  • Yboyray
  • Registratie: April 2016
  • Laatst online: 06-02-2023
Ik krijg mijn Windows installatie niet op GPT en heb al meerdere dingen geprobeerd. Hij crashed (op de foto te zien) Afbeeldingslocatie: https://imgur.com/iQylQa0
Ik heb dit commanda ingevoerd:
C:\WINDOWS\system32>MBR2GPT.EXE /convert /allowfullos /logs:"C:\LOG
En dit is het log wat ik er uit heb gekregen
2020-01-14 13:05:49, Info MBR2GPT was explicitly asked to run in full OS mode.
2020-01-14 13:05:49, Info MBR2GPT: System disk number is 0
2020-01-14 13:05:49, Info MBR2GPT: Attempting to convert disk 0
2020-01-14 13:05:49, Info MBR2GPT: Retrieving layout of disk
2020-01-14 13:05:49, Info MBR2GPT: Initial partition information
2020-01-14 13:05:49, Info ===========================================================
2020-01-14 13:05:49, Info Partition layout for disk: 0
2020-01-14 13:05:49, Info Partition style : MBR
2020-01-14 13:05:49, Info MBR signature: 3640812
2020-01-14 13:05:49, Info Number of partitions : 1
2020-01-14 13:05:49, Info ===================PARTITION===============================
2020-01-14 13:05:49, Info Number: 1
2020-01-14 13:05:49, Info Type: 7
2020-01-14 13:05:49, Info Boot: Yes
2020-01-14 13:05:49, Info Recognized: Yes
2020-01-14 13:05:49, Info Style: 0
2020-01-14 13:05:49, Info Offset: 49383936
2020-01-14 13:05:49, Info Length: 480051984384
2020-01-14 13:05:49, Info Volume: \\?\Volume{c8d9a732-bb17-11e3-94f8-806e6f6e6963}\
2020-01-14 13:05:49, Info Drive: C:\
2020-01-14 13:05:49, Info NT Path: \Device\HardDisk0\Partition1
2020-01-14 13:05:49, Info ESP partition size will be 104857600
2020-01-14 13:05:49, Info MBR2GPT: Validating layout, disk sector size is: 512 bytes
2020-01-14 13:05:49, Info BCD: Opening store. Flags: 0x0
2020-01-14 13:05:49, Info BCD: Store path: "\??\GLOBALROOT\device\harddisk0\partition1\Boot\BCD"
2020-01-14 13:05:49, Info BCD: Loaded hive at BCD00000000
2020-01-14 13:05:49, Info BCD: Opening object {9dea862c-5cdd-4e70-acc1-f32b344d4795}
2020-01-14 13:05:49, Info FindOSPartitions: Default boot entry: {714E07B0-3614-11EA-B8F3-EE9FF8CDF64E}
2020-01-14 13:05:49, Info BCD: Opening object {714e07b0-3614-11ea-b8f3-ee9ff8cdf64e}
2020-01-14 13:05:49, Info VERBOSE: Device path: \Device\HarddiskVolume1
2020-01-14 13:05:49, Info VERBOSE: Dos path: \\?\GLOBALROOT\Device\HarddiskVolume1
2020-01-14 13:05:49, Info FindOSPartitions: Volume name for the default boot entry: \\?\Volume{c8d9a732-bb17-11e3-94f8-806e6f6e6963}\
2020-01-14 13:05:49, Info BCD: Opening object {3dac8c5a-3615-11ea-b8f3-ee9ff8cdf64e}
2020-01-14 13:05:49, Error GetOSDeviceVolume: Cannot get NT path for entry.[gle=0x000000ea]
2020-01-14 13:05:49, Error FindOSPartitions: Cannot get volume name for the recovery boot entry. Error: 0x000000EA[gle=0x000000ea]
2020-01-14 13:05:49, Error Cannot find OS partition(s) for disk 0[gle=0x000000ea]
2020-01-14 13:05:49, Info MBR2GPT: Partition information at error point
Ik heb ook een filmpje van de gebeurtenis
Het gaat in dit geval om een zeer oude laptop (XP/VISTA tijd) die vervangen moet worden door een nieuwe. het oude systeem support geen EUFI en het nieuwe geen legacy ik heb de schijf momenteel aangesloten op een computer die deze wel ondersteund
Ik heb al geprobeerd om via partition magic de OS partitie als eerste te zetten. Maar dit had geen invloed er zijn voor de rest geen partities aanwezig. Ik heb ook gepropeerd buiten de Windows instalatie(die van MBR naar GPT moet) dit commando uit te voeren voor de oude installatie dit had geen invloed.
[ Voor 0% gewijzigd door Yboyray op 15-01-2020 11:55 . Reden: extra toelichting, spelling en zin fouten ]
  • Wim-Bart
  • Laatst online: 10-01-2021
Wim-Bart
Zie signature voor een baan.
Om van MBR naar GPT te kunnen is er ongepartioneerde disk ruimte nodig.
Beheerders, Consultants, Servicedesk medewerkers. We zoeken het allemaal. Stuur mij een PM voor meer info of kijk hier De mooiste ICT'er van Nederland.
  • Yboyray
Wim-Bart schreef op dinsdag 14 januari 2020 @ 13:38:
Ik ga het zo direct proberen. maar zou Windows dit niet standaard al voor je moeten doen?
Erg bedankt voor het mee denken.
