AMD introduceert Threadripper 3960X en 3970X
  • |sWORDs|
  • Laatst online: 14-04 12:48
|sWORDs|
vSphere/ESXi
AMD introduceert Threadripper 3960X en 3970X met 24 en 32 cores
@Xtuv
"De theoretische maximale geheugenhoeveelheid is 2TB."
Daar gaat iets mis, er is geen RDIMM support en maximaal 2 DIMMs per channel, dus momenteel is het maximum 8*32GB of te wel 256GB.
Dit is ook wat alle moederbord fabrikanten aangeven.
Asrock:
Quad Channel DDR4 Memory Technology
- 8 x DDR4 DIMM Slots
- Supports DDR4 4666(OC)+/4600(OC) / 4533(OC) / 4466(OC) / 4400(OC) / 4333(OC) / 4266(OC) / 4200(OC) / 4133(OC) / 4000(OC) / 3866(OC) / 3800(OC) / 3733(OC) / 3600(OC) / 3466(OC) / 3200 / 2933 / 2667 / 2400 / 2133 ECC & non-ECC, un-buffered memory (U-DIMM)
- Max. capacity of system memory: 256GB
- 15μ Gold Contact in DIMM Slots
Gigabyte:
8 x DDR4 DIMM sockets supporting up to 256 GB (32 GB single DIMM capacity) of system memory
Quad Channel memory architecture
Support for DDR4 4400(O.C.) / 4266(O.C.) / 4133(O.C.) / 4000(O.C.) / 3866(O.C.) / 3733(O.C.) / 3600(O.C.) / 3466(O.C.) / 3400(O.C.) / 3333(O.C.) / 3300(O.C.) / 3200 / 2933 / 2667 / 2400 / 2133 MHz memory modules
Support for ECC Un-buffered DIMM 1Rx8/2Rx8 memory modules
Support for non-ECC Un-buffered DIMM 1Rx8/2Rx8/1Rx16 memory modules
Support for Extreme Memory Profile (XMP) memory modules
Asus:
the TRX40 series offers four memory channels for up to 256 GB of RAM across eight slots.
https://www.redsharknews....-zen-3-design-is-complete
The TRX4 will have quad-channel memory. With support for two UDIMMs per channel and 128 GB per UDIMM, that’s an impressive max of 1 TB. For I/O it will support 64 PCIe 4.0 lanes, of which 16 can be switched to SATA.
The WRX8 will have eight memory channels channels for up to 2 TB of DDR-3200 RAM and between 96 and 128 PCIe 4.0 lanes, with 32 switchable to SATA.
En 128GB UDIMM is er nog helemaal niet, we hebben pas sinds kort 32GB UDIMM.
[ Voor 27% gewijzigd door |sWORDs| op 08-11-2019 14:09 ]
Te Koop:24 Core Intel Upgradeset
  • Wintervacht
  • Laatst online: 28-08 08:56
Wintervacht
Dat het in de praktijk (nog) niet bestaat betekent toch niet dat het dan theoretisch gezien niet klopt?
Weet een beetje van veel dingen en veel van een paar dingen.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Zelfs theoretisch is het niet correct (dit gaat over de TRX4, alleen de WRX8 zou het theoretisch hebben) en een theoretisch maximum wat 4-8x boven de werkelijkheid ligt is best misleidend.
  • Xtuv
  • Laatst online: 17-10 21:22
@|sWORDs| Excuses voor de late reactie. Ik heb het zinnetje over de theoretische capaciteit weggehaald; is niet helemaal correct inderdaad. Moederbordfabrikanten noemen max 256GB omdat dit nu de praktisch haalbare max is. De cpu's zijn niet gelimiteerd op 256GB, dat wou ik aangeven.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
We zijn allemaal druk. :)
  • Knudel
  • Registratie: Mei 2016
  • Laatst online: 18-09-2023
Heeft iemand al ervaring met deze systemen?
Is het systeem op dit moment stabiel genoeg?
