ZEEEEEEEEER lange text!
Meningen graag!
WHO BUILT THE GREAT PYRAMID?
By John Zajac The Pyramids. According to common perception they were built, with the begrudging help of great armies of slaves, by the ancient pharaohs of Egypt as tombs for preserving their royal bodies. Pyramids were meant to be monuments to the pharaoh's greatness, filled with great treasures for the afterlife.
To construct these massive shrines, the pharaoh's copied the oldest and largest pyramid of all, the Great Pyramid of Giza. But the Great Pyramid itself contains no pharaoh's body, no treasure chamber, and no treasures. Who, then, designed it and built it? What was its purpose? Let us begin our tour by considering a few basic facts about the Great Pyramid. The Last "Wonder of the World" Thirty times larger than the Empire State Building, the Pyramid's features are so large they can be seen from the Moon.
Its base covers 13.6 acres (equal to seven midtown Manhatten city blocks), each side being greater than five acres in area. A highway lane eight feet wide and four inches thick could be built from San Francisco to New York and put inside the Great Pyramid. The oldest structure in existence, having been started 4,617 years ago, it is the sole remnant of the Seven Wonders of the World. Journey to the Center of the Earth Only a solid stone mountain could endure the Pyramid's immense weight. And indeed, a flat solid granite mountain happens to be located just beneath the surface of the ground directly under the Pyramid.
It is built to face true North. The Pyramid is located at the exact center of the Earth's land mass. That is, its East-West axis corresponds to the longest land parallel across the Earth, passing through Africa, Asia, and America. Similarly, the longest land meridian on Earth, through Asia, Africa, Europa, and Antarctica, also passes right through the Pyramid. Since the Earth has enough land area to provide 3 billion possible building sites for the Pyramid, the odds of it's having been built where it is are 1 in 3 billion. Construction Unequaled by Modern Technology Like 20th century bridge designs, the Pyramid's cornerstones have balls and sockets built into them. Several football fields long, the Pyramid is subject to expansion and contraction movements from heat and cold, as well as earthquakes, settling, and other such phenomena.
After 4,600 years it's structure would have been significantly damaged without such construction. While the bulk of the Pyramid's core was constructed of 4,000- to 40,000-pound blocks of soft limestone, the outer layer of the Pyramid was made of a beautifully bright, protective layer of polished stone. These outer "casing stones" are missing today because about 600 years ago they were stolen by Arabs, (This accounts for the very worn appearance of the Pyramid today, since the inner limestone blocks are not immune to attack by the elements-wind, rain, and sandstrom.)
This protective covering was made up of 100-inch-thick, 20-ton block of hard, white limestone, similar to marble but superior in hardness and in durability against the elements. The Great Pyramid did not always look as "rough" as it does today. Originally it was encased with a layer of tight-fitting, highly polished 20-ton stone slabs. The casing stones, 144,000 in all, were so brilliant that they could literally be seen from the mountains of Israel hundreds of miles away.
On bright mornings and late afternoons, sunlight reflected by this vast mirrored surface of 5-1/4 acres distinguished the Pyramid as being visible from the moon <http://southport.jpl.nasa.gov:80/imagemaps/html/srl-giza.html>. (Note: For those interested in possible symbolic significance, in Bible prophecy 144,000 is the number of people-12,000 from each of the 12 tribes of Israel-who are supposed to evangelize the world at the endtime.)
The people of the area had viewed the Pyramid and its polished stones with awe for centuries. But when a 13th century earthquake loosened some of these casing stones, the Arabs recognized a great quarry of precut stones that could be used to finish off palaces and mosques. For instance, the casing stones were used to rebuild the new city of El Kaherah plus Cairo mosques and palaces, including the Mosque of Sultan Hasan.
Amazingly, the outside surface stones are cut within 0.01 (1/100th) inch of perfectly straight and at nearly perfect right angles for all six sides. And they were placed together with an intentional gap between them of 0.02 inch. Modern technology cannot place such 20-ton stones with greater accuracy than those in the Pyramid. Even more amazing is that the 0.02-inch gap was designed to allow space for glue to seal and hold the stones together.
A white cement that connected the casing stones and made them watertight is still intact and stronger than the blocks that it joins. Let's pause from our tour for a moment's rest and reflection. Whoever built the Pyramid used a technologly that we still do not possess today to cut, move, and cement stones. Whoever built it also had some knowledge of the Earth, because it was built in the right spot-one of the few places that would support such a great weight. The builder also knew where the greatest land mass of the Earth was in both the North-South and East-West directions. Amazing.
