Nieuwste patch voor Operation Flashpoint install..
  • 120 views sinds 30-01-2008
...problemen :)
"please insert correct cd" error (cd heet toch FLASHPOINT)??
lijst met fixes:
*** IMPORTANT - OPERATION FLASHPOINT INTERIM UPGRADE (V1.10) README ***
1st August 2001
This readme outlines the functionality improvements, bug fixes and new features incorporated into the first official upgrade release. The file is available for download from www.codemasters.com/flashpoint/upgrades (and associated mirror sites). Unzip it and run the extracted .exe from any directory - it will automatically update all the necessary files.
Add-Ons (new vehicles, weapons, single and multi-player missions) will be available separately soon.
PLEASE NOTE - YOU WILL NEED YOUR ORIGINAL OPERATION FLASHPOINT DISC IN THE CD DRIVE WHEN YOU RUN THE UPGRADE .EXE - THE FILE IS COPY-PROTECTED AND WILL NOT WORK WITHOUT IT.
Requirements:
1) Installed release version of Operation Flashpoint (WITH ORIGINAL DISC IN CD DRIVE)
2) We recommend that all applications (including Operation Flashpoint) be closed down before running the upgrade .exe.
NEW FEATURES
* Customised faces can now be inserted for use in multi-player games, in JPG format.
* "Walking" mode can be toggled with the 'F' key.
* It is now possible to turn while reloading.
* Weapon shadows now reflect the actual weapon held.
* You can now move when using optics while crouched.
* You will experience reduced weapon recoil when crouching.
* It is now possible to sprint when using an ironsight view.
* Even small hand injuries now cause some weapon trembling.
* Heavy breathing will cause increased weapon trembling.
* AI characters now use the "walking with rifle" animation when appropriate.
* The "NEXT WAYPOINT" command has been implemented for any selected unit - not just the player-commanded vehicle.
* A server can kick players from the "Players" dialog.
* A warning message box will be shown in the server briefing if all players are not ready.
* Blood now appears before an injury is critical.
* Titles were shown at unlimited distance - distance is now limited to 100m.
* The ability to create user-defined actions has been introduced.
* The crash info file context.bin contains more information: CPU registers and version info are saved.
* Squad pictures and titles are now shown on client machines.
* New support and checks for add-ons, referenced to version number.
IMPROVEMENTS
* AI visual and audible enemy detection is improved, especially for prone targets.
* AI night vision is less effective.
* AI now put on/take off NV goggles where appropriate.
* Interior collisions are improved.
* Soldiers report sooner for medical assistance.
* Air friction physics modelling on missiles improved.
* The LAW and RPG are now faster and burn most of their fuel while in the tube.
* Missile fire tail is no longer drawn when fuel is burnt out.
* Airplane target engaging is improved.
* Airplanes lose less speed while turning.
* Even if 'turned in', the gunner is now drawn in the external camera view.
* When connecting through GameSpy arcade, you can now interrupt a "waiting for server" message.
* Only assigned players, not all connected players, are now shown in a multiplayer game.
* The design of the server briefing dialog and chat systems has been improved.
* More transfered properties in multiplayer have been added for airplanes.
* A more robust handling of the "maximum texture size" and "out of memory" conditions has been introduced.
* "Invalid vehicle types" are handled better.
* M113 gunner view improved.
* Seagull handling improved.
* Connect/disconnect messages are now localized.
* Guard band clipping enabled - this solves some issues with clipping sun on nVidia cards, and also increases performance on TnT family cards.
* All reward/penalty cutscenes now marked as played when appropriate.
MISSION FIXES
* Single Mission - 05 Heavy Metal - Mission would rarely not finish.
* Single Mission - 09 Sniper Team - CPU saboteurs not moving.
* Single Mission - 10 Commander - Occasionally didn't end.
* Campaign - 03b Alert - Radio calls M113 'unknown'.
* Campaign - 12 Spearhead - Spelling errors in briefing.
* Campaign - 38 StatusQuo - Crash at Laruns.
