Synology DS214Play tot leven wekken
  • rikadoo
Ik heb hier een DS214Play met een probleem, het blauwe lampje knippert, word nergens meer gezien in het netwerk.
De disk die ik er tijdelijk in gedaan hebt die boot 'nog' niet op.
Nu heb ik er een serieel console aangehangen op de poort intern in de NAS en kwam de volgende POST eruit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
AC_BOOT
Intel(R) Consumer Electronics Firmware Development Kit (Intel(R) CEFDK)
Copyright (C) 1999-2012 Intel Corporation. All rights reserved.
Build Time (03/04/14 18:20:11).
Searching 8051 FW in MFH...
Load 8051 FW from MFH successfully!
No active splash screen found in flash.
Showing black screen.
SMM: Ok
ACPI Init: finished with table region from 00011aa0 to 00018000
acpi: Created tables at 00011aa0-00018000
PCIe Port0 setting: Auto
PCIe Port1 setting: Gen1
CEFDK Version        : CE5300 (SMP enabled)
8051 Firmware        : C0-1.0.49 (0x00050000)
8051 FW I/O Module   : NEC-1.0.082
Silicon Stepping     : D0 (PCI)
Silicon SKU          : 0x07C
Board                : REF0
CPU Threads          : 4
CPU Multiplier       : 16
CPU Bus Speed        : 100 MHz
Memory Size          : 1024 MB
Memory Type & Speed  : x16 DDR3-1600 (11-11-11)
Memory Configuration : A B Interleave Mode 1
PCI Mode             : PCI Standard
Boot Mode            : SPI-NOR
mac address is the same, skip sync.
Registered net controller: e1000e
Waiting for the Link up: /
1000M FD Link is ready!
Configure IP via static IP.
Mac address is    : 00:11:32:26:9F:D2
Host IP address is: 192.168.1.3
Subnet Mask is    : 255.255.255.0
Gateway address is: 192.168.1.1
Press 'Enter' within 2 seconds to disable automatic boot.
Hit a key to start the shell...
ERROR: Invalid or missing kernel at 0x01000000.
Attempting to boot Linux from NOR ...
Kernel not found at 0xC0140000 in NOR, continue booting from HD.
Attempting to boot Redboot...
ERROR: No active Redboot found in flash.
Attempting to boot Linux...
Attempting to boot from HDD...
Attempting to boot redboot from Sector 1 of HD 0...
No valid redboot found in HD(s).
Reading boot sector...done.
Error: Invalid boot sector.
shell>
Dit lijkt te duiden op een relatief ernstig geval van corrupte boot software maar wat mij nog wel lijkt te fixen.
Ik ben er een avondje mee bezig geweest maar ik kom er nog niet zo goed uit, wellicht dat er iemand is die mij een zetje in de goede richting kan geven.
Ik heb de NAS een IP gegeven, die is nu te zien in de POST, hiermee kan ik connecten met een TFTP server in mijn LAN en dit werkt ik heb er verscheidene files heen kunnen verzenden maar ik ben er nog niet echt achter hoe ik deze kan laten opstarten, Bijv RedBoot of een ramdisk.
De commando`s waar ik het mee moet doen:
29
30
31
32
33
34
35
36
shell> help
   bootata - Boots from the primary master ATA device.
 bootlinux - Boots linux from flash. Usage: bootlinux "<kernel cmd line>"
    ymodem - Receive a file from serial using YMODEM.
     lspci - Displays PCI device info.
  ord[2|4] - Read or write to memory.
  pci[2|4] - Read or write to PCI configuration space.
 port[2|4] - Read or write to I/O port.
   ramdisk - set ramdisk start address and length
      mmap - Displays a system memory map.
  expflash - Access flash on expansion bus.
 bootflash - Boot Redboot from flash.
bootkernel - Boot Linux kernel from flash.
       mfh - manage the MFH on flash devices
       sha - Calculate a SHA sum for an input data string.
       md5 - Calculate a MD5 sum for an input data string.
      emmc - Auxiliary shell command to handle eMMC
 spi_flash - Auxiliary shell command to handle SPI Flash
     strap - reading the strappings on Soc.