But we had better keep going. And joining us on the leg of our tour will be none other than Sir Issac Newton... The Cosmic Yardstick The Great Pyramid is one of the most comprehensively surveyed buildings in the World. Scientists over the centuries have taken thousands of measurements in their quest to find out more about its mysteries. Among those intrigued by the incredible accuracy of the Pyramid's construction was the great scientist and mathematician Sir Isaac Newton.
Attemping to formulate his famous law of gravity, Newton needed to know the diameter of the Earth. However, in the 1600's no measurement was accurate enough, especially since Newton theorized that the Earth's spin would cause an equatorial bulge. Having heard legends claiming that knowledge of the Earth, the past, and the future were contained in the Pyramid, Newton set out to investigate.
After studying the detailed measurements made by the investigators before him, Newton recognized that many key measurements would be in round numbers if the standard unit of measure was just 0.001 (1/1,000) inch larger than the British inch-which just happens to be the Sacred Jewish Inch. (The Sacred Jewish Inch, 1/25 of a cubit, equals 1.00106 British inches.)
This discovery allowed the secrets of the Pyramid to be unlocked and revealed unmistakable and mathematical relationships. For instance: We know from geometry that there is a universal relationship between the diameter of a circle and its circumference. Consider this: The height of the Pyramid's apex is 5,812.98 inches, and each side is 9,131 inches from corner to corner (in a straight line). If the circumference of the Pyramid is divided by twice its height (the diameter of a circle is twice the radius), the result is 3.14159, which just happens to be pi. Incredibly, this calculation is accurate to six digits. So the Pyramid is a square circle, and thus pi was designed into it 4,600 years ago.
Pi is demonstrated many times throughout the Pyramid. Other numbers are also repeated throughout. Each of the Pyramids four walls, when measured as a straight line, are 9,131 inches, for a total of 36,524 inches. At first glance, this number may not seem significant, but move the decimal point over and you get 365.24. Modern science has shown us that the exact length of the solar year is 365.24 days.
All of the evidence in the Great Pyramid shows that 4,600 years ago somebody knew a great deal about the Earth. But it gets better, much better: The average height of land above sea level (Miami being low and the Himalayas being high), as can be measured only by modern-day satellites and computers, happens to be 5,449 inches. That is the exact height of the Pyramid. All four sides of the Pyramid are very slightly and evenly bowed in, or concave.
This effect, which cannot be detected by looking at the Pyramid from the ground, was discovered around 1940 by a pilot taking aerial photos to check certain measurements. As measured by today's laser instruments, all of these perfectly cut and intentionally bowed stone blocks duplicate exactly the curvature of the earth.
The radius of this bow is equal to the radius of the Earth. This radius of curvature is what Newton had long been seeking. The Great Pyramid is located on the far right. Clearly, whoever built the Pyramid had access to information beyond that which earthlings possessed at the time, at least earthlings as we know them. Now, one can argue that we were visited by scientifically advanced beings from outer space who taught us their technology. That is possible from the evidence presented, perhaps even likely.
If so, these advanced beings had the paramount goal of leaving behind a message that would endure for eons. Suppose these beings decided to leave a message. The message would have to be universal yet simple. It would have to survive the centuries and be understandable by all the Earth's inhabitants despite language and cultural differences. The message would have to be understood by many languages that would not come into existence for centuries after the message was written. So far the message indicates that whoever built the Pyramid knew the Earth well: the length of the year, the radius of curvature, the standard measurement techniques, the average height of the continents, and the center of the land mass. They were able to consruct something that we still cannot construct today, and they were able to tie all these things together in this single structure. Were they extraterrestrial, or perhaps even supernatural? The answer is not yet clear. However, thus far we have examined only the outside of the Pyramid.
  • Delerium
Delerium
Mythology
hum, interpunctie?
En wat moeten we met deze lap tekst eigenlijk doen?
hehe, sorry, maar ik heb het uit een .txt bestand gekopieerd :(
Probeer het maar
zo beter?
Nou nee, vertaal het eerst even :)
/edit bovendien waar is je eigen mening nu je om meningen vraagt :?
  • Wolfensteijn
  • Laatst online: 15:37
Een mening? tja, mijn mening over die tekst, zeer lang ;).
Maar als we idd kijken naar het hoe en waarom van pyramides, nog lang niet alle geheimen van de oudste pyramide zijn opgelost.
