize(, 22).Value = Array(C_INVENTARIO.Value, T_M2.Value, T_ARRENDADOR.Value, T_AREA.Value, T_SUELO.Value, _
C_MET.Value, T_PROP.Value, T_REF.Value, T_NOTA.Value, T_ABONO.Value, T_RAD.Value, _
T_NRAD.Value, T_NPAGO.Value, C_CONCEPTO.Value, T_CP.Value, T_TRANS.Value, T_CALLE.Value, T_COL.Value, _
T_CARGO.Value, T_PAGO.Value, NEWD.Value, ENDD.Value)
'Columns.AutoFit
MsgBox "The new entry has been saved.", vbInformation, "Done"
For Each Ctrl In Controls
    If TypeName(Ctrl) = "TextBox" Or TypeName(Ctrl) = "ComboBox" Then Ctrl.Value = ""
Next Ctrl
LB_01.ListIndex = -1
LB_01.TopIndex = 0
Call UserForm_Initialize
End Sub
hele VBA code
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
Option Explicit
Dim Ctrl As Control
Dim iRow As Integer
Private Sub C_INVENTARIO_Click()
T_AREA.Value = C_INVENTARIO.Column(1)
T_M2.Value = C_INVENTARIO.Column(3)
T_SUELO.Value = C_INVENTARIO.Column(4)
T_COL.Value = C_INVENTARIO.Column(9)
T_PROP.Value = C_INVENTARIO.Column(13)
T_ARRENDADOR.Value = C_INVENTARIO.Column(11)
T_CALLE.Value = C_INVENTARIO.Column(12)
T_CP.Value = C_INVENTARIO.Column(14)
NEWD.Value = C_INVENTARIO.Column(5)
ENDD.Value = C_INVENTARIO.Column(6)
DAYSEND.Value = C_INVENTARIO.Column(7)
T_EST.Value = C_INVENTARIO.Column(16)
End Sub
'Columns.AutoFit
Next Ctrl
LB_01.TopIndex = 0
End Sub
Private Sub CMB_change_Click()
Set wsAE = Worksheets("IPSA_DATA")
Set Rng = wsAE.Range("A2:A" & wsAE.Cells(Rows.Count, "A").End(xlUp).Row)
  MsgBox "First choose a item in the list!", vbCritical, "Attention!"
  Exit Sub
Set fnd = Rng.Find(What:=T_id.Value, LookIn:=xlValues, Lookat:=xlWhole)
  If LB_01.ListIndex = -1 Then
  Exit Sub
  Else
    If T_id = vbNullString Then
        MsgBox "Customizing is not possible, no entries found", vbExclamation, "Attention!"
        Exit Sub
    ElseIf Not fnd Is Nothing Then
        Application.EnableEvents = False
       wsAE.Cells(fnd.Row, "A").Resize(, 22).Value = Array(C_INVENTARIO.Value, T_M2.Value, C_INVENTARIO.Value, T_AREA.Value, T_SUELO.Value, _
C_MET.Value, T_PROP.Value, T_REF.Value, , T_NOTA.Value, T_ABONO.Value, T_RAD.Value, _
T_CARGO.Value, T_PAGO.Value, T_CP.Value, NEWD.Value, ENDD.Value)
'Columns.AutoFit
MsgBox "The changes have been saved.", vbInformation, "Done"
      Application.EnableEvents = True
    End If
Next Ctrl
LB_01.TopIndex = 0
    End If
End Sub
Private Sub CMB_clear_Click()
Next Ctrl
LB_01.TopIndex = 0
End Sub
Private Sub CMB_close_Click()
Unload Me
End Sub
Private Sub LB_01_Click()
T_id.Value = LB_01.Column(0)
C_INVENTARIO.Value = LB_01.Column(1)
T_TRANS.Value = LB_01.Column(2)
T_ARRENDADOR = LB_01.Column(3)
T_AREA.Value = LB_01.Column(4)
T_SUELO.Value = LB_01.Column(5)
T_PROP.Value = LB_01.Column(6)
T_M2.Value = LB_01.Column(7)
T_CALLE.Value = LB_01.Column(8)
T_COL.Value = LB_01.Column(9)
T_CP.Value = LB_01.Column(10)
T_EST.Value = LB_01.Column(11)
NEWD.Value = LB_01.Column(12)
ENDD.Value = LB_01.Column(13)
C_CONCEPTO.Value = LB_01.Column(14)
T_CARGO.Value = LB_01.Column(15)
T_ABONO.Value = LB_01.Column(16)
C_MET.Value = LB_01.Column(17)
T_REF.Value = LB_01.Column(18)
T_PAGO.Value = LB_01.Column(19)
T_RAD.Value = LB_01.Column(20)
T_NRAD.Value = LB_01.Column(21)
T_NPAGO.Value = LB_01.Column(22)
T_NOTA.Value = LB_01.Column(23)
End Sub
Private Sub UserForm_Initialize()
LB_01.List = [database].Value
C_INVENTARIO.List = [datalist].Value
C_MET.List = [nouns].Value
C_CONCEPTO.List = [matgroup].Value
T_TRANS.Value = Now
End Sub
El trago de mezcal, como lo senos de las mujeres, uno es insuficiente, tres son demasiados
  • Sr Juan
Sr Juan
Mildpower schreef op dinsdag 11 februari 2020 @ 00:07:
[/code]
Ik denk dat ik het al gevonden heb, ik ben een .value vergeten in de T_ARRENDADOR!
Op dit moment geen meldingen meer :)
