asus V7700 met Abit KT7A: signal missing!
  • 100 views sinds 30-01-2008
Als ik de spanning op alle onderdelen zet moet ik binnen een tiende van een seconde de powerknop van computer hebben ingedrukt anders doet de video kaart het niet ;(.
Het gevolg is anders dat de monitor denkt dat de kabel niet is aangesloten.
De enigste oplossing is dan ctrl alt del.
Als de computer dan opnieuw opstart dan krijg ik wel beeld.
Kent iemand dit probleem?
Heeft iemand hier een oplossing voor?
reageer dan ff.
Booij
  • MrTinux
  • Laatst online: 08:26
MrTinux
Terug van nooit weggeweest.
Uit de bekende unofficial Abit KT7 FAQ:
Why does my system not boot with the Asus V7700 AGP Card?
In an email to me from the support desk at Monarch Computer Systems, they said that problems occur 80% of the time with the V7700 Pure 32MB and V7700 Deluxe 64 MB, but that they have not seen this problem occur with the V7700 Deluxe 32MB or the V7700 Pure 64 MB. The problems do not occur with other motherboards. [Update: one user emailed me to say he cannot get his V7700 Deluxe 32MB to boot and ended up buying a GeForce2Mx.]
This problem can sometimes be resolved by raising the I/O voltage in the BIOS to 3.4v and/or raising the AGP Driving Strength to EA or FF in the Advanced Chipset Features of the BIOS. It has also been reported that flashing to the 2.14 bios
available on the Asus web site (ftp page) solves the problem. Also see the ABIT FAE advice. If these solutions do not work for you, you may wish to return you card to Asus for a newer replacement - the fault appears to be theirs.
One user warned me that despite the above advice, with his KT7 and Asus 7700 deluxe graphics card (BIOS revision 2.15.01.14), he still could not achieve stability. He claimed that neither ASUS nor ABIT would accept responsibility and advised users to stay clear of this graphics card until the problem is resolved. My best guess is that the Asus 7700 must be marginally compatible with the KT7, depending on the tolerances of the particular components on each board. Hence the mixed reports of success. Your choice.
Other solutions
Another user found that by setting the Delay for HDD to 2 seconds in Advanced BIOS Features page of the BIOS allowed the machine to boot correctly - as it prevents both the disks and graphics card from drawing too much current at the same time.
One user found that if he hit the reset button at the moment the motherboard beeped at him (when it failed to find the graphics card), then the machine would then go on to boot fine. This fix was 100% successful.
Another user found that the cause of his problems was that the machine was not properly grounded (earthed). By properly grounding the machine the machine booted correctly.
"Hij doet 't niet" = onvolledige informatie
Ken het probleem.... Heb ik ook gehad, maar niks leek bij te werken (ook niet al die oplossingen uit the unofficial KT7 Faq). Dus ik heb mijn bordje omgeruild voor een Asus A7V133 (en dies nog sneller ook):9
bedankt, :P *D
Het probleem is opgelost!
JB
  • DutchPlayer
  • Laatst online: 11-11-2025
geeft de monitor dan aan signal missing, mijn PC doet ook opeens vreemd.
Heb een fan adapter geplaats en nu heb ik geen beeld meer ofwel de PC doet niks boot ook niet.
AMD 7800X3D - Lian Li HydroShift - Asus TUF X670E - Corsair Vengance 2x16GB 6000Mhz- Gigabyte RTX4070 Super 12GB - Kingston 1TB M2 - Crucial MX100 512GB - Lexar 2TB M2 - Lian Li O11D Evo RGB - Corair RM750Watt - LG 38