Ik kan eigenlijk niet wachten totdat we erachter komen wat en waarom die pyramide is gebouwd.
  • Delerium
Delerium
Mythology
IMHO zijn die gebouwd omdat de mensen zich in de zomer verveelden (land was toch overstroomd door de nijl) en dat de pharao gewoon iets indrukwekends wilde maken.
Een combinatie daarvan zorgde dat de mensen zo toch nuttig bezig waren in de ogen van de pharao en de mensen iets konden doen zodat ze konden verdienen.
Dat ze zulke absurde gebouwen op den duur neerzette is ongeveer even absurd als nu een 4 baans snelweg verbreden naar 6.
  • Elvhenk
Elvhenk
Madam Mikmak
X-zero, wil je je bedoeling en mening over het onderwerp even uiteenzetten; in het nederlands? Is wel zo praktisch.
Er zijn al geregeld topics over de pyramiden geweest, dus misschien dat hier sowieso niet zoveel reactie op komt.
  • Morphs
  • Laatst online: 21-05-2025
Ben een maand geleden naar Egypte geweest en uiteraard heb ik ook de Pyramides van Gizeh gezien en ben ik zelf in de kleinste geweest.
Wel, het is erg indrukwekkend. Over de grootste (was geloof ik 143m hoog) is 20 jaar gedaan. Erg lang dus. Echter: tegenwoordig kunnen ze zo'n pyramide waarschijnlijk niet eens namaken omdat het gewoon een te kolossaal bouwwerk is (en vooral zo hoog).
Toen we aan kwamen rijden leek het alsof het uit vrij kleine blokken bestond. Eenmaal aan de voet van de pyramide bleken ze net zo groot als een mens te zijn (en wegen 15 ton).
Al met al zeer indrukwekkend hoor. Het stuk tekst ga ik straks wel lezen, moest ff mijn verhaal kwijt :)
  • lexkam
  • Laatst online: 09-01-2013
Tijdje geleden een docu (op national geographic d8 ik) gezien waarin ze een hoop van deze 'verklaringen' onderuit haalde. Ik denk dat als ik m'n tafel ga opmeten en met deze getallen ga stoeien ik ook hele leuke verhalen kan maken.
(Nostrodamus versen achteraf op volgorde leggen kan iedereen, maar de voorspellingen voor de toekomst kloppen voor geen kant)
Hoe meet je een zwaar ge-erodeerde piramide op in 3 cijfers achter de komma?
Maar het verhaal is altijd leuk om te lezen, en mischien wisten ze inderdaad meer als we dachten dat ze deden ( :? )
Op donderdag 02 augustus 2001 17:18 schreef Morphs het volgende:
We kunnen het tegenwoordig best namaken, maar het kost ongelovelijk veel geld (grondstoffen, manuren, etc.) en het is zinloos.
Ik denk zelf dat de pyramidenbouwers best wel dingen zullen hebben geweten die wij op dit moment nog niet weten. Maar dan denk ik aan dingen als: bouwkundige handigheidjes, wiskundige truukjes, etc.
Ook niet alle pyramides zijn perfect, er zijn er genoeg kleinere waarbij je kunt zien dat ze de techniek nog niet geperfectioneerd hadden. De zijn vaak ook meer vergaan.
er zijn een paar grote, die dataren ongeveer 5000 BC.
Ik denk dat die door een of andere culteer/beschaving/ras (!?) is gemaakt, en dan de egyptenaren ze toen probeerde na te maken, en dat zijn die 71 andere kleine uit elkaar vallende pyramides
Wist je trouwens dat in 2004 de noordster voor het eerst in 6000 jaar precies in de noorderschaft schijnt.
En in het hoofdstuk exodus, wat ongeveer 2000 BC is geschreven, wisten ze niet meer wie de pyramides had gebouwd, omdat ze toen al zo oud waren.....
denk!
  • Delerium
Delerium
Mythology
't zou ook kunnen dat die dateringen niet goed zijn: dat is ook wel makkelijk terug te kijken, maar als een pyramide fout gebouwt is kan ie wel in een andere tijd bv precies goed staan.
ja , maar is kinvd het toch dan toeval datook een andere ster precies in die andere schaft schijnt (er zijn 2 schaften)
En de sphinx is 11.000 BC gebaseerd.
Op donderdag 02 augustus 2001 18:34 schreef X-ZERO het volgende:
En weet je ook hoeveel sterren er zijn? ;)
Het zou pas echt toeval zijn als er geen ster in de schaft zou schijnen.
