Hallo iedereen,
* zeroxcool zit weer met een probleem...
Ik ben bezig een forumpje te maken, en nou wilde ik op m'n linux bak de db zetten, dus ik mooi in PHP scripje geschreven krijg ik dit:
Nou post ik hieronder even een drop uit de user table van MySQL:
beetje veel maarja, kijk maar wat er fout is...
* zeroxcool snapt er geen snars van!
| Warning: MySQL Connection Failed: Host '10.0.0.10' is not allowed to connect to this MySQL server in f:\webserver\html\gameboard\cp\manageconf.php3 on line 20 |
29
30
31
32
33
34
35
36
37
38
39
40
41
| # phpMyAdmin MySQL-Dump
# http://phpwizard.net/phpMyAdmin/
# Host: server:3306 Database : mysql
# Table structure for table 'user'
CREATE TABLE user (
Host char(60) binary NOT NULL,
User char(16) binary NOT NULL,
Password char(16) binary NOT NULL,
Select_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Insert_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Update_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Delete_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Create_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Drop_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Reload_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Shutdown_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Process_priv enum('N','Y') DEFAULT 'N' NOT NULL,
File_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Grant_priv enum('N','Y') DEFAULT 'N' NOT NULL,
References_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Index_priv enum('N','Y') DEFAULT 'N' NOT NULL,
Alter_priv enum('N','Y') DEFAULT 'N' NOT NULL,
PRIMARY KEY (Host, User)
# Dumping data for table 'user'
INSERT INTO user VALUES ( 'localhost', 'root', '', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y');
INSERT INTO user VALUES ( 'server', 'root', '', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y');
INSERT INTO user VALUES ( 'localhost', '', '', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N');
INSERT INTO user VALUES ( 'server', '', '', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N');
INSERT INTO user VALUES ( '10.0.0.100', 'root', '', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y', 'Y');
INSERT INTO user VALUES ( '10.0.0.100', '', '', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N', 'N'); |
