MacBook Pro schakelt niet over van AC op (nieuwe) accu
Mijn vraag
Accu vervangen van Macbook Pro 13” A1425 (late 2012) door aftermarket accu Mayerinc – model A1437. Installatie zonder problemen, PRAM reset, accu opgeladen tot full charge, SMC reset gedaan.
Als ik de Magsafe oplader afkoppel schakelt de Macbook meteen uit.
Opstarten zonder de oplader lukt ook niet.
Old Battery Information:
Model Information:
Serial Number: C01329408FTF957AX
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 000a
Cell Revision: 1155
Charge Information:
Charge Remaining (mAh): 1943
Fully Charged: No
Charging: Yes
Full Charge Capacity (mAh): 1963
Health Information:
Cycle Count: 1078
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 700
Voltage (mV): 11769
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 28800
AutoPowerOff Enabled: 1
Current Power Source: Yes
DarkWakeBackgroundTasks: 1
Display Sleep Uses Dim: Yes
Hibernate Mode: 3
High Standby Delay: 4200
PrioritizeNetworkReachabilityOverSleep: 0
Standby Battery Threshold: 50
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
Display Sleep Timer (Minutes): 2
DarkWakeBackgroundTasks: 0
Hibernate Mode: 3
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x002b46f4
Charging: Yes
New Battery Information:
Model Information:
Serial Number: C01514309YEF90MA4
Manufacturer: Mayerinc
Device Name: A1437
Pack Lot Code: 3230
PCB Lot Code: 30db
Firmware Version: ddae
Hardware Revision: dac2
Cell Revision: 2b39
Charge Information:
Charge Remaining (mAh): 6735
Fully Charged: Yes
Charging: No
Full Charge Capacity (mAh): 6749
Health Information:
Cycle Count: 1
Condition: Normal
Amperage (mA): 0
Voltage (mV): 12839
AC Power:
Wake on LAN: Yes
Hibernate Mode: 3
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
Hibernate Mode: 3
Standby Delay: 4200
Standby Enabled: 1
UPS Installed: No
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x00ba
Charging: No
Wat ik al gevonden of geprobeerd heb.
Ik heb de oude accu weer geïnstalleerd en ondanks dat deze nog maar tot 1/3 van de originele capaciteit vasthoudt blijft de Macbook gewoon fuctioneren nadat ik de oplader afkoppel. Dat betekent dus dat er geen probleem is met het logic board of andere hardware onderdelen.
Het probleem lijkt te zijn dat het Macbook Pro power management systeem niet herkent dat de nieuwe accu is geïnstalleerd en/of volledig is opgeladen.
De enige verklaring die ik kan verzinnen is dat de nieuwe accu niet compatible is met de geïnstalleerde Firmware Version….of dat er een bug zit in de MacOS Catalina 10.15.2
MacBook Pro (Retina, 13-inch, Late 2012)
Processor 2,5 GHz Dual-Core Intel Core i5
Memory 8 GB 1600 MHz DDR3
Graphics Intel HD Graphics 4000 1536 MB
Serial number C02L60BYDR55
Ongeveer 1 jaar geleden heb ik het scherm en de SSD vervangen.
Wie weet wat het probleem is en hoe het opgelost kan worden?
  • rvanpruissen
  • Laatst online: 29-08 17:05
rvanpruissen
rePear.it
Dit is één van de weinige dingen waarbij een SMC-reset en PRAM-reset soms wat uithaalt IMHO.