Dat weten ze helemaal nog niet. De meeste egyptologen denken dat de sphinxen net zo oud als de pyramides zijn. Er zijn verschillende verklaringen voor de erosie, maar ze weten nog niet welke juist is. Sommige egyptologen denken dat de sphinxen ouder zijn, maar die hebben geen verklaring door wie ze dan gebouwd zijn.
  • tita_tovenaar
  • Laatst online: 05-09 09:35
tita_tovenaar
Passief Actief
Heb geen zin om die hele txt te lezen 't is vakantie hoor.
Soms weet ik het ook niet meer.........
Op donderdag 02 augustus 2001 21:06 schreef tita_tovenaar het volgende:
idd
Op vrijdag 03 augustus 2001 00:48 schreef Neonlampje het volgende:
idd
TSsssss.
Pansies...
  • RM-rf
  • Laatst online: 18:18
RM-rf
1 2 3 4 5 7 6 8 9
misschien moet jezelf ook eens wat andere topics doorlezen, is al vaker aan bod geweest, theorie van Hancock en Bauvall ed.
[topic=170415]
[topic=141236]
[topic=41480]
ik ben nog altijd benieuwd naar newijsmateriaal voor dit soort verhalen, en nee, dat vind ik niet in data hele stuk van jou; dat het allemaal zo knap is, dat mensen er achteraf allemal opzienbare berekeningen mee gaan uitvoeren is leuk, maar geenszins een bewijs.
Op donderdag 02 augustus 2001 15:42 schreef X-ZERO het volgende:
Cheops naar wat terugkomt in alle documentatie, dateringen etc.
en resten van de werkmansteden zijn ook in de omgeving van Gizeh te vinden
nee Cheops baseerde zijn pyramide op het werk van een eerdere pharao; Khafroe,
het idee dat iemand een 'monument van zijn grootheid' in de schaduw en wat kleiner laat bouwen dan een al eerder bestaande pyramide is ..eeh .. niet erg groot.
:? de grote pyramide bevat wel degelijk twee kamers; een grote hal e.d.
en waaruit wordt hier opeens de conclusie gehaalt dat de pyramide niet door de pharao' zou zijn gebouwd?
nee, de chinese muur kan worden gezien vanaf de maan, door de grote schaal darvn en aangezien deze een lijn door het landschap trekt, de pyramide is groot maar te klein om op te vallen vanaf de maan.
de chinese muur is ook groter dan de pyramides, en bestaat ook nog steeds.
de pyramide is juist de oudste van de 'seven wonders' en niet de laatste
een onderaardse berg? ik denk dat de schrijver hier doelt op het Gizeh plateu, een rots-plateau van stevige zandsteen, inderdaad de meest geschikte locatie inde nabije omgeving
:D ROFLOL
het feit dat de egyptenaren hem hebben gebouwd zou misschien eventueel ook wat te maken kunnen hebben met het feit dat de pyramides in egypte staan, maar that's just a guess
en dat komt nu net exact overeen met 20de eeuwse bruggenbouwers, hetzij dat een 100mtr lange ijzeren spoorbrug meer uitzetting heeft dan een stuk steen van 119x119 breed
ach de arabieren hebben het weer gedaan, nee de laag is niet in één keer gestolen echter in de loop der tijden, de dure en mooie stenen hebben een hoge waarde en worden dus gebruikt door de bouwers van andere gebouwen als ze de kans hebben.
overigens is er nog een pyramide met een overgroot deel van de originele bekleding, de oudere van khafroe, bekend al de 'knik' -pyramide, de reden daarvoor is in eerste instantie de geisoleerde locatie, gizeh, vlak in de buurt van cairo ligt een stuk toegankelijker.
een zeszijdige piramide :?
ehm, de stenen zijn tot op 0,01 inch afwijking exact egaal gemaakt, en kunnen dus nooit minder dan een tussenruimte van 0,02 inch hebben (de optelsom van beide afwijkingen)
en zo gaat het verhaal door, omslachtige verhullingen van algemeen bekende gegevens, gegoochel met cijfers, sugestieve interpretaties.
tja als er mensen zijn die dit geloven, dan is die 'super-intelligente beschaving' die het gebouwd heeft, het laatste bewijs van de aanwezigheid van intelligentie op aarde ;)
Intelligente mensen zoeken in tijden van crisis naar oplossingen, Idioten zoeken dan schuldigen
rm-rf "een zeszijdige piramide :? "
ehm... het gaat over de stenen, niet over de pyramide als geheel
