  • DaVaRiOuS
  • Laatst online: 27-07-2022
We hebben een Server 2012 R2 draaien die ineens een system failure aangaf en automatisch herstarte.
De logs nagelopen en kwam DNS issues tegen.
Event viewer:
The dynamic registration of the DNS record '_ldap._tcp.Default-First-Site-Name._sites.ForestDnsZones.domain.local. 600 IN SRV 0 100 389 srv-dc.domain.local.' failed on the following DNS server:
DNS server IP address: ::
Returned Response Code (RCODE): 0
Returned Status Code: 0
For computers and users to locate this domain controller, this record must be registered in DNS.
USER ACTION
Determine what might have caused this failure, resolve the problem, and initiate registration of the DNS records by the domain controller. To determine what might have caused this failure, run DCDiag.exe. To learn more about DCDiag.exe, see Help and Support Center. To initiate registration of the DNS records by this domain controller, run 'nltest.exe /dsregdns' from the command prompt on the domain controller or restart Net Logon service.
Or, you can manually add this record to DNS, but it is not recommended.
ADDITIONAL DATA
Error Value: Bad DNS packet.
The WinRM service failed to create the following SPNs: WSMAN/srv-dc.domain.local; WSMAN/srv-dc.
Additional Data
The error received was 9502: %%9502.
User Action
The SPNs can be created by an administrator using setspn.exe utility.
[b]DCDIAG DNS TEST:
Directory Server Diagnosis
Performing initial setup:
Trying to find home server...
Home Server = srv-dc
* Identified AD Forest.
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site-Name\SRV-DC
Starting test: Connectivity
......................... SRV-DC passed test Connectivity
Doing primary tests
Starting test: DNS
DNS Tests are running and not hung. Please wait a few minutes...
......................... SRV-DC failed test DNS
Running partition tests on : ForestDnsZones
Running partition tests on : DomainDnsZones
Running partition tests on : Schema
Running partition tests on : Configuration
Running partition tests on : domain
Running enterprise tests on : domain.local
Starting test: DNS
Test results for domain controllers:
DC: srv-dc.domain.local
Domain: domain.local
TEST: Basic (Basc)
Warning: no DNS RPC connectivity (error or non Microsoft DNS server is running)
srv-dc PASS WARN n/a n/a n/a n/a n/a
......................... domain.local passed test DNS
In de DNS staat deze ldap record wel geregistreerd.
Alles lijkt verder ook gewoon normaal te functioneren.
Het lijkt erop dat de server iedere 2 uur een storing hierop krijgt en zich reboot.
Ik heb nog niets kunnen herleiden waar dit in kan zitten :(
[ Voor 0% gewijzigd door Jazzy op 20-01-2020 17:16 . Reden: bedrijfsnaam stond er nog in ]
  • .Maarten
  • Laatst online: 10-10 16:53
Een server reboot niet door een DNS fout. Test eerst de hardware maar eens zoals hdd en ram.
  • downtime
downtime
Everybody lies
Verder zoeken. Een DNS fout leidt niet tot een reboot.
  • Brahiewahiewa
  • Laatst online: 30-09-2022
Brahiewahiewa
boelkloedig
DaVaRiOuS schreef op maandag 13 januari 2020 @ 19:17:
Het lijkt erop dat de server iedere 2 uur een storing hierop krijgt en zich reboot...
Ja, dat doet windows als de licence is verlopen
QnJhaGlld2FoaWV3YQ==
  • Rolfie
  • Laatst online: 10:56
Brahiewahiewa schreef op maandag 13 januari 2020 @ 23:46:
Volgens mij doet die dan een shutdown en geen reboot. En als ik het nog goed weet, een duidelijke eventviewer melding.
  • nelizmastr
  • Laatst online: 10-10 12:46
nelizmastr
Goed wies kapot
Rolfie schreef op vrijdag 17 januari 2020 @ 17:50:
Idd. Doet een oude SBS bak ook als-ie niet meer de enige DC is. Dan is de licentie ook niet meer geldig en gaat-ie uit, geen reboot.
  • Question Mark
  • Laatst online: 09-10 13:32
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Hoe ziet je dns en domain structuur er nu uit? Wat is de naam van je domain, en welke zones bestaan nu op je dns-server. Je DNS ondersteund ook ipv6 query's?
Geeft verder eens een ipconfig /all van die Domain Controller?
[ Voor 0% gewijzigd door Jazzy op 20-01-2020 17:15 . Reden: bedrijfsnaam uit de quote gehaald ]
Controleer sowieso je hardware ook even.
Enne, je hebt niet overal de naam weggehaald.