      8051 - 8051 specific commands
     svmem - Perform SV memory test
   ata-map - Sets the ATA geometry mapping.
     cache - Manipulate the processor cache.
  settings - BIOS Settings
       i2c - I2C buses read and write (SV ver).
      iosf - Read/write 32 bit register on IOSF sideband port.
      ping - Ping destination [Ping count number]
      tftp - Download/upload file from/to server via TFTP.
        ip - Configure CEFDK static IP address, Subnet Mask and Gateway address.
     ifset - Select actived net interface
    script - Switch on/off the automatic shell script.
      gpio - gpio  commands
      help - Displays this screen.
      exit - Stops the shell.
  showbcmd - Print the default boot arguments.
shell>
Wat dingen die ik krijg bij wat commando`s:
shell> bootata
Attempting ATA boot...
shell>
shell> bootlinux
Linux command line = 'console=ttyS0,115200 mem=exactmap memmap=640K@0 memmap=127M@1M root=/dev/nfs rw nfsroot=192.168.002.001:/tmp/share/ce5300_disk  ip=192.168.002.100:192.168.002.001:192.168.002.001:255.255.255.0:CE5300:eth0:off acpi=verbose'
Attempting to boot Linux from flash...
Error booting Linux: Invalid or missing kernel at 0xC0140000.
shell>
shell> bootflash
shell>
Het boeltje draait op een Intel Atom CPU en het lijkt erop dat dit dus de firmware gedeelte is van deze NAS
en dat draait op, Intel(R) Consumer Electronics Firmware Development Kit. Ik heb verschillende dingen gevonden op internet maar dit was allemaal op Marvell en realtek gebaseerd die weer andere manier van aanspreken in hun firmware hebben.
AMD Ryzen 7 5900x | Custom WC | ASUS ROG Strix X570-E Gaming | 32GB Corsair DDR4-3600MHz | Samsung 970 nvme 1TB | Samsung 860 EVO 2TB | AMD RX 6900XT 16GB | 1x Asus RoG XG27AQDMG | 1x LG UltraGear 27GL850
  • Wylana
  • Laatst online: 15-10 08:41
Je kan kijken of je via de recovery methode de nas kan redden.
Echter heb je hier wel een HDD voor nodig die gewiped mag worden.
Dus als er data op je HDD staat die in je NAS zit, dan moet je die eerst eruit halen en daarna onderstaande stappen volgen.
Members only:
bron: https://nellocastellano.com/fix-synologys-blue-led-death/
Ik ben steenrijk....ik heb een grindpad!
  • rikadoo
Wylana schreef op woensdag 18 september 2019 @ 12:03:
Members only:
Gaat niet werken, hij komt daar niet voorbij. Word niet gezien in de lan via DSM oid. Het gaat daarvoor al mis, zie de logs (kernel missing etc)
  • Wylana
Als Synology Assistant hem ook niet ziet, dan is het enige wat je kan doen een melding maken bij Synology om hem te herstellen.
Omdat je nog wel een console sessie hebt, kunnen zij mogelijk via die weg hem herstellen.
  • rikadoo
Wylana schreef op woensdag 18 september 2019 @ 12:31:
Verwacht het niet, is console via het bord zelf. heb hem helemaal uit elkaar gehaald en er zit dus een seriele connectie op. Die lees ik uit met putty. Is dus niet te benaderen vanaf internet oid.
  • -36-
  • Laatst online: 05-09 14:22
-36-
Trust me. I'm an amateur
Via spi een nieuwe image flashen kan misschien helpen.
https://forum.synology.com/enu/viewtopic.php?t=84141
  • rikadoo
Bedankt voor het meedenken, SPI flash is me wat te lastig zonder de benodigde informatie van mijn systeem.