  • Brahiewahiewa
  • Laatst online: 30-09-2022
Brahiewahiewa
boelkloedig
Yboyray schreef op dinsdag 14 januari 2020 @ 13:46:
Nope: https://docs.microsoft.co...ows/deployment/mbr-to-gpt
QnJhaGlld2FoaWV3YQ==
  • TheVMaster
  • Laatst online: 23:43
TheVMaster
Moderator WOS
Titelfix MBT2GPT --> MBR2GPT
Thanks @Brahiewahiewa voor de tip
Mijn Apps: DiscVault - MealieShopper - SintMaarten - 3D Print Pricing
  • Yboyray
Ik heb dit geprobeerd maar mbr2gpt.exe crashed nu :/ .
Ik heb nogmaals de log bijgevoegd van het nieuwe probleem
2020-01-15 11:35:20, Info MBR2GPT was explicitly asked to run in full OS mode.
2020-01-15 11:35:20, Info MBR2GPT: Attempting to convert disk 0
2020-01-15 11:35:20, Info MBR2GPT: Retrieving layout of disk
2020-01-15 11:35:20, Info MBR2GPT: Initial partition information
2020-01-15 11:35:20, Info ===========================================================
2020-01-15 11:35:20, Info Partition layout for disk: 0
2020-01-15 11:35:20, Info Partition style : MBR
2020-01-15 11:35:20, Info MBR signature: 123173419
2020-01-15 11:35:20, Info Number of partitions : 1
2020-01-15 11:35:20, Info ===================PARTITION===============================
2020-01-15 11:35:20, Info Number: 2
2020-01-15 11:35:20, Info Type: 7
2020-01-15 11:35:20, Info Boot: Yes
2020-01-15 11:35:20, Info Recognized: Yes
2020-01-15 11:35:20, Info Style: 0
2020-01-15 11:35:20, Info Offset: 5239503360
2020-01-15 11:35:20, Info Length: 67315691520
2020-01-15 11:35:20, Info Volume: \\?\Volume{07577a2b-0000-0000-007a-4c3801000000}\
2020-01-15 11:35:20, Info Drive: C:\
2020-01-15 11:35:20, Info NT Path: \Device\HardDisk0\Partition2
2020-01-15 11:35:20, Info ESP partition size will be 104857600
2020-01-15 11:35:20, Info MBR2GPT: Validating layout, disk sector size is: 512 bytes
2020-01-15 11:35:20, Info BCD: Opening store. Flags: 0x0
2020-01-15 11:35:20, Info BCD: Store path: "\??\GLOBALROOT\device\harddisk0\partition2\Boot\BCD"
2020-01-15 11:35:20, Info BCD: Loaded hive at BCD00000000
2020-01-15 11:35:20, Info BCD: Opening object {9dea862c-5cdd-4e70-acc1-f32b344d4795}
2020-01-15 11:35:20, Info FindOSPartitions: Default boot entry: {714E07B0-3614-11EA-B8F3-EE9FF8CDF64E}
2020-01-15 11:35:20, Info BCD: Opening object {714e07b0-3614-11ea-b8f3-ee9ff8cdf64e}
2020-01-15 11:35:20, Info VERBOSE: Device path: \Device\HarddiskVolume2
2020-01-15 11:35:20, Info VERBOSE: Dos path: \\?\GLOBALROOT\Device\HarddiskVolume2
2020-01-15 11:35:20, Info FindOSPartitions: Volume name for the default boot entry: \\?\Volume{07577a2b-0000-0000-007a-4c3801000000}\
2020-01-15 11:35:20, Info BCD: Opening object {3dac8c5a-3615-11ea-b8f3-ee9ff8cdf64e}
2020-01-15 11:35:20, Error GetOSDeviceVolume: Cannot get NT path for entry.[gle=0x000000ea]
2020-01-15 11:35:20, Error FindOSPartitions: Cannot get volume name for the recovery boot entry. Error: 0x000000EA[gle=0x000000ea]
2020-01-15 11:35:20, Error Cannot find OS partition(s) for disk 0[gle=0x000000ea]
2020-01-15 11:35:20, Info MBR2GPT: Partition information at error point
2020-01-15 11:35:20, FatalError [0x090001] PANTHR Exception (code 0xC0000005: ACCESS_VIOLATION) occurred at 0x00CD9A89 in C:\WINDOWS\system32\MBR2GPT.EXE (+00029A89). Minidump attached (35523 bytes) to diagerr.xml and C:/LOG\mndC7FD.diagerr.mdmp.
  • Wim-Bart
Wim-Bart
CMD prompt wel als Administrator gestart? Run as Administrator.
  • Yboyray
Wim-Bart schreef op woensdag 15 januari 2020 @ 12:50:
Jazeker
  • akimosan
Altijd interessant zo'n probleem, maar kun je er niet omheen werken en een nieuwe installlatie uitvoeren op het systeem? Ik hoop/denk dat in het nieuwe systeem ook een nieuwere SSD zit? Waarom dan nog de oude disk aansluiten?
Als je later data wilt overzetten kun je ook de oude disk even met een SATA naar USB converter aansluiten en die disk benaderen...
  • Yboyray
akimosan schreef op donderdag 16 januari 2020 @ 22:43:
Is helaas niet mogelijk omdat de software mee moet en dit niet helemaal goed gaat met een nieuwe installatie
