(Sorry for using English, my Dutch isn't too good yet)
Hoi! I was lucky enough to purchase the Ryzen 9 3900x CPU on Alternate.nl last night as the single biggest upgrade to my PC (1440p 144hz gaming, streaming, video encoding, and 3D rendering all-in-one). I have my eyes on the Asus PRIME X470-Pro motherboard to accompany the CPU (My PC currently uses an Intel CPU and motherboard).
Unfortunately, the Asus motherboard requires an AMD CPU in order to update the BIOS to be compatible with the Ryzen 3900x - I don't have one that I can use.
Is there any store that sells PC parts (Or a physical service in Amsterdam) that can update the BIOS on the motherboard for me?
Thanks!
Beste antwoord (via Verwijderd op 01-10-2019 17:55)
  • Damic
  • Laatst online: 21:03
Damic
Tijd voor Jasmijn thee
  • Devian
  • Laatst online: 19:22
Buy this:
V&A aangeboden: AMD Athlon 200GE Boxed
Update your bios.
Sell it again.
[ Voor 22% gewijzigd door Devian op 01-10-2019 17:45 ]
https://wren.co/join/Devian
  • Beste antwoord ✓
  • Damic
Damic
Thanks both of you! I'll grab one from there!
  • Joey_RTLX
  • Registratie: Juni 2018
  • Laatst online: 07-10-2025
Also Azerty does have the option for a bios update, also worth checking if the board does have a option to use USB flash without a cpu installed.
Joey van der Houven
  • mitsumark
  • Laatst online: 01:39
Or choose a different motherboard with the right bios on it (MSI MAX versions), or with USB flash option (on many MSI boards).
https://docs.google.com/s...ydkpFA/edit#gid=611478281
(the prime x470 is actually not that good related to VRM, but without OC and/or with some airflow it should work fine)
[ Voor 78% gewijzigd door mitsumark op 01-10-2019 21:35 ]