Ik heb het momenteel opkunnen lossen door hetvolgende:
Hier zie je de partities mee
mfh list
 MFH Entry List
 Type                   ID Active Offset     Size       Label
cefdk_s1                00 YES    0x00000000 0x00010000
cefdk_s2                00 YES    0x00010000 0x0006F000
cefdk_s1h               00 YES    0x0007f000 0x00000800
cefdk_s2h               00 YES    0x0007f800 0x00000800
uc8051_fw               00 YES    0x00080800 0x00010000
cefdk_params            00 YES    0x00090800 0x000005F0
ip_params               00 YES    0x00090df0 0x00000010
plat_params             00 YES    0x00090e00 0x00010000
kernel                  00 YES    0x000a0e00 0x00300000
ramdisk                 00 YES    0x003a0e00 0x00400000
user flash              00 NO     0x007d0000 0x00000000
Om de kernel te wissen
mfh delete kernel 0
In de ramdisk te wissen
mfh delete ramdisk 0
Vervolgens:
mfh add kernel 0
Nu word er gevraagd om de kernel te versturen via ymodem, dit doe je door de firmware file te openen en zImage bestand eruit te halen en te verzenden. De boel word automatisch na het laden geconfigureerd en om de juiste plek geprogrammeerd.
mfh add ramdisk 0
Hetzelfde als hierboven alleen nu upload je het bestand rd.bin.
Nadat dit succesvol is gegaan kan je een reset commando geven en is de Synology weer zichtbaar en up en running voor een nieuwe installatie.
  • BartNL
  • Laatst online: 23:07
rikadoo schreef op maandag 16 september 2019 @ 21:39:
lijkt op bekend probleem met Intel CPU's in Synology NAS zie https://community.synology.com/enu/forum/1/post/120548
Je zou kunnen proberen of de daar beschreven fix met 100Ohm weerstand voor jouw NAS werkt?
  • MsG
  • Laatst online: 15-10 12:47
MsG
Forumzwerver
Wat als je hem zonder schijven en met niets er verder aan laat booten. Piept hij dan na een minuut? Ik heb ook een Synology die blauw knippert, maar ik heb de seriële connectie nog niet geprobeerd. Ik krijg zelf helaas geen piep na een minuut, wat wel duidt op hardware-falen in mijn geval.
  • rikadoo
BartNL schreef op dinsdag 24 september 2019 @ 16:07:
Klopt idd, dit was ook het eerste waar ik naar keek, maar de CPU die hierin zit valt hier niet onder. (Intel Atom CE5335)
MsG schreef op dinsdag 24 september 2019 @ 16:12:
Nee hij piepte niet, met of zonder harddisks`s, hij bleef aanstaan met de blauwe LED knipperen en geen opspinnende disken (wat gebeurd als de kernel geladen word, dan worden de disken pas aangesproken), verder niets. Dat die niet piept hoeft geen hardware falen te zijn. gebeurde bij mij ook niet met een missende kernel, echter na het reflashen ervan start deze op zoals alle Synology`s doen.
  • MsG
MsG
Forumzwerver
rikadoo schreef op dinsdag 24 september 2019 @ 17:18:
Klinkt zeer interessant. Heb je wat info over die SPI flash truukjes die jij nu uithaalt? Op Google stopt iedereen meteen met zijn Synology als de Manager hem niet meer vindt. Ga ik ook nog eens kijken of ik de boel kan repareren, de mijne heeft namelijk ook niet de bewuste defecte CPU.
  • rikadoo
MsG schreef op dinsdag 24 september 2019 @ 18:20:
Wat ik heb gedaan staat hierboven, dit is echter wel een Intel CPU, als jou NAS een Marvell of Realtek heeft dan hebben ze weer andere commando`s. Mijn nas is gebaseerd op Intel CEDFK bootloader, Marvell en Realtek werken op U-Boot.
[ Voor 47% gewijzigd door rikadoo op 24-09-2019 18:24 ]
  • MsG
MsG
Forumzwerver
rikadoo schreef op dinsdag 24 september 2019 @ 18:23:
Ik bedoel de fysieke connectie. Heb je anders wat foto's waar je dat dan op aansluit? Bij mij betreft het een reguliere DS214, die een Marvell Armada XP SoC heeft.
  • rikadoo
MsG schreef op dinsdag 24 september 2019 @ 18:25:
Aah
Dit is de pinout:
Pin Number  Function
1 3.3V
2 GND
4 TX
6 RX
Je hebt een RS232 naar TTL converter nodig, en teraterm (geen putty, die gaf bij mij problemen met het uploaden van de kernel)
Baudrate is 1115200.
[ Voor 8% gewijzigd door rikadoo op 24-09-2019 18:37 ]