* Campaign - 38 StatusQuo - Spanish briefing.
CODE FIXES
* Fixed - Problems with prone soldiers invulnerable to being run over.
* Fixed - Hardware T&L daytime light glitches.
* Fixed - Watch and compass animations under hardware T&L.
* Fixed - Problems with compass and watch on re-trying a mission.
* Fixed - Graphical corruption with Voodoo 3s under Glide.
* Fixed - In-game resolution switches causing some graphical corruption with certain cards.
* Fixed - Spinning sight view with an unloaded rocket launcher on your back.
* Fixed - Preferences resolution not matching in-game selection.
* Fixed - Keyboard input disabled during mission loading.
* Fixed - "3rd person view" difficulty option not functioning correctly.
* Fixed - Autodetect settings for file & texture heap wrong if <128MB reported by Windows.
* Fixed - Double music volume in Audio options.
* Fixed - Problems with map marker centring after installation or creating a new user.
* Fixed - Crash without ammo in ship simulation.
* Fixed - Save-game corruption if save called when training target was being destroyed.
* Fixed - User cannot be deleted sometimes.
* Fixed - Mission objectives not always correctly updated after load.
* Fixed - Soldier very rarely stays frozen in mid-air when getting out of a vehicle, until moved.
* Fixed - "End" button in "Player Killed" screen was handled incorrectly.
* Fixed - Sports car speedometer moving in the wrong direction.
* Fixed - Friendly units info on map in veteran mode.
* Visibility during stand up/lay down transitions now correct.
* Sometimes a tank was aiming at a target in 'prepare' mode only, because the target was already inactive. The tank commander now cancels target in such a situation.
* When a tank commander was changing weapons often, the weapon change command was sometimes lost. This has been fixed.
* Minor night-time visibility bugs resolved.
* AI soldiers watched non-combat enemies, which made weapon selection unstable. Binoculars were also selected for no apparent reason. Only combat enemies are watched now.
* Tank commander weapon selection is now more stable, especially when engaging cars.
* When there were no dangerous enemies visible, the importance of weak targets was overestimated. As a result, much stronger weapons were selected than necessary. This problem has been resolved.
* Camera position is now clipped, so that the camera does not look through objects.
* Night vision equipment now visible on dead soldiers where appropriate.
* Reloading with weapon on back is now disabled.
* Multiplayer - Fixed - Problems when two players get into a vehicle simultaneously.
* Multiplayer - Fixed - "Hide body" sometimes not working.
* Multiplayer - Fixed - Vehicle shaking problem.
* Multiplayer - Fixed - Respawn and "high speed soldier" bugs if killed while getting into a vehicle.
* Multiplayer - Fixed - Disabling radio subtitles removes chat ability.
* Multiplayer - Fixed - Procedure "moveInGunner" is now multi-player safe.
* Multiplayer - Fixed - Procedure "moveInDriver" is now multi-player safe.
* Multiplayer - Fixed - Procedure "moveInCommander" is now multi-player safe.
* Multiplayer - Fixed - Procedure "moveInCargo" is now multi-player safe.
* Multiplayer - Fixed - Score register.
* Multiplayer setup - Fixed - Player assignment bugs.
  • Joske Pauwels
  • Laatst online: 19-07-2016
Joske Pauwels
Stelt zich vragen...
WOOHOOOO!!!!!!!!!!!!
Blij dat ik dit spel legaal heb...
En dan nog wel gratis >:)
Kheb de press release :P
  • Kwistnix
  • Laatst online: 13:23
Heb um orgineel gekocht, en Max Payne ook.
Voor allebei ben ik op het moment de patches aan ut downloaden
Heb je tijdens de installatie van die patch wel de CD in je dinges gehad?
Als die uberhaupt een cd heeft >:)
  • Kwistnix
Prefief, bij mij installeerde de OF-patch vlekkeloos en die van MP ook.
Net zo'n grapje als Unreal Tournament zeker, daar had je ook de originele cd nodig om er een patch overheen te gooien.
