  • JulianD123
  • Registratie: Januari 2020
  • Laatst online: 27-08 08:53
Ik heb zelf een triple pack zou ik er nog 1 toe kunnen voegen in het velop-beheer?
ps. ik heb alle 3 de kastjes aangesloten aan een switch
  • Malantur
Deze gezien?
https://www.linksys.com/us/support-article?articleNum=217438
How many Velop nodes can I add to my network?
You can add as many Velop nodes to your home as you’d like as every home is unique. Take your home’s layout into consideration when figuring out the optimal number of nodes you need for your home. This includes length, number of rooms, and any potential interference-inducing obstacles like brick walls, metal doors or large appliances.
Ideally the node connected to your modem should be centrally located in your home. It’s okay if that’s not possible in your particular setup, but we recommend doing so when you can. We typically recommend one to two nodes per floor. You can always start there and test out various ways of placing your nodes to maximize your coverage. Since every home is different, you can always add an additional node where needed.
If your home is already wired with ethernet connection, you can take advantage of these connections to increase the range of your Velop network and reduce the risk of Wi-Fi interference. For more information about this, click here.
[ Voor 26% gewijzigd door Malantur op 24-01-2020 11:47 ]
'Let's eat Grandma!' or, 'Let's eat, Grandma!'. Punctuation saves lives.
  • JulianD123
Nee die had ik nog niet gezien, Bedankt!
