apt/dslect probleem
Ik heb wat problemen met apt, weet iemand misschien hoe ik dit kan oplossen?. Hij wilt soms pakketjes niet installeren of eraf halen en dan krijg je de foutmelding die hieronder staat.
Ook apt-setup werkt niet meer.
boeffie:/home/taco# apt-get remove
Reading Package Lists... Done
Building Dependency Tree... Done
The following packages will be REMOVED:
  horde
0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 packages not fully installed or removed.
Need to get 0B of archives. After unpacking 1704kB will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 31698 files and directories currently installed.)
Removing horde ...
dpkg - warning: while removing horde, directory `/etc/horde' not empty so not removed.
Can't call method "template" on an undefined value at /usr/lib/perl5/Debian/DebConf/Question.pm line 251, <GEN0> chunk 1.
dpkg: error processing horde (--remove):
 subprocess post-removal script returned error exit status 29
Errors were encountered while processing:
 horde
E: Sub-process /usr/bin/dpkg returned an error code (1)
boeffie:/home/taco# apt-setup
Can't call method "template" on an undefined value at /usr/lib/perl5/Debian/DebConf/Question.pm line 251, <GEN0> chunk 6.
  • Valium
  • Laatst online: 23:37
Valium
- rustig maar -
Je perl-pakket is waarschijnlijk kapot of niet goed geinstalleerd. Probeer al je perl-pakketten eens opnieuw erop te zetten.