Ik vind dat wel een mooie beveiliging eigenlijk, zeker bij een spel zo brak als Operation Flashpoint. Dan kan je eigenlijk niet om zo'n update heen.
  • Joske Pauwels
Joske Pauwels
Op donderdag 02 augustus 2001 19:42 schreef -polle- het volgende:
Operation Flashpoint = Brak ?!?!?!? :?
You are sick :(
  • tCC
  • Laatst online: 23-08 08:23
tCC
de update is al gehacked, dus die valt rustig te installeren (zonder cd btw)...
de cracked exe van bee.rockz werkte half (foutmelding "bad serial given in setup"), maar een nieuwe crack is alweer te vinden op het net :P
have fun er maar weer mee,
tCC.
  • Zeeger
  • Laatst online: 25-03-2025
UT patchte met een gekopierde cd net zo lekker als op een originele hoor, dus ik weet niet wat je hier bedoelt. :?
Wel effe een goede crack erover uiteraard. >:)
Op donderdag 02 augustus 2001 20:28 schreef de_vinny het volgende:
You are sick :(
Inderdaad ja, brak. Hiermee bedoel ik vol met bugs, Zo kan je sommige missies niet normaal uitspelen, kijk je wel eens door huizen heen enz. Ik bedoel er niet mee te zeggen dat het een slecht spel is, alleen misschien net iets te vroeg gereleased.
Wat mijn mening en mijn lichamelijke status met elkaar te maken hebben snap ik niet helemaal :?
  • Bezulba
  • Laatst online: 24-08 13:00
Bezulba
Formerly known as Eendje
mischien moet je dan het origineel maar eens proberen ipv brakke iso release met fade.... er zitten aantal foutjes in maar om nou te zeggen dat ie brak is.. nee dat vin ik niet... kheb zelf ook geen probs gehad met levels die niet uit te spelen waren ofzo...
blup
  • tCC
tCC
Op vrijdag 03 augustus 2001 13:16 schreef Werkeend het volgende:
prrrrfffft, dream on:
MISSION FIXES
dan zal jij wel de enige zijn dan die op z'n originele cd ook de 1.10 patch heeft staan, druif.
  • MM-
  • Laatst online: 30-11-2023
MM-
leer jij nog maar even door baasje, deviance was de eerste die FADE omzeilde, pff het staat zelfs in Power Unlimited. Da's dus zeker geen brakke iso-release.
  • Joske Pauwels
Joske Pauwels
Op vrijdag 03 augustus 2001 13:02 schreef -polle- het volgende:
Dat meende ik niet :)
Maar idd, het heeft bugs, maar ik heb nog nooit gehad dat het crachte, hoogstens af en toe een clipping probleempje...
En liever 2 maand te vroeg gereleased, en tijdens mijn grote vakantie er al van kunnen spelen (met nog niet alle features), ipv tot september te moeten wachten voor iets dat ik nu met een patch ook zal kunnen hebben...
  • Kwistnix
Ik heb OF orgineel gekocht en ik ben geen bugs tegengekomen! En ik heb het hele spel 2x uitgespeeld (op beide skill-levels).
Betekend niet dat er geen bugs inzitten, die zijn er genoeg, maar ik heb er totaal geen last van gehad.
Dus zonder patch is de release versie duidelijk niet brak te noemen...
  • Joske Pauwels
Joske Pauwels
Op zaterdag 04 augustus 2001 14:39 schreef FallenAngel666 het volgende:
Ik heb het ook legaal, en geen bugs!
Nog nooit gecrashed zelfs, dus die illegale boys hebben pech...
  • HappyFun
  • Registratie: Mei 2001
Op zondag 05 augustus 2001 12:51 schreef de_vinny het volgende:
Is die patch nodig om online te kunnen m-playen :? met GameSpy
Defunctus Deo Juvente
  • HappyFun
Can iemand mij helpen..elke keer als ik met GameSpy M-playen wil dan blijft ie hangen op "waiting for server"
Ligt aan firewall of..?
- iemand was me voor -
